14 Jan 22:11:21 - [info] Node-RED version: v3.0.2
14 Jan 22:11:21 - [info] Node.js version: v18.12.1
14 Jan 22:11:21 - [info] Linux 5.15.80 x64 LE
14 Jan 22:11:23 - [info] Loading palette nodes
14 Jan 22:11:27 - [info] Dashboard version 3.3.0 started at /endpoint/ui
14 Jan 22:11:27 - [info] Settings file : /etc/node-red/config.js
14 Jan 22:11:27 - [info] Context store : ‘default’ [module=memory]
14 Jan 22:11:28 - [info] User directory : /config/node-red/
14 Jan 22:11:28 - [warn] Projects disabled : editorTheme.projects.enabled=false
14 Jan 22:11:28 - [info] Flows file : /config/node-red/flows.json
14 Jan 22:11:28 - [warn] Encrypted credentials not found
14 Jan 22:11:28 - [info] Server now running at http://127.0.0.1:46836/
14 Jan 22:11:28 - [info] Starting flows
[22:11:28] INFO: Starting NGinx…
14 Jan 22:11:28 - [info] Started flows
14 Jan 22:11:33 - [info] [server:Home Assistant] Connecting to http://supervisor/core
14 Jan 22:11:33 - [info] [server:Home Assistant] Connected to http://supervisor/core
14 Jan 22:13:53 - [info] Installing module: node-red-contrib-weekday, version: 0.1.0
14 Jan 22:15:19 - [warn] Installation of module node-red-contrib-weekday failed:
14 Jan 22:15:19 - [warn] ------------------------------------------
14 Jan 22:15:19 - [warn] npm WARN config production Use --omit=dev instead.
npm ERR! code EAI_AGAIN
npm ERR! syscall getaddrinfo
npm ERR! errno EAI_AGAIN
npm ERR! request to https://registry.npmjs.org/node-red-contrib-weekday failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2023-01-14T21_13_54_422Z-debug-0.log
Error: Install failed
at /opt/node_modules/@node-red/registry/lib/installer.js:285:25
at processTicksAndRejections (node:internal/process/task_queues:95:5)
14 Jan 22:15:20 - [error] Error: Install failed
