dobra, masz na brudno:
[{"id":"a1f43d5a7dc68b6d","type":"server-state-changed","z":"fb7ad2d6d88b2fd4","name":"czujnik drzwi","server":"4d0e02c9.2307bc","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":330,"y":1160,"wires":[["c37286a5d2a81d40"],[]]},{"id":"fc90ffc1421d23c3","type":"change","z":"fb7ad2d6d88b2fd4","name":"aktywnyalarm true","rules":[{"t":"set","p":"aktywnyalarm","pt":"global","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":1040,"wires":[[]]},{"id":"c37286a5d2a81d40","type":"switch","z":"fb7ad2d6d88b2fd4","name":"czy alarm aktywny","property":"aktywnyalarm","propertyType":"global","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":570,"y":1160,"wires":[["55fecf1b02b7fa32"]]},{"id":"55dc641c0ab02ad0","type":"api-call-service","z":"fb7ad2d6d88b2fd4","name":"wlacz syrene","server":"4d0e02c9.2307bc","version":3,"debugenabled":false,"service_domain":"","service":"","entityId":"","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1150,"y":1160,"wires":[[]]},{"id":"f3103911e8cd6465","type":"change","z":"fb7ad2d6d88b2fd4","name":"aktywnyalarm false","rules":[{"t":"set","p":"aktywnyalarm","pt":"global","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":1080,"wires":[[]]},{"id":"b2ebd5107026346a","type":"server-state-changed","z":"fb7ad2d6d88b2fd4","name":"group.person","server":"4d0e02c9.2307bc","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"false","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":330,"y":1060,"wires":[["fc90ffc1421d23c3"],["f3103911e8cd6465"]]},{"id":"55fecf1b02b7fa32","type":"api-current-state","z":"fb7ad2d6d88b2fd4","name":"pomocnik - aktywna automatyzacja alarmu","server":"4d0e02c9.2307bc","version":2,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":870,"y":1160,"wires":[["55dc641c0ab02ad0"],[]]},{"id":"4d0e02c9.2307bc","type":"server","name":"Asystent domowy","version":1,"legacy":false,"addon":false,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
czyli zadzwoni jak sa spelnione 2 warunki nikogo nie ma w domu i pomocnik jest wlaczony, jak go recznie wylaczysz to nie bedzie dzwonic, az znowu go wlaczysz
