rok 2022
wydania lipcowego nie było - okres wakacyjny
2022.1.0 - Modbus: use multiply for publishing number; Upgrade ArduinoJson to 6.18.5 and migrate code; Fix backwards string case helpers
2022.2.0 - [TCS34725] remove duplicated endian conversion; TSL2591 automatic gain control; [debug] Refactor debug sensors to use the normal sensor model; Allow framework version validator to be maximum version
2022.3.0 - BH1750 dynamically calculate options; Add class as first positional arg to sensor_schema; Raise minimum python version to 3.8
2022.4.0 - Make home_assistant imported sensors internal by default
2022.5.0 - select component; number component
2022.6.0 - TCS34725 automatic sampling settings; support for SGP41; Remove deprecated fan speeds; Output a true RMS voltage %, Add display_type property to DisplayBuffer
wydania lipcowego (które by miało numer wersji 2022.7.0) nie było - okres wakacyjny
2022.8.0 - Extend ST7789V component to support additional displays; Refactor BedJet climate into Hub component; Remove min_save_interval from intergration and total_daily_energy; Rework NaN handling in sensor filters
2022.9.0 - jedna z niewielu wersji nie mających oficjalnie breaking changes
2022.10.0 - Thermostat remove deprecated config; Bump python min to 3.9; Refactor xpt2046 to be a touchscreen platform; Add ble RSSI sensor for connected devices
2022.11.0 - Don’t Use Base Network Manual IP for WiFi AP
2022.12.0 - Update esp32 arduino and platform versions; Docker Container images
