Hej, sprawdziłem z najnowszą wersją iiiiii… udało się zdekodować 1.ramkę!
Nawet niejedną
[21:21:29][V][rxLoop:171]: Have 299 bytes from CC1101 Rx, RSSI: -52 dBm LQI: 128
[21:21:29][V][rxLoop:176]: Synchronus mode enabled.
[21:21:29][D][mbus:034]: Processing T1 A frame
[21:21:29][V][mbus:040]: Frame: 9B271C58D59A35994BB0B65A58D58EA6C2E34E669335699659965A5A9B32D0EA664E5C592EC94DA6395C2DA8F198D36534E9534D999C2DA68B7315A6723B0DB3295965669C6B4665D32996599B0B98BB23A71C8B58B6A39ACC6CC692E5CA57344CB2F497472939CA4BD0EA6CB2694D5B1C4B5A670B96CD0D95CB345B2A71674B1C8E62D69692F2A71D198DAD292D68DC3938D358D71A35CCB1B325B42DA6B46B25A9B1965659AA5C66C734B269A3A72B1370ED2658ED19C5A3B4D23A6671A4E594D729734B13D31A [RAW]
[21:21:29][V][mbus:042]: Frame: 694F138E9A371A5993992D64E37195A3713D342CB729D0D3A99ACD0D4CD36CA74A747298D32F4D3470E6A66562DC95A68E58B59C971A4DA5966C3712E3D13A6597164B2CB99C3744CD999D2C3B12CECB24F265672CD0B2E569664E663B1A4F296C4CD5 (299) [RAW]
[21:21:29][V][mbus:052]: Frame: AE440106159383560102F83B7A6710A005560F8EC2FA79D53891FB9436BDA119129775A436634D0A4B818E9550646C59CEA00583A38BFDE3036BA8D8DF39E94C733C9C4F24F3C2F88A910DD30A4398C1948C0EFD5C84BA309F3EFDC5B6CF30B427B7014614ED8E0C366C6E0F855006F4584C8AABFE8742CA02C5D62CCBFA4679914F4C87CDFF7D22AB460525307B450B47CC334FC12FA8C17118FCFC4FB73CCC426A5034966203049DF1F5581D3BC7F99D5333A41C71A5C82D32EE7E5048C33960525B867E9871 (199) [with CRC]
[21:21:29][V][mbus:095]: Validating CRC for Block1
[21:21:29][V][crc:031]: calculated: 0xF83B, read: 0xF83B
[21:21:29][V][mbus:115]: Validating CRC for Block2
[21:21:29][V][crc:031]: calculated: 0x36BD, read: 0x36BD
[21:21:29][V][mbus:115]: Validating CRC for Block3
[21:21:29][V][crc:031]: calculated: 0x6C59, read: 0x6C59
[21:21:29][V][mbus:115]: Validating CRC for Block4
[21:21:29][V][crc:031]: calculated: 0x733C, read: 0x733C
[21:21:29][V][mbus:115]: Validating CRC for Block5
[21:21:29][V][crc:031]: calculated: 0x0EFD, read: 0x0EFD
[21:21:29][V][mbus:115]: Validating CRC for Block6
[21:21:29][V][crc:031]: calculated: 0x14ED, read: 0x14ED
[21:21:29][V][mbus:115]: Validating CRC for Block7
[21:21:29][V][crc:031]: calculated: 0x42CA, read: 0x42CA
[21:21:29][V][mbus:115]: Validating CRC for Block8
[21:21:29][V][crc:031]: calculated: 0xAB46, read: 0xAB46
[21:21:29][V][mbus:115]: Validating CRC for Block9
[21:21:29][V][crc:031]: calculated: 0xFCFC, read: 0xFCFC
[21:21:29][V][mbus:115]: Validating CRC for Block10
[21:21:29][V][crc:031]: calculated: 0x1D3B, read: 0x1D3B
[21:21:29][V][mbus:115]: Validating CRC for Block11
[21:21:29][V][crc:031]: calculated: 0xC339, read: 0xC339
[21:21:29][V][mbus:115]: Validating CRC for Block12
[21:21:29][V][crc:031]: calculated: 0x9871, read: 0x9871
[21:21:29][V][mbus:062]: Frame: AE4401061593835601027A6710A005560F8EC2FA79D53891FB94A119129775A436634D0A4B818E955064CEA00583A38BFDE3036BA8D8DF39E94C9C4F24F3C2F88A910DD30A4398C1948C5C84BA309F3EFDC5B6CF30B427B701468E0C366C6E0F855006F4584C8AABFE8702C5D62CCBFA4679914F4C87CDFF7D220525307B450B47CC334FC12FA8C171184FB73CCC426A5034966203049DF1F558C7F99D5333A41C71A5C82D32EE7E504860525B867E (175) [without CRC]
[21:21:29][D][wmbus:097]: Using driver 'amiplus' for ID [0x56839315] RSSI: -52 dBm LQI: 128 Frame: T1 A T: AE4401061593835601027A6710A005560F8EC2FA79D53891FB94A119129775A436634D0A4B818E955064CEA00583A38BFDE3036BA8D8DF39E94C9C4F24F3C2F88A910DD30A4398C1948C5C84BA309F3EFDC5B6CF30B427B701468E0C366C6E0F855006F4584C8AABFE8702C5D62CCBFA4679914F4C87CDFF7D220525307B450B47CC334FC12FA8C171184FB73CCC426A5034966203049DF1F558C7F99D5333A41C71A5C82D32EE7E504860525B867E (175)
[21:21:29][V][utils:291]: 2F2F check after decrypting - OK
[21:21:29][D][wmbus:104]: Decrypted T : AE4401061593835601027A6710A0052F2F066D9E55151632400C78159383560E035211160000008E10030841070000008E20034470080000008E30030000000000008E8010030000000000000E833C6308000000008E10833C6308000000008E20833C0000000000008E30833C0000000000008E8010833C0000000000000B2B8101000AFDC9FC0136020AFDC9FC0236020AFDC9FC0329020BABC8FC100000002F2F2F2F2F2F2F2F2F2F2F2F2F2F2F (175)
[21:21:29][V][wmbus:121]: Publishing 'current_power_consumption_kw' = 0.1810
[21:21:29][V][sensor:043]: 'Current power consumption in kW': Received new state 0.181000
[21:21:29][D][sensor:094]: 'Current power consumption in kW': Sending state 0.18100 kW with 3 decimals of accuracy
[21:21:29][V][wmbus:121]: Publishing 'total_energy_consumption_kwh' = 161.1520
[21:21:29][V][sensor:043]: 'Consumption in kWh': Received new state 161.151993
[21:21:29][D][sensor:094]: 'Consumption in kWh': Sending state 161.15199 kWh with 3 decimals of accuracy
[21:21:29][V][wmbus:121]: Publishing 'total_energy_production_kwh' = 0.8630
[21:21:29][V][sensor:043]: 'Total energy production in kWh': Received new state 0.863000
[21:21:29][D][sensor:094]: 'Total energy production in kWh': Sending state 0.86300 kWh with 3 decimals of accuracy
[21:21:29][V][wmbus:121]: Publishing 'voltage_at_phase_1_v' = 236.0000
[21:21:29][V][sensor:043]: 'napiecie L1': Received new state 236.000000
[21:21:29][D][sensor:094]: 'napiecie L1': Sending state 236.00000 V with 0 decimals of accuracy
[21:21:29][V][wmbus:121]: Publishing 'voltage_at_phase_2_v' = 236.0000
[21:21:29][V][sensor:043]: 'napiecie L2': Received new state 236.000000
[21:21:29][D][sensor:094]: 'napiecie L2': Sending state 236.00000 V with 0 decimals of accuracy
[21:21:29][V][wmbus:121]: Publishing 'voltage_at_phase_3_v' = 229.0000
[21:21:29][V][sensor:043]: 'napiecie L3': Received new state 229.000000
[21:21:29][D][sensor:094]: 'napiecie L3': Sending state 229.00000 V with 0 decimals of accuracy
[21:21:29][W][component:214]: Component wmbus took a long time for an operation (0.53 s).
[21:21:29][W][component:215]: Components should block for at most 20-30ms.
[21:22:00][V][rxLoop:171]: Have 299 bytes from CC1101 Rx, RSSI: -52 dBm LQI: 128
[21:22:00][V][rxLoop:176]: Synchronus mode enabled.
[21:22:00][D][mbus:034]: Processing T1 A frame
[21:22:00][V][mbus:040]: Frame: 9B271C58D59A35994BB0B65A58D58EA6C2E34E66AC356996599C9A4DAC5A59A7233B270D67472598B2CD596713A4D8E396C35AA6C2EC2E3D1AA596B1A5639A4DC64B8F1D1CC65A5639A2DA99C64E64D4CBA634DA2EC98E719726B0BB2CCB466C719C5A9B1C4BB263A6CB47235A37312E995A6B14D9C5A6534EC8D370D38DA5C4DA38E4D98E5665671A4DD133664D995C2D3C6C68DC93363C5358D4ECD1966936395A723CA56A998BA532DCC698DC4E3674C5C971D0E98BC636636728E96749532D34E694D4E56A32 [RAW]
[21:22:00][V][mbus:042]: Frame: E6B19C639B2CB22DCC656635B1956C9CD252F4C5C70B6724D98DC4EC5A54CB6A62DAC7134ED0D3A33996A6723CA96A59655B1359B16C5670BCA94CD9715AC96672C696A598DC8F199C9B1D253A94F268E38BA4B9634E56652CDA69B2C8F238D70D4D65 (299) [RAW]
[21:22:00][V][mbus:052]: Frame: AE440106159383560102F83B7A6810A005E676D6064B2E415C49A3310047F1BB9816F8383BC6F56DF0267453BDC4D9F02636A4525173FB7638A2454A8388EC5845D6ADD38A2AEC4B0B4D3F966D75D65778B74121F4762275B9595DF1C71A759437D861E71BD70178C55F1B964BE96FA3F734DFB47B5CD49DC2A3DB5B5EBF5C97377A91796B3A85DBAEEE34D95B0D90E4C93CD4435E75B47809736A36DD12C12B256A4BEF69990D1580D043EF719D089A4860F5B4BDA4ADC92F7E6223F39B795931FF88BE214170 (199) [with CRC]
[21:22:00][V][mbus:095]: Validating CRC for Block1
[21:22:00][V][crc:031]: calculated: 0xF83B, read: 0xF83B
[21:22:00][V][mbus:115]: Validating CRC for Block2
[21:22:00][V][crc:031]: calculated: 0x0047, read: 0x0047
[21:22:00][V][mbus:115]: Validating CRC for Block3
[21:22:00][V][crc:031]: calculated: 0xD9F0, read: 0xD9F0
[21:22:00][V][mbus:115]: Validating CRC for Block4
[21:22:00][V][crc:031]: calculated: 0x45D6, read: 0x45D6
[21:22:00][V][mbus:115]: Validating CRC for Block5
[21:22:00][V][crc:031]: calculated: 0x4121, read: 0x4121
[21:22:00][V][mbus:115]: Validating CRC for Block6
[21:22:00][V][crc:031]: calculated: 0x1BD7, read: 0x1BD7
[21:22:00][V][mbus:115]: Validating CRC for Block7
[21:22:00][V][crc:031]: calculated: 0xD49D, read: 0xD49D
[21:22:00][V][mbus:115]: Validating CRC for Block8
[21:22:00][V][crc:031]: calculated: 0xAEEE, read: 0xAEEE
[21:22:00][V][mbus:115]: Validating CRC for Block9
[21:22:00][V][crc:031]: calculated: 0x6A36, read: 0x6A36
[21:22:00][V][mbus:115]: Validating CRC for Block10
[21:22:00][V][crc:031]: calculated: 0x719D, read: 0x719D
[21:22:00][V][mbus:115]: Validating CRC for Block11
[21:22:00][V][crc:031]: calculated: 0x7959, read: 0x7959
[21:22:00][V][mbus:115]: Validating CRC for Block12
[21:22:00][V][crc:031]: calculated: 0x4170, read: 0x4170
[21:22:00][V][mbus:062]: Frame: AE4401061593835601027A6810A005E676D6064B2E415C49A331F1BB9816F8383BC6F56DF0267453BDC42636A4525173FB7638A2454A8388EC58ADD38A2AEC4B0B4D3F966D75D65778B7F4762275B9595DF1C71A759437D861E70178C55F1B964BE96FA3F734DFB47B5CC2A3DB5B5EBF5C97377A91796B3A85DB34D95B0D90E4C93CD4435E75B4780973DD12C12B256A4BEF69990D1580D043EF089A4860F5B4BDA4ADC92F7E6223F39B31FF88BE21 (175) [without CRC]
[21:22:00][D][wmbus:097]: Using driver 'amiplus' for ID [0x56839315] RSSI: -52 dBm LQI: 128 Frame: T1 A T: AE4401061593835601027A6810A005E676D6064B2E415C49A331F1BB9816F8383BC6F56DF0267453BDC42636A4525173FB7638A2454A8388EC58ADD38A2AEC4B0B4D3F966D75D65778B7F4762275B9595DF1C71A759437D861E70178C55F1B964BE96FA3F734DFB47B5CC2A3DB5B5EBF5C97377A91796B3A85DB34D95B0D90E4C93CD4435E75B4780973DD12C12B256A4BEF69990D1580D043EF089A4860F5B4BDA4ADC92F7E6223F39B31FF88BE21 (175)
[21:22:00][V][utils:291]: 2F2F check after decrypting - OK
[21:22:00][D][wmbus:104]: Decrypted T : AE4401061593835601027A6810A0052F2F066D8056151632400C78159383560E035411160000008E10031041070000008E20034470080000008E30030000000000008E8010030000000000000E833C6308000000008E10833C6308000000008E20833C0000000000008E30833C0000000000008E8010833C0000000000000B2B8101000AFDC9FC0135020AFDC9FC0236020AFDC9FC0329020BABC8FC100000002F2F2F2F2F2F2F2F2F2F2F2F2F2F2F (175)
[21:22:00][V][wmbus:121]: Publishing 'current_power_consumption_kw' = 0.1810
[21:22:00][V][sensor:043]: 'Current power consumption in kW': Received new state 0.181000
[21:22:00][D][sensor:094]: 'Current power consumption in kW': Sending state 0.18100 kW with 3 decimals of accuracy
[21:22:00][V][wmbus:121]: Publishing 'total_energy_consumption_kwh' = 161.1540
[21:22:00][V][sensor:043]: 'Consumption in kWh': Received new state 161.154007
[21:22:00][D][sensor:094]: 'Consumption in kWh': Sending state 161.15401 kWh with 3 decimals of accuracy
[21:22:00][V][wmbus:121]: Publishing 'total_energy_production_kwh' = 0.8630
[21:22:00][V][sensor:043]: 'Total energy production in kWh': Received new state 0.863000
[21:22:00][D][sensor:094]: 'Total energy production in kWh': Sending state 0.86300 kWh with 3 decimals of accuracy
[21:22:00][V][wmbus:121]: Publishing 'voltage_at_phase_1_v' = 235.0000
[21:22:00][V][sensor:043]: 'napiecie L1': Received new state 235.000000
[21:22:00][D][sensor:094]: 'napiecie L1': Sending state 235.00000 V with 0 decimals of accuracy
[21:22:00][V][wmbus:121]: Publishing 'voltage_at_phase_2_v' = 236.0000
[21:22:00][V][sensor:043]: 'napiecie L2': Received new state 236.000000
[21:22:00][D][sensor:094]: 'napiecie L2': Sending state 236.00000 V with 0 decimals of accuracy
[21:22:00][V][wmbus:121]: Publishing 'voltage_at_phase_3_v' = 229.0000
[21:22:00][V][sensor:043]: 'napiecie L3': Received new state 229.000000
[21:22:00][D][sensor:094]: 'napiecie L3': Sending state 229.00000 V with 0 decimals of accuracy
[21:22:00][W][component:214]: Component wmbus took a long time for an operation (0.52 s).
[21:22:00][W][component:215]: Components should block for at most 20-30ms.
[21:22:29][V][rxLoop:171]: Have 299 bytes from CC1101 Rx, RSSI: -51 dBm LQI: 128
[21:22:29][V][rxLoop:176]: Synchronus mode enabled.
[21:22:29][D][mbus:034]: Processing T1 A frame
[21:22:29][V][mbus:040]: Frame: 9B271C58D59A35994BB0B65A58D58EA6C2E34E66A5356996599C6CC8D59669635CD19C5C8F238E95C6B1D1A69A656656653666C5ACB458E6723729537324D37312F2D0D959B324F1725399B194CE95A39A666C654EC4E3959C4D96596365AD256746998E93A3C4D672CA634B5A5C9938B72C58D593A4B4E62D69B297138B396669674B347292D9D34B192CE4E99B495C2E338BC8D2DA4D3B252D92CE365B32696C666993A67193B24CB71935366CD1C38EB16A669A3B1A64D71C8DAC96D0D36638D7252F1D32D254 [RAW]
[21:22:29][V][mbus:042]: Frame: CB2D98D3B13C69C65A4B5A9A6CD0E974B0DA6C2E96AC2DA365D268E6656C5C4E34D939A4E698ED1A974C696744D93696713668E35ACB23D1C9994D3D0B69366597292998D3B13C69C65A4B5A9A6CD0E974B0DA6C2E96AC2DA365D268E6656C5C4E34D9 (299) [RAW]
[21:22:29][V][3of6:083]: Decode 3 out of 6 failed..
[21:22:29][W][component:214]: Component wmbus took a long time for an operation (0.10 s).
[21:22:29][W][component:215]: Components should block for at most 20-30ms.
[21:23:00][V][rxLoop:171]: Have 299 bytes from CC1101 Rx, RSSI: -52 dBm LQI: 128
[21:23:00][V][rxLoop:176]: Synchronus mode enabled.
[21:23:00][D][mbus:034]: Processing T1 A frame
[21:23:00][V][mbus:040]: Frame: 9B271C58D59A35994BB0B65A58D58EA6C2E34E66A6356996599B25B1AD1C38E39A8D3B2C4D6CACD31656D0D6939715937239B1C66D323A96A94CB699C99C56C56732729C723533A6B198E54E5D168EC59AB348CB59C3659722E68DCC4DC726B25936B4C934E6C569A9B194DC9638D62CD8CD69A953C5A9A32D68E3D3272C4F469334D9A5B29965A6CD0E2CE963731666B192EC95C725B2635398D65C6AC71C696A5C3B4B348D638E35A9535B42CEC5971C8E558B653A59996C992E5C8DC53C8BC9CC74C9CCA9D16D [RAW]
[21:23:00][V][mbus:042]: Frame: 0E9729A32E5599C5CA4D6593633B1696674B1359368E8CE2F165A5A9969A53A5967298DA5A5A32D35B2CA35B1396726C9C4F4965C8B8D94F42DA36C8E52DA4EC4F48E63563A5B1CD1695A3964ECD323696634EC8E5C4ED31A6970B58E98DD0D39C9A55 (299) [RAW]
[21:23:00][V][mbus:052]: Frame: AE440106159383560102F83B7A6A10A0058986C42226B78870E8CD50C1679D074BADDACE2F6F7365E5D0D04E4FDE172A85B979C0B8068CB304199E3AB4D1DE6E076CE77AD0AF85749BB031B16697D6AB30BBCE487C6711A98F99F8C2329B4D5A853894498A17A154684460F42C8CB02216970C32D544B90357F5A0E539E1D7E3E4DCE4EFC0C29EAB3905D4F1551B2D605C870762B23D560F9FF7F55EA1F60B370EEB0D204AE47C99E3B57C3618B936787CBA102984C0962078CE1F5B78B9D2CDFF4302A1C124A9 (199) [with CRC]
[21:23:00][V][mbus:095]: Validating CRC for Block1
[21:23:00][V][crc:031]: calculated: 0xF83B, read: 0xF83B
[21:23:00][V][mbus:115]: Validating CRC for Block2
[21:23:00][V][crc:031]: calculated: 0xC167, read: 0xC167
[21:23:00][V][mbus:115]: Validating CRC for Block3
[21:23:00][V][crc:031]: calculated: 0x172A, read: 0x172A
[21:23:00][V][mbus:115]: Validating CRC for Block4
[21:23:00][V][crc:031]: calculated: 0x076C, read: 0x076C
[21:23:00][V][mbus:115]: Validating CRC for Block5
[21:23:00][V][crc:031]: calculated: 0xCE48, read: 0xCE48
[21:23:00][V][mbus:115]: Validating CRC for Block6
[21:23:00][V][crc:031]: calculated: 0x8A17, read: 0x8A17
[21:23:00][V][mbus:115]: Validating CRC for Block7
[21:23:00][V][crc:031]: calculated: 0xB903, read: 0xB903
[21:23:00][V][mbus:115]: Validating CRC for Block8
[21:23:00][V][crc:031]: calculated: 0x3905, read: 0x3905
[21:23:00][V][mbus:115]: Validating CRC for Block9
[21:23:00][V][crc:031]: calculated: 0xF55E, read: 0xF55E
[21:23:00][V][mbus:115]: Validating CRC for Block10
[21:23:00][V][crc:031]: calculated: 0x18B9, read: 0x18B9
[21:23:00][V][mbus:115]: Validating CRC for Block11
[21:23:00][V][crc:031]: calculated: 0xD2CD, read: 0xD2CD
[21:23:00][V][mbus:115]: Validating CRC for Block12
[21:23:00][V][crc:031]: calculated: 0x24A9, read: 0x24A9
[21:23:00][V][mbus:062]: Frame: AE4401061593835601027A6A10A0058986C42226B78870E8CD509D074BADDACE2F6F7365E5D0D04E4FDE85B979C0B8068CB304199E3AB4D1DE6EE77AD0AF85749BB031B16697D6AB30BB7C6711A98F99F8C2329B4D5A85389449A154684460F42C8CB02216970C32D54457F5A0E539E1D7E3E4DCE4EFC0C29EABD4F1551B2D605C870762B23D560F9FF7A1F60B370EEB0D204AE47C99E3B57C3636787CBA102984C0962078CE1F5B78B9FF4302A1C1 (175) [without CRC]
[21:23:00][D][wmbus:097]: Using driver 'amiplus' for ID [0x56839315] RSSI: -52 dBm LQI: 128 Frame: T1 A T: AE4401061593835601027A6A10A0058986C42226B78870E8CD509D074BADDACE2F6F7365E5D0D04E4FDE85B979C0B8068CB304199E3AB4D1DE6EE77AD0AF85749BB031B16697D6AB30BB7C6711A98F99F8C2329B4D5A85389449A154684460F42C8CB02216970C32D54457F5A0E539E1D7E3E4DCE4EFC0C29EABD4F1551B2D605C870762B23D560F9FF7A1F60B370EEB0D204AE47C99E3B57C3636787CBA102984C0962078CE1F5B78B9FF4302A1C1 (175)
[21:23:00][V][utils:291]: 2F2F check after decrypting - OK
[21:23:00][D][wmbus:104]: Decrypted T : AE4401061593835601027A6A10A0052F2F066D8057151632400C78159383560E035711160000008E10031341070000008E20034470080000008E30030000000000008E8010030000000000000E833C6308000000008E10833C6308000000008E20833C0000000000008E30833C0000000000008E8010833C0000000000000B2B8201000AFDC9FC0134020AFDC9FC0236020AFDC9FC0328020BABC8FC100000002F2F2F2F2F2F2F2F2F2F2F2F2F2F2F (175)
[21:23:00][V][wmbus:121]: Publishing 'current_power_consumption_kw' = 0.1820
[21:23:00][V][sensor:043]: 'Current power consumption in kW': Received new state 0.182000
[21:23:00][D][sensor:094]: 'Current power consumption in kW': Sending state 0.18200 kW with 3 decimals of accuracy
[21:23:00][V][wmbus:121]: Publishing 'total_energy_consumption_kwh' = 161.1570
[21:23:00][V][sensor:043]: 'Consumption in kWh': Received new state 161.156998
[21:23:00][D][sensor:094]: 'Consumption in kWh': Sending state 161.15700 kWh with 3 decimals of accuracy
[21:23:00][V][wmbus:121]: Publishing 'total_energy_production_kwh' = 0.8630
[21:23:00][V][sensor:043]: 'Total energy production in kWh': Received new state 0.863000
[21:23:00][D][sensor:094]: 'Total energy production in kWh': Sending state 0.86300 kWh with 3 decimals of accuracy
[21:23:00][V][wmbus:121]: Publishing 'voltage_at_phase_1_v' = 234.0000
[21:23:00][V][sensor:043]: 'napiecie L1': Received new state 234.000000
[21:23:00][D][sensor:094]: 'napiecie L1': Sending state 234.00000 V with 0 decimals of accuracy
[21:23:00][V][wmbus:121]: Publishing 'voltage_at_phase_2_v' = 236.0000
[21:23:00][V][sensor:043]: 'napiecie L2': Received new state 236.000000
[21:23:00][D][sensor:094]: 'napiecie L2': Sending state 236.00000 V with 0 decimals of accuracy
[21:23:00][V][wmbus:121]: Publishing 'voltage_at_phase_3_v' = 228.0000
[21:23:00][V][sensor:043]: 'napiecie L3': Received new state 228.000000
[21:23:00][D][sensor:094]: 'napiecie L3': Sending state 228.00000 V with 0 decimals of accuracy
[21:23:00][W][component:214]: Component wmbus took a long time for an operation (0.53 s).
[21:23:00][W][component:215]: Components should block for at most 20-30ms.
Widzę, że większość ramek potrafi zdekodować (myślę, że z 60-70%)
Po kilku minutach procek z niewiadomego powodu się zresetował i przestał dekodować ramki:
[21:32:55][I][ota:117]: Boot seems successful, resetting boot loop counter.
[21:32:55][D][esp32.preferences:114]: Saving 1 preferences to flash...
[21:32:55][V][esp32.preferences:126]: sync: key: 233825507, len: 4
[21:32:55][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[21:32:59][V][rxLoop:171]: Have 299 bytes from CC1101 Rx, RSSI: -52 dBm LQI: 128
[21:32:59][V][rxLoop:176]: Synchronus mode enabled.
[21:32:59][D][mbus:034]: Processing T1 A frame
[21:32:59][V][mbus:040]: Frame: 9B271C58D59A35994BB0B65A58D58EA6C2E34E64E935699659994E665D267343713597262D9B29A65B1959A66C2DCC4BD328CBA564DA68B6A336965664BB234E3CB2D0B971CA6C74C6C3A5599D29CA5A69C93C6C95AA7239A5B4B2C8F2732C9638ED315937266B468B9632CEC4D36972938E6749666992ECD342DC39668D4CE959696963B266698E68CE64D2CD95658E693D1335934D39A2E9C8E2CD94E36C2F465A94B713A69D1AC4E70B719B3496969A3A9A658E9C74D134F18DC9534CB3A5669D2635938EA746 [RAW]
[21:32:59][V][mbus:042]: Frame: 968D3393353D0D4D35B471A9B1734A4B729A6965C95A5932F46B1B318D32F2B1A4E9D0ED0DC998D396CA63974C6C94B65A38EC53C71C53B1C9598CD4D9B0EB2626968D3393353D0D4D35B471A9B1734A4B729A6965C95A5932F46B1B318D32F2B1A4E9 (299) [RAW]
[21:32:59][V][3of6:083]: Decode 3 out of 6 failed..
[21:32:59][W][component:214]: Component wmbus took a long time for an operation (0.11 s).
[21:32:59][W][component:215]: Components should block for at most 20-30ms.
[21:34:59][V][rxLoop:171]: Have 299 bytes from CC1101 Rx, RSSI: -53 dBm LQI: 128
[21:34:59][V][rxLoop:176]: Synchronus mode enabled.
[21:34:59][D][mbus:034]: Processing T1 A frame
[21:34:59][V][mbus:040]: Frame: 9B271C58D59A35994BB0B65A58D58EA6C2E34E6B0B356996599B232D6C5C3A66A68D3B0E58E72CC8ED3469A953C93669725C7299C2CE713D2366C3594E3953C4DC962F2C4B3B23717328F12CD8D37318E98CED295992F27296724E3C71723972CB1C4D6B1363C63974CA3CA6D258E9B0BD1A5A93B4971C8E372696D26D1973298D8F44E6C4B6A5A4D9937298D6A7159370BD25D164E366C8CE732C4DC4B4F498DA6C70D2E6C598CDC5968BD259A6971B1A39C99999A2D98E34DA599C996AC372D19369693C5A3724 [RAW]
[21:34:59][V][mbus:042]: Frame: DA593C5C9A68E339A8F138D8DCC566A9C8D72566CD16D0B98E5A9B3498D2CEB322D64CBD3134D64D2DA672659C56C4D6533B26B24E53B1D325A54D67134DA39AD2C35A95C2ECD316968F134B8D3674B32CB49592DA59666C2CB3ACD32C994E366C4E4E (299) [RAW]
[21:34:59][V][3of6:075]: Decode 3 out of 6 failed.
Ale po kilku minutach zaczął znowu poprawnie działać chociaż już nie tak stabilnie. Pełny log wrzucam w pliku
logs_wmbus-reader_logs (3).zip (25.6 KB)
@_Szczepan Dzięki wielkie za Twoją pracę!
