rok 2021
1.16.0 (luty 2021) - Enable reverse display of the Max7219 digit; Pulse_counter measure total pulses; Support I2C transactions with combined reads and writes
1.17.0 (4 maj 2021) - MCP23XXX Refactor
1.18.0 (19 maj 2021) - Raise minimum python version to 3.7; esphome: Change wifi signal strength unit to dBm; esphome: Use core constants for sample duration on bh1750
1.19.0 (czerwiec 2021) - Drop 128x160 ESP-32 camera resolution; teleinfo: use text_sensor and sensor; CLI user experience improvements
1.20.0 (lipiec 2021) - Change color model to fix white channel issues - addressable RGBW lights + RGBW lights; remote_receiver use config parent receiver for registering dumpers; Remove a whole bunch of deprecated/removed stuff; catch 0.0 in float set_level pre-adjustment; Climate mode meaning was changed
2021.8.0 - Merge build flags from platformio_options; Color mode implementation; Fix parity bit calculation for ESP8266SoftwareSerial; Dont force 0 state instead of min_power unless explicit config set; Anova fahrenheit support; Tidy HA addon; Thermostat enhancements 2
2021.9.0 - Fix SDM energy units to be KILO; Reject template select/number/switches that don’t handle user input; Remove last_reset_type and convert all those sensors to TOTAL_INCREASING; Midea support v2
2021.10.0 - Combine code of xiaomi_miscale and xiaomi_miscale2; Correctly invert the float output state; Add SSD1305 support to SSD1306 integration along with few new options; Disable dependency finder on ESP32
2021.11.0 - TCS34725 BugFix and GA factor; Limit hostnames to 31 characters; Move default build path to .esphome directory; ESP8266 disable PIO LDF; Remove autoload of xiaomi_ble and ruuvi_ble; BH1750: Fix a too high default H-res2 mode value; Add option to use MQTT abbreviations; Add restore_mode to rotary_encoder; Neopixelbus redo method definitions; Update device classes for binary sensors; BLE_Sensor: Use as_reversed_hex_array to properly parse UUIDs after
2021.12.0 - Fix NEC protocol implementation; Tuya Cover improvements
https://esphome.io/changexiaomi_blelog/2021.12.0
