Witajcie.
Mam problem z NR. Dokładnie chodzi o nod WaitUntil który powoduje zawieszenie NR i jego ponowne uruchomienie. Jak się domyślacie większość Flow nie działa prawidłowo. Światła nie gasna itp.
Załączam logi. Ma ktoś może jakiś pomysł?
Na forum dodatku NR cisza, na oficjalnym forum NR odsyłają do twórców dodatku.
Logi
7 Sep 12:02:38 - [info] Dashboard version 2.30.0 started at /endpoint/ui
/bin/sh: /opt/node_modules/node-red-node-pi-gpio/testgpio.py: not found
7 Sep 12:02:39 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
7 Sep 12:02:39 - [warn] ------------------------------------------------------
7 Sep 12:02:39 - [warn] [node-red-contrib-wled3/wled2] ‘wled2’ already registered by module node-red-contrib-wled2
7 Sep 12:02:39 - [info] Settings file : /etc/node-red/config.js
7 Sep 12:02:39 - [info] Context store : ‘default’ [module=memory]
7 Sep 12:02:39 - [info] User directory : /config/node-red/
7 Sep 12:02:39 - [warn] Projects disabled : editorTheme.projects.enabled=false
7 Sep 12:02:39 - [info] Flows file : /config/node-red/flows.json
7 Sep 12:02:39 - [info] Server now running at http://127.0.0.1:46836/
7 Sep 12:02:39 - [info] Starting flows
7 Sep 12:02:41 - [info] Started flows
7 Sep 12:02:41 - [info] [server:Home Assistant] Connecting to http://192.168.XX.XX:8123
7 Sep 12:02:41 - [info] [mqtt-broker:HA MQTT] Connected to broker: mqtt://192.168.XX.XX:1883
7 Sep 12:02:41 - [info] [server:Home Assistant] Connected to http://192.168.XX.XX:8123
7 Sep 12:02:44 - [error] [wled2:Wled] Unable to get state at startup: FetchError: request to http://192.168.XX.XX/json/state failed, reason: connect EHOSTUNREACH 192.168.XX.XX:80
7 Sep 12:23:39 - [red] Uncaught Exception:
7 Sep 12:23:39 - Error: Invalid property expression: zero-length
at createError (/opt/node_modules/@node-red/util/lib/util.js:184:13)
at normalisePropertyExpression (/opt/node_modules/@node-red/util/lib/util.js:212:15)
at Object.setObjectProperty (/opt/node_modules/@node-red/util/lib/util.js:457:24)
at WaitUntil$1.setContextValue (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/index.js:242:31)
at Timeout._onTimeout (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/index.js:6184:22)
at listOnTimeout (internal/timers.js:557:17)
at processTimers (internal/timers.js:500:7)
[12:23:40] INFO: Starting Node-RED…
Przykładowe Flow
[{"id":"44b2c64d.c4add8","type":"tab","label":"Schody","disabled":false,"info":""},{"id":"c2b6513e.135c3","type":"api-call-service","z":"44b2c64d.c4add8","name":"LED Schody ON","server":"439777edd11178a8","version":3,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.led_schody","data":"{\"entity_id\":\"light.led_schody\",\"brightness_pct\":80}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":560,"y":100,"wires":[["fa058bc066c52f4c"]],"icon":"node-red/light.svg"},{"id":"a651f799.fa31d8","type":"api-call-service","z":"44b2c64d.c4add8","name":"LED Schody OFF","server":"439777edd11178a8","version":3,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"light.led_schody","data":"","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":950,"y":100,"wires":[[]],"icon":"node-red/light.svg"},{"id":"79031530.18e32c","type":"server-state-changed","z":"44b2c64d.c4add8","name":"AL. Polpietro","server":"439777edd11178a8","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.czujka_schody","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":90,"y":280,"wires":[["53233779.cd3608"],[]]},{"id":"83ee56b3.d72408","type":"time-range-switch","z":"44b2c64d.c4add8","name":"","lat":"","lon":"","startTime":"22:00","endTime":"06:00","startOffset":0,"endOffset":0,"x":370,"y":260,"wires":[["47574f20.770dd"],[]]},{"id":"e2935d19.83ea3","type":"api-call-service","z":"44b2c64d.c4add8","name":"LED Schody ON","server":"439777edd11178a8","version":3,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.led_schody","data":"{\"entity_id\":\"light.led_schody\",\"brightness_pct\":30}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":340,"y":440,"wires":[["1e7cf788.f5cb58"]],"icon":"node-red/light.svg"},{"id":"69887972.0532e8","type":"api-call-service","z":"44b2c64d.c4add8","name":"LED Schody OFF","server":"439777edd11178a8","version":3,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"light.led_schody","data":"","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1010,"y":440,"wires":[[]],"icon":"node-red/light.svg"},{"id":"53233779.cd3608","type":"api-current-state","z":"44b2c64d.c4add8","name":"Jasnosc","server":"439777edd11178a8","version":2,"outputs":2,"halt_if":"1000","halt_if_type":"num","halt_if_compare":"lt","entity_id":"sensor.0_cfg_nightime","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":260,"y":340,"wires":[["933ac6b08b47cbaf","a103564c90ec2077","83ee56b3.d72408"],[]]},{"id":"1e7cf788.f5cb58","type":"ha-wait-until","z":"44b2c64d.c4add8","name":"Ruch salon","server":"439777edd11178a8","version":0,"outputs":2,"entityId":"binary_sensor.czujka_salon","entityIdFilterType":"exact","property":"state","comparator":"is","value":"on","valueType":"str","timeout":"30","timeoutType":"num","timeoutUnits":"seconds","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":550,"y":380,"wires":[["24d8849eae6452c7"],["2600303423838804"]]},{"id":"f161d7e1.524d88","type":"api-call-service","z":"44b2c64d.c4add8","name":"Sw. Wyspa ON","server":"439777edd11178a8","version":3,"debugenabled":false,"service_domain":"switch","service":"turn_on","entityId":"switch.multi_relay_0_8","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1000,"y":360,"wires":[["7922290.9d4b3d8"]]},{"id":"7922290.9d4b3d8","type":"ha-wait-until","z":"44b2c64d.c4add8","name":"Koniec ruchu","server":"439777edd11178a8","version":0,"outputs":2,"entityId":"binary_sensor.czujka_salon","entityIdFilterType":"exact","property":"state","comparator":"is","value":"off","valueType":"str","timeout":"10","timeoutType":"num","timeoutUnits":"minutes","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":1190,"y":360,"wires":[["a380d701.bd7808"],[]]},{"id":"a380d701.bd7808","type":"delay","z":"44b2c64d.c4add8","name":"","pauseType":"delay","timeout":"120","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"x":1390,"y":360,"wires":[["0248fbf17e173dc6","cf7e3ff0.766cc"]]},{"id":"cf7e3ff0.766cc","type":"api-call-service","z":"44b2c64d.c4add8","name":"Sw. Wyspa OFF","server":"439777edd11178a8","version":3,"debugenabled":false,"service_domain":"switch","service":"turn_off","entityId":"switch.multi_relay_0_8","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1620,"y":360,"wires":[[]]},{"id":"e87678ad.d98808","type":"api-call-service","z":"44b2c64d.c4add8","name":"LED Schody OFF","server":"439777edd11178a8","version":3,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"light.led_schody","data":"","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1550,"y":420,"wires":[[]],"icon":"node-red/light.svg"},{"id":"ae482490.2b1f58","type":"change","z":"44b2c64d.c4add8","name":"Reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1210,"y":300,"wires":[["a380d701.bd7808","2600303423838804"]]},{"id":"47574f20.770dd","type":"api-current-state","z":"44b2c64d.c4add8","name":"ON?","server":"439777edd11178a8","version":2,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.salon","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":550,"y":280,"wires":[["e2935d19.83ea3"],[]]},{"id":"f2b92bbb.1a56b8","type":"inject","z":"44b2c64d.c4add8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":790,"y":520,"wires":[["69887972.0532e8"]]},{"id":"fa058bc066c52f4c","type":"delay","z":"44b2c64d.c4add8","name":"","pauseType":"delay","timeout":"30","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"x":740,"y":100,"wires":[["a651f799.fa31d8"]]},{"id":"0248fbf17e173dc6","type":"delay","z":"44b2c64d.c4add8","name":"","pauseType":"delay","timeout":"10","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"x":1380,"y":420,"wires":[["e87678ad.d98808"]]},{"id":"2600303423838804","type":"delay","z":"44b2c64d.c4add8","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"x":780,"y":440,"wires":[["69887972.0532e8"]]},{"id":"d53a2570fd3550f0","type":"api-call-service","z":"44b2c64d.c4add8","name":"LED Schody ON","server":"439777edd11178a8","version":3,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.led_schody","data":"{\"entity_id\":\"light.led_schody\",\"brightness_pct\":50}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":560,"y":160,"wires":[["05e305a6d7c2e2ac"]],"icon":"node-red/light.svg"},{"id":"92650beeb19d1deb","type":"api-call-service","z":"44b2c64d.c4add8","name":"LED Schody OFF","server":"439777edd11178a8","version":3,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"light.led_schody","data":"","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":950,"y":160,"wires":[[]],"icon":"node-red/light.svg"},{"id":"05e305a6d7c2e2ac","type":"delay","z":"44b2c64d.c4add8","name":"","pauseType":"delay","timeout":"30","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"x":740,"y":160,"wires":[["92650beeb19d1deb"]]},{"id":"a103564c90ec2077","type":"time-range-switch","z":"44b2c64d.c4add8","name":"","lat":"","lon":"","startTime":"19:00","endTime":"22:00","startOffset":0,"endOffset":0,"x":370,"y":160,"wires":[["d53a2570fd3550f0"],[]]},{"id":"933ac6b08b47cbaf","type":"time-range-switch","z":"44b2c64d.c4add8","name":"","lat":"","lon":"","startTime":"15:00","endTime":"19:00","startOffset":0,"endOffset":0,"x":370,"y":100,"wires":[["c2b6513e.135c3"],[]]},{"id":"3b08c0d1474d8fc6","type":"time-range-switch","z":"44b2c64d.c4add8","name":"","lat":"","lon":"","startTime":"22:00","endTime":"06:00","startOffset":0,"endOffset":0,"x":970,"y":240,"wires":[["ae482490.2b1f58","7922290.9d4b3d8"],[]]},{"id":"bf8071dfa691a404","type":"server-state-changed","z":"44b2c64d.c4add8","name":"Ruch salon","server":"439777edd11178a8","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.czujka_salon","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":800,"y":240,"wires":[["3b08c0d1474d8fc6"],[]]},{"id":"24d8849eae6452c7","type":"api-current-state","z":"44b2c64d.c4add8","name":"Sw. Wyspa On/Off","server":"439777edd11178a8","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"switch.multi_relay_0_8","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":810,"y":360,"wires":[[],["f161d7e1.524d88"]]},{"id":"17b29145066fe9a6","type":"server-state-changed","z":"44b2c64d.c4add8","name":"Ruch dol","server":"439777edd11178a8","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.czujnik_ruchu_schody_dol","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":80,"y":340,"wires":[["53233779.cd3608","9c64ad5a7f828cb2"],[]]},{"id":"861aeb8876118478","type":"server-state-changed","z":"44b2c64d.c4add8","name":"Ruch gora","server":"439777edd11178a8","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.czujnik_ruchu_schody_gora","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":80,"y":400,"wires":[["53233779.cd3608","9c64ad5a7f828cb2"],[]]},{"id":"9c64ad5a7f828cb2","type":"change","z":"44b2c64d.c4add8","name":"Reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":170,"y":140,"wires":[["fa058bc066c52f4c","05e305a6d7c2e2ac"]]},{"id":"439777edd11178a8","type":"server","name":"Home Assistant","version":1,"legacy":false,"addon":false,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
Node-RED version: 10.0.0
Node.js version: 14.17.4
npm version:
Platform/OS: HA Supervisor
Browser: Opera, chrome
