opened 08:06PM - 06 Jul 22 UTC
problem in dependency
integration: opentherm_gw
### The problem
Integration is not working, log is flooded with errors, probabl…y due to the upgrade to Python 3.10
### What version of Home Assistant Core has the issue?
2022.7.0
### What was the last working version of Home Assistant Core?
2022.6.7
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
OpenTherm Gateway
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/opentherm_gw/
### Diagnostics information
_No response_
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
```txt
Error doing job: Exception in callback SerialTransport._read_ready()
File "/usr/local/lib/python3.10/asyncio/events.py", line 80, in _run
self._context.run(self._callback, *self._args)
File "/usr/local/lib/python3.10/site-packages/serial_asyncio/__init__.py", line 120, in _read_ready
self._protocol.data_received(data)
File "/usr/local/lib/python3.10/site-packages/pyotgw/protocol.py", line 95, in data_received
self._readbuf += data
AttributeError: 'protocol' object has no attribute '_readbuf'
### Additional information
_No response_
