Dzięki za cierpliwość
Używałem już wcześniej wersji “Next” także. I tutaj bez sukcesów.
Dla testu podczas działania dodatku wypiąłem tuner z USB - wysypało błędy i dodatek się wyłączył. Podłączyłem dongla (to samo USB), restart dodatku (w wersji Next) i DZIAŁA!
Starting rtl_433 with rtl_433.conf...
[rtl_433] rtl_433 version 23.11-131-ge67969a2 branch master at 202406100043 inputs file rtl_tcp RTL-SDR
[rtl_433] MQTT: Publishing MQTT data to core-mosquitto port 1883
[rtl_433] MQTT: Publishing device info to MQTT topic "rtl_433/9b13b3f4-rtl433/devices[/type][/model][/subtype][/channel][/id]".
[rtl_433] MQTT: Publishing events info to MQTT topic "rtl_433/9b13b3f4-rtl433/events".
[rtl_433] MQTT: Publishing states info to MQTT topic "rtl_433/9b13b3f4-rtl433/states".
[rtl_433] [Protocols] Registered 3 out of 258 device decoding protocols
[rtl_433]
[rtl_433] [Input] The internals of input handling changed, read about and report problems on PR #1978
[rtl_433] New defaults active, use "-Y classic -s 250k" if you need the old defaults
[rtl_433]
[rtl_433] Registering protocol [55] "Acurite 606TX Temperature Sensor"
[rtl_433] Registering protocol [119] "Bresser Weather Center 5-in-1"
[rtl_433] Registering protocol [172] "Bresser Weather Center 6-in-1, 7-in-1 indoor, soil, new 5-in-1, 3-in-1 wind gauge, Froggit WH6000, Ventus C8488A"
[rtl_433] [SDR] Found 1 device(s)
[rtl_433] [SDR] trying device 0: Realtek, RTL2838UHIDIR, SN: 00000001
[rtl_433] Found Fitipower FC0012 tuner
[rtl_433] [SDR] Using device 0: Realtek, RTL2838UHIDIR, SN: 00000001, "Generic RTL2832U OEM"
[rtl_433] [SDR] Sample rate set to 1024000 S/s.
[rtl_433] [Input] Bit detection level set to 0.0 (Auto).
[rtl_433] [SDR] Tuner gain set to Auto.
[rtl_433] [Input] Reading samples in async mode...
[rtl_433] [SDR] rtlsdr_set_center_freq 433920000 = 0
[rtl_433] [SDR] Tuned to 433.920MHz.
[rtl_433] [acquire_thread] acquire_thread enter...
[rtl_433] [MQTT] MQTT Connected...
[rtl_433] [MQTT] MQTT Connection established.
[rtl_433] [Baseband] low pass filter for 1024000 Hz at cutoff 102400 Hz, 9.8 us
[rtl_433] [pulse_slicer_ppm] Acurite 606TX Temperature Sensor
[rtl_433] codes : {24}000000
[rtl_433] codes : {21}401040
[rtl_433] [SDR] rtlsdr_set_center_freq 868000000 = 0
[rtl_433] [SDR] Tuned to 868.000MHz.
[rtl_433] [pulse_slicer_pcm] Exact bit width (in us) is 121.73 vs 123.05, 46 bit preamble
[rtl_433] [bresser_5in1_decode] bit_per_row 215 out of range
[rtl_433] [pulse_slicer_pcm] Bresser Weather Center 5-in-1
[rtl_433] codes : {215}55555555555516ea615784220c390c7fffff92c47ffff6ff80be54
[rtl_433] [bresser_6in1_decode]
[rtl_433] codes : {144}c2af0844187218ffffff2588ffffedff017c
[rtl_433] {"time" : "2024-06-11 00:02:20", "model" : "Bresser-6in1", "id" : 138680434, "channel" : 0, "sensor_type" : 1, "wind_max_m_s" : 0.000, "wind_avg_m_s" : 0.000, "wind_dir_deg" : 258, "rain_mm" : 1.200, "startup" : 1, "flags" : 1, "mic" : "CRC"}
[rtl_433] _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
[rtl_433] time : 2024-06-11 00:02:20
[rtl_433] model : Bresser-6in1 id : 08441872
[rtl_433] channel : 0 Sensor type: 1 Wind Gust : 0.0 m/s Wind Speed: 0.0 m/s Direction : 258 Rain : 1.2 mm Startup : 1 Flags : 1 Integrity : CRC
[rtl_433] [pulse_slicer_pcm] Bresser Weather Center 6-in-1, 7-in-1 indoor, soil, new 5-in-1, 3-in-1 wind gauge, Froggit WH6000, Ventus C8488A
[rtl_433] [pulse_slicer_pcm] Exact bit width (in us) is 122.34 vs 123.05, 18 bit preamble
[rtl_433] [bresser_5in1_decode] bit_per_row 164 out of range
[rtl_433] codes : {164}aaaab33333332b4cad2b4d4accd334d4cd52b4b32
[rtl_433] [pulse_slicer_pcm] Exact bit width (in us) is 122.29 vs 123.05, 18 bit preamble
[rtl_433] codes : {164}aaaab33333332b32cacb54ab2ad3552ad534d5332
[rtl_433] codes : {164}aaaab33333332b4b34b2b32d4d2d2d4cb35335534
[rtl_433] [pulse_slicer_pcm] Exact bit width (in us) is 122.50 vs 123.05, 18 bit preamble
[rtl_433] codes : {164}aaaab33333332b552acab32b2cd34cb5532d3532a
[rtl_433] codes : {164}aaaab33333332ab2cd2b52d34b2b2ab532d552b52
[rtl_433] [pulse_slicer_pcm] Exact bit width (in us) is 121.71 vs 123.05, 46 bit preamble
[rtl_433] [bresser_5in1_decode] bit_per_row 205 out of range
[rtl_433] codes : {205}55555555555516ea3e5184220c39ffffffff10472cabffe0d550
[rtl_433] [bresser_6in1_decode] 140 too short
Mam informacje w mqtt explorerze (wykryta jako Bresser 6in1)
Odpalam rtl_433 auto discovery Next i dane w mqtt:
@szopen królu złoty! Wiszę Ci piwo albo kawę!
