Próbuję połączyć się z piecem przez USB za pomocą ebusd i nijak mi nie wychodzi. Po wifi działa bez problemu.
USB wykrywa:
Takie logi i nic więcej:
> ebusd --foreground --mqtthost=core-mosquitto --mqttport=1883 --mqttuser=addons --mqttpass=ef4ohphai6wakae1oa5avei3rio8quae1AeVaimoh5aiRaiquoowu6ohy3eiP0To --scanconfig --mqttjson --latency=10 --mqttint=/etc/ebusd/mqtt-hassio.cfg --mqtttopic=ebusd --device=/dev/ttyUSB1 --log=all:debug
2023-02-07 23:32:20.551 [main notice] ebusd 23.1.p20230106 started with auto scan on device /dev/ttyUSB1
2023-02-07 23:32:20.551 [main info] loading configuration files from https://cfg.ebusd.eu/
2023-02-07 23:32:20.763 [main info] reading templates /
2023-02-07 23:32:20.995 [main info] read templates in /
2023-02-07 23:32:20.995 [main info] reading file memory.csv
2023-02-07 23:32:21.218 [main info] successfully read file memory.csv
2023-02-07 23:32:21.218 [main info] reading file broadcast.csv
2023-02-07 23:32:21.453 [main info] successfully read file broadcast.csv
2023-02-07 23:32:21.453 [main info] read config files, got 11 messages
2023-02-07 23:32:21.454 [bus notice] bus started with own address 31/36
2023-02-07 23:32:21.455 [main info] registering data handlers
2023-02-07 23:32:21.455 [mqtt info] mosquitto version 2.0.15 (compiled with 2.0.15)
2023-02-07 23:32:21.457 [mqtt debug] connection requested
2023-02-07 23:32:21.457 [main info] registered data handlers
2023-02-07 23:32:21.458 [mqtt notice] connection established
2023-02-07 23:32:21.458 [mqtt debug] publish ebusd/global/version "ebusd 23.1.p20230106"
2023-02-07 23:32:21.458 [mqtt debug] publish ebusd/global/running true
2023-02-07 23:32:31.458 [main debug] performing regular tasks
2023-02-07 23:32:37.557 [mqtt debug] publish ebusd/global/uptime 16
2023-02-07 23:32:37.557 [mqtt debug] publish homeassistant/binary_sensor/ebusd_global_running/config {
"unique_id":"ebusd_global_running",
"device":{
"identifiers":"ebusd",
"manufacturer":"ebusd.eu",
"name":"ebusd",
"sw_version":"23.1",
"suggested_area":"Heating"
"state_topic":"ebusd/global/running",
"name":"ebusd running",
"device_class":"running",
"state_class":"measurement",
"payload_on":"true",
"payload_off":"false"
2023-02-07 23:32:37.558 [mqtt debug] publish homeassistant/binary_sensor/ebusd_global_signal/config {
"unique_id":"ebusd_global_signal",
"device":{
"name":"ebusd",
"state_topic":"ebusd/global/signal",
"name":"ebusd signal",
"device_class":"connectivity",
2023-02-07 23:32:37.558 [mqtt debug] publish homeassistant/sensor/ebusd_global_uptime/config {
"unique_id":"ebusd_global_uptime",
"device":{
"name":"ebusd",
"state_topic":"ebusd/global/uptime",
"name":"ebusd uptime",
"state_class":"total_increasing",
"unit_of_measurement":"s"
2023-02-07 23:32:37.558 [mqtt debug] publish homeassistant/update/ebusd_global_updatecheck/config {
"unique_id":"ebusd_global_updatecheck",
"device":{
"name":"ebusd",
"state_topic":"ebusd/global/updatecheck",
"name":"ebusd updatecheck",
"value_template":"{% set my_new = value_json|truncate(255)|regex_replace(find=',.*| available|revision v|version v|OK',replace='') %}{% if my_new == '' %}{% set my_new = '23.1' %}{% endif %}{{ {'installed_version':'23.1','latest_version':my_new,'entity_picture':'https://ebusd.eu/logo-32x32.png','release_url':'https://github.com/john30/ebusd/releases/latest'} | tojson }}"
2023-02-07 23:32:37.559 [mqtt debug] publish homeassistant/sensor/ebusd_global_scan/config {
"unique_id":"ebusd_global_scan",
"device":{
"name":"ebusd",
"state_topic":"ebusd/global/scan",
"name":"ebusd scan",
2023-02-07 23:32:41.459 [main debug] performing regular tasks
2023-02-07 23:32:51.459 [main debug] performing regular tasks
2023-02-07 23:32:53.578 [mqtt debug] publish ebusd/global/uptime 32
2023-02-07 23:33:01.460 [main debug] performing regular tasks
2023-02-07 23:33:09.599 [mqtt debug] publish ebusd/global/uptime 48
2023-02-07 23:33:11.461 [main debug] performing regular tasks
Ktoś korzysta po USB może coś robię źle.
To jest dobre na tym forum , edytuje swój wpis 4 dni później żeby przekazać o ogarnięciu połączenia ebusd do HA przez COM. W “odpowiedzi” zablokowaliby mi konto
Wystarczyło wpisać w polu “network_device:” ścieżkę do adaptera po COM’ie. Wiem, że dziwne ale działa .
Może komuś się przyda.
Co ciekawe z1DayTemp dalej nie działa . Przez co nie mogę normalnie ustawić integracji “climate”
