Cześć, Mam kilka liczników Bmeters. Większość odczytuje mi prawidłowo, ale przy kilku mam komunikat:
2F2F check after decrypting
Czy mogę coś z tym zrobić - jeżeli liczniki wraz z nakładkami kupiłem jako używki z różnych źródeł ?
Log poniżej: (pierwszy ok - pozostałe brak odczytu :()
12:30:17][D][wmbus:097]: Using driver 'bmeters' for ID [0x17034869] RSSI: -61 dBm LQI: 128 Frame: T1 A T: 4E44B4096948031713077A39004005F0AB8BD0FAD1A5BA733285EFC2C9E9D927B848A443D1FF7748A6AD555BEABDA7A67D359A4960E1D5AE7EB09D4CF5B596445730867ACEF25B3A0090C1EF46805C (79)
[12:30:17][D][wmbus:104]: Decrypted T : 4E44B4096948031713077A390040052F2F0C1393642800046D042E2D310F153E050000006066003A6700E867009A6800436900AC6900276B008B6C001C6D00696D00296E00666F00002F2F2F2F2F2F (79)
[12:30:17][D][sensor:094]: '34 Cold water': Sending state 286.49301 m³ with 3 decimals of accuracy
[12:30:17][W][component:237]: Component wmbus took a long time for an operation (68 ms).
[12:30:17][W][component:238]: Components should block for at most 30 ms.
[12:30:31][D][mbus:034]: Processing T1 A frame
[12:30:31][D][wmbus:097]: Using driver 'bmeters' for ID [0x13068924] RSSI: -44 dBm LQI: 128 Frame: T1 A T: 4944B4092489061305077A940806100F6785E74EC20F1F5E242A01010000005137141301254A51004C51004D51004E5100535100545100775100AB5100AB5100AB5100AB5100AB510000 (74)
[12:30:31][D][utils:294]: 2F2F check after decrypting !!!
[12:30:33][D][mbus:034]: Processing T1 A frame
[12:30:33][D][wmbus:097]: Using driver 'bmeters' for ID [0x15195681] RSSI: -53 dBm LQI: 128 Frame: T1 A T: 4644B4098156191505077AEB0006108E678168BF760F1D3E00000000004414130125884400A24400644500EE4500F84500F84500F84500FA4500214600794600E646005B470000 (71)
[12:30:33][D][utils:294]: 2F2F check after decrypting !!!
[12:30:50][D][mbus:034]: Processing T1 A frame
[12:30:50][D][wmbus:097]: Using driver 'bmeters' for ID [0x12033695] RSSI: -48 dBm LQI: 128 Frame: T1 A T: 3C44B4099536031202077A8B000610EE07C732C5160F116E9C07008E04008E04008E04008E04008E04008E04008E04008E0400FF0400C7050043060000 (61)
[12:30:50][D][utils:294]: 2F2F check after decrypting !!!
[12:30:55][D][mbus:034]: Processing T1 A frame
