Nie widzę co masz w środku ale musisz wszystkie po kolei sprawdzić i jak jest aktywne to dopisać do wiadomości
masz tu moje, najpierw sprawdzasz czy któreś śmieci są aktywne, a potem dodajesz do wiadomości po kolei jakie to są śmieci
[{"id":"f17c4f77.6cb36","type":"api-current-state","z":"2cdff75c.5c6178","name":"zmieszane","server":"4d0e02c9.2307bc","version":2,"outputs":2,"halt_if":"0","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.smieci_zmieszane","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":1190,"y":280,"wires":[["2953ad14.d534e2"],["b9a3a337.805a1"]]},{"id":"2953ad14.d534e2","type":"function","z":"2cdff75c.5c6178","name":"odpadów zmieszanych","func":"msg.wiadomosc = msg.wiadomosc+\n \"odpadów zmieszanych\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1390,"y":280,"wires":[["b9a3a337.805a1"]]},{"id":"b6ce1e2.4ccdce","type":"function","z":"2cdff75c.5c6178","name":"Śmieci dziś","func":"msg.wiadomosc = msg.wiadomosc+\n \" Przypominam, dziś jest wywóz śmieci\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1010,"y":280,"wires":[["f17c4f77.6cb36","6ea6494c.b7a898"]]},{"id":"b9a3a337.805a1","type":"api-current-state","z":"2cdff75c.5c6178","name":"Plastik","server":"4d0e02c9.2307bc","version":2,"outputs":2,"halt_if":"0","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.smieci_plastikowe","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":1210,"y":330,"wires":[["7d2d6ba0.47b294"],["7531f564.098d2c"]]},{"id":"7d2d6ba0.47b294","type":"function","z":"2cdff75c.5c6178","name":"plasiku","func":"msg.wiadomosc = msg.wiadomosc+\n \", plastików\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1350,"y":330,"wires":[["7531f564.098d2c"]]},{"id":"7531f564.098d2c","type":"api-current-state","z":"2cdff75c.5c6178","name":"papier","server":"4d0e02c9.2307bc","version":2,"outputs":2,"halt_if":"0","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.smieci_papier","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":1210,"y":370,"wires":[["1772b03f.c4e2f"],["c4be894e.373bd8"]]},{"id":"1772b03f.c4e2f","type":"function","z":"2cdff75c.5c6178","name":"papieru","func":"msg.wiadomosc = msg.wiadomosc+\n \", papieru\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1350,"y":370,"wires":[["c4be894e.373bd8"]]},{"id":"c4be894e.373bd8","type":"api-current-state","z":"2cdff75c.5c6178","name":"Szkło","server":"4d0e02c9.2307bc","version":2,"outputs":2,"halt_if":"0","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.smieci_szklo","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":1210,"y":410,"wires":[["63a47f61.6cbb"],["e7349680.7531d8"]]},{"id":"63a47f61.6cbb","type":"function","z":"2cdff75c.5c6178","name":"szkła","func":"msg.wiadomosc = msg.wiadomosc+\n \", szkła\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1340,"y":410,"wires":[["e7349680.7531d8"]]},{"id":"e7349680.7531d8","type":"api-current-state","z":"2cdff75c.5c6178","name":"Popiół","server":"4d0e02c9.2307bc","version":2,"outputs":2,"halt_if":"0","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.smieci_popiol","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":1210,"y":450,"wires":[["789b81f8.9db95"],["e3e81b21b176dd0c","48385daf.e5d1d4"]]},{"id":"789b81f8.9db95","type":"function","z":"2cdff75c.5c6178","name":"popiołu","func":"msg.wiadomosc = msg.wiadomosc+\n \", popiołu\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1350,"y":450,"wires":[["e3e81b21b176dd0c","48385daf.e5d1d4"]]},{"id":"1c0ce08e.71b47f","type":"api-current-state","z":"2cdff75c.5c6178","name":"zmieszane","server":"4d0e02c9.2307bc","version":2,"outputs":2,"halt_if":"0","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.smieci_zmieszane","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"zmieszane1","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":710,"y":280,"wires":[["b6ce1e2.4ccdce"],["ce56bec.a63074"]]},{"id":"992e50b7.48424","type":"api-current-state","z":"2cdff75c.5c6178","name":"papier","server":"4d0e02c9.2307bc","version":2,"outputs":2,"halt_if":"0","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.smieci_papier","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"papier1","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":690,"y":360,"wires":[["b6ce1e2.4ccdce"],["3d8b8372.15586c"]]},{"id":"3d8b8372.15586c","type":"api-current-state","z":"2cdff75c.5c6178","name":"Szkło","server":"4d0e02c9.2307bc","version":2,"outputs":2,"halt_if":"0","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.smieci_szklo","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"szklo1","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":690,"y":400,"wires":[["b6ce1e2.4ccdce"],["c4b71ec0.60879"]]},{"id":"c4b71ec0.60879","type":"api-current-state","z":"2cdff75c.5c6178","name":"Popiół","server":"4d0e02c9.2307bc","version":2,"outputs":2,"halt_if":"0","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.smieci_popiol","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"popiol1","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":690,"y":440,"wires":[["b6ce1e2.4ccdce"],["e3e81b21b176dd0c","48385daf.e5d1d4"]]},{"id":"ce56bec.a63074","type":"api-current-state","z":"2cdff75c.5c6178","name":"Śmieci textylia","server":"4d0e02c9.2307bc","version":2,"outputs":2,"halt_if":"0","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.smieci_plastikowe","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"plastik2","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"x":720,"y":320,"wires":[["b6ce1e2.4ccdce"],["992e50b7.48424"]]},{"id":"48385daf.e5d1d4","type":"function","z":"2cdff75c.5c6178","name":"KOMUNIKAT","func":"msg.komunikat =\n{\n \"data\":\n {\n \"message\": msg.wiadomosc,\n }\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":910,"y":520,"wires":[["c14565e4.0bfe78","8f8b1008.b1686","e19e8f72.89d5a","e742eefa.c4a05"]]},{"id":"4d0e02c9.2307bc","type":"server","name":"Asystent domowy","version":1,"legacy":false,"addon":false,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
