Dziękuje za pomoc, ruszyło, wystarczy ten okrojony kod nawet bez ID, problemem był okres telemetrii, który trzeba ustawić na 300s, jutro spróbuje z tymi osmioma czujnikami
Rule1 ON DS18B20#Temperature>%var1% DO Backlog var1 %value%; Publish tele/%topic%/SENSOR {"Time":"%timestamp%","DS18B20":{"Temperature":%value%}}; var2 %value%; add1 0.2; sub2 0.2 ENDON
Rule1 + ON DS18B20#Temperature<%var2% DO Backlog var2 %value%; Publish tele/%topic%/SENSOR {"Time":"%timestamp%","DS18B20":{"Temperature":%value%}}; var1 %value%; add1 0.2; sub2 0.2 ENDON
Rule1 1
Dla innych:
w przypadku jak poniżej ![]()
Rule1 ON DS18B20-1#Temperature>%var1% DO Backlog var1 %value%; Publish tele/%topic%/SENSOR {"Time":"%timestamp%","DS18B20-1":{"Temperature":%value%}}; var2 %value%; add1 0.4; sub2 0.4 ENDON
Rule1 + ON DS18B20-1#Temperature<%var2% DO Backlog var2 %value%; Publish tele/%topic%/SENSOR {"Time":"%timestamp%","DS18B20-1":{"Temperature":%value%}}; var1 %value%; add1 0.4; sub2 0.4 ENDON
Rule1 + ON DS18B20-2#Temperature>%var3% DO Backlog var3 %value%; Publish tele/%topic%/SENSOR {"Time":"%timestamp%","DS18B20-2":{"Temperature":%value%}}; var4 %value%; add3 0.4; sub4 0.4 ENDON
Rule1 + ON DS18B20-2#Temperature<%var4% DO Backlog var4 %value%; Publish tele/%topic%/SENSOR {"Time":"%timestamp%","DS18B20-2":{"Temperature":%value%}}; var3 %value%; add3 0.4; sub4 0.4 ENDON
Rule1 + ON DS18B20-3#Temperature>%var5% DO Backlog var5 %value%; Publish tele/%topic%/SENSOR {"Time":"%timestamp%","DS18B20-3":{"Temperature":%value%}}; var6 %value%; add5 0.4; sub6 0.4 ENDON
Rule1 + ON DS18B20-3#Temperature<%var6% DO Backlog var6 %value%; Publish tele/%topic%/SENSOR {"Time":"%timestamp%","DS18B20-3":{"Temperature":%value%}}; var5 %value%; add5 0.4; sub6 0.4 ENDON
Rule2 + ON DS18B20-4#Temperature>%var7% DO Backlog var7 %value%; Publish tele/%topic%/SENSOR {"Time":"%timestamp%","DS18B20-4":{"Temperature":%value%}}; var8 %value%; add7 0.4; sub8 0.4 ENDON
Rule2 + ON DS18B20-4#Temperature<%var8% DO Backlog var8 %value%; Publish tele/%topic%/SENSOR {"Time":"%timestamp%","DS18B20-4":{"Temperature":%value%}}; var7 %value%; add7 0.4; sub8 0.4 ENDON
Rule2 + ON DS18B20-5#Temperature>%var9% DO Backlog var9 %value%; Publish tele/%topic%/SENSOR {"Time":"%timestamp%","DS18B20-5":{"Temperature":%value%}}; var10 %value%; add9 0.4; sub10 0.4 ENDON
Rule2 + ON DS18B20-5#Temperature<%var10% DO Backlog var10 %value%; Publish tele/%topic%/SENSOR {"Time":"%timestamp%","DS18B20-5":{"Temperature":%value%}}; var9 %value%; add9 0.4; sub10 0.4 ENDON
Rule2 + ON DS18B20-6#Temperature>%var11% DO Backlog var11 %value%; Publish tele/%topic%/SENSOR {"Time":"%timestamp%","DS18B20-6":{"Temperature":%value%}}; var12 %value%; add11 0.4; sub12 0.4 ENDON
Rule2 + ON DS18B20-6#Temperature<%var12% DO Backlog var12 %value%; Publish tele/%topic%/SENSOR {"Time":"%timestamp%","DS18B20-6":{"Temperature":%value%}}; var11 %value%; add11 0.4; sub12 0.4 ENDON
Rule3 + ON DS18B20-7#Temperature>%var13% DO Backlog var13 %value%; Publish tele/%topic%/SENSOR {"Time":"%timestamp%","DS18B20-7":{"Temperature":%value%}}; var14 %value%; add13 0.4; sub14 0.4 ENDON
Rule3 + ON DS18B20-7#Temperature<%var14% DO Backlog var14 %value%; Publish tele/%topic%/SENSOR {"Time":"%timestamp%","DS18B20-7":{"Temperature":%value%}}; var13 %value%; add13 0.4; sub14 0.4 ENDON
Rule3 + ON DS18B20-8#Temperature>%var15% DO Backlog var15 %value%; Publish tele/%topic%/SENSOR {"Time":"%timestamp%","DS18B20-8":{"Temperature":%value%}}; var16 %value%; add15 0.4; sub16 0.4 ENDON
Rule3 + ON DS18B20-8#Temperature<%var16% DO Backlog var16 %value%; Publish tele/%topic%/SENSOR {"Time":"%timestamp%","DS18B20-8":{"Temperature":%value%}}; var15 %value%; add15 0.4; sub16 0.4 ENDON
Rule1 1
Rule2 1
Rule3 1
w powyższym przypadku tamnosta wysyła mi tylko power i za chiny nie wiem jak ugyźć wysyłanie pozostałych parmaterów. Pomożesz?
moja paczka danych, jak podstawiam w jednel linijce pozostałe parametry, to wszystkie się zastępują jednym - z power i w rezultacie mam 2500Watt i 2500V itd
, jak robiłem kolejny z nazwą ENERGY to na przemiennie się wyświetlały, czyli coś się krzaczy
12:41:31.198 MQT: tele/Express_Kuchnia/SENSOR = {"Time":"2022-03-20T12:41:31","ENERGY":{"TotalStartTime":"2021-09-23T20:49:23","Total":102.269,"Yesterday":0.698,"Today":0.319,"Period":0,"Power":3,"ApparentPower":21,"ReactivePower":20,"Factor":0.13,"Voltage":250,"Current":0.082}}
