Bmeters problem z odczytem jednego z 2 identycznych wodomierzy
Walczę od kilku dni z dekodowaniem telegramu jednego z dwóch wodomierzy.
Dwa wodomierze Bmeters. W przypadku jednego jest OK a drugi nie.
Log wygląda następująco:
[11:13:39][I][wmbus:081]: Using driver 'bmeters' for ID [0x19179448] RSSI: -49 dBm LQI: 128 Mode: T1 T: 4D44B4094894171913077AE1084005F49D81081B88B96B94A845EF8FF76EAFC2CF027C0D2858257042CC0FC4EB79A8B7754331B345256B7BF2288785489D012936D4076FB82E3578C71A33883EAD (78)
[11:13:39][E][wmbus:106]: Something was not OK during decrypting telegram for ID [0x19179448] 'bmeters' key: '00000000000000000000000000000000'
[11:13:39][E][wmbus:110]: T : 4D44B4094894171913077AE1084005F49D81081B88B96B94A845EF8FF76EAFC2CF027C0D2858257042CC0FC4EB79A8B7754331B345256B7BF2288785489D012936D4076FB82E3578C71A33883EAD (78)
[11:13:39][E][wmbus:111]: T': 4D44B4094894171913077AE1084005E87B2D2D11BC2D7392D929771E9D3FCD0C8202CFD0B2D57616D80E4976DD11549B0391FDB179D067BB5ECAC7CD19113E2936D4076FB82E3578C71A33883EAD (78)
[11:13:39][W][component:214]: Component wmbus took a long time for an operation (0.07 s).
[11:13:39][W][component:215]: Components should block for at most 20-30ms.
[11:13:48][I][wmbus:081]: Using driver 'bmeters' for ID [0x21501195] RSSI: -55 dBm LQI: 128 Mode: T1 T: 4E44B4099511502113077A29404005709F2DE46FD2CD57A8D866C300984BEED5500C81317788FA96FAC1E46C61A4BBC9D8358885A5366BAFCA2CF53C1F58C36092D5F57A02BE7F6F966C1B69E0C185 (79)
[11:13:48][D][wmbus:094]: Decrypted T : 4E44B4099511502113077A294040052F2F0C1375901200046D082BF22C0F9529230904760000002A2100792100C522008923003B2600862800662C007C2D006092D5F57A02BE7F6F966C1B69E0C185 (79)
[11:13:48][D][sensor:093]: 'Licznik wody1 LQI': Sending state 128.00000  with 0 decimals of accuracy
[11:13:48][D][sensor:093]: 'Licznik wody1 RSSI': Sending state -55.00000 dBm with 0 decimals of accuracy
[11:13:48][D][sensor:093]: 'Licznik wody1': Sending state 129.07500 m³ with 3 decimals of accuracy
[11:13:48][W][component:214]: Component wmbus took a long time for an operation (0.07 s).
[11:13:48][W][component:215]: Components should block for at most 20-30ms.
Co mogę z tym zrobić, gdyż pomysły mi się skończyły.
Proponuję
  1. nie podklejać swoich problemów do losowo wybranego wątku tylko dlatego, że jest w danym momencie aktywny
  2. wywołać specjalistę - autora komponentu
    małpa nick
    @_Szczepan
nie mogę moderować mając totalnie uszkodzoną klawiaturę…
Jesteś pewien, że oba używają tego samego klucza?
Tak z pewnością to problem klucza, jednak na tym poległem.
Spróbować inny klucz, albo uzyskać klucz do niego.
Poproś wodociągi o klucz albo poszukaj w necie jakiegoś domyślnego (o ile istnieje).
