CC1101 + szczepanleon + ESP32C3 + Apator162
Wracam do tematu po latach :wink:
Wszystko działało przez długi czas dopóki nie zacząłem aktualizować. Teraz odbieram ramki ale ESPHome ich nie dekoduje.
Mój yaml:
substitutions:
  devicename: "esp32-c3-sm-07"
  upper_devicename: "Wodomierz"
  friendly_name: $upper_devicename
  board: esp32-c3-devkitm-1
    type: arduino
# Enable logging
# Enable Home Assistant API
  - platform: esphome
# Enable Web server
web_server:
  port: 80
  ssid: !secret wifi_ssid
  fast_connect: on
  manual_ip:
    # Set this to the IP of the ESP
    static_ip: 192.168.1.251
    # Set this to the IP address of the router. Often ends with .1
    gateway: 192.168.1.1
    # The subnet of the network. 255.255.255.0 works for most home networks.
    subnet: 255.255.255.0
captive_portal:
binary_sensor:
  - platform: status
    name: "${upper_devicename} - Status"
    device_class: connectivity
time:
  - platform: homeassistant
external_components:
# 🔴 WMBUS (stary, działający styl)
wmbus:
  mosi_pin: GPIO5
  miso_pin: GPIO7
  clk_pin: GPIO6
  cs_pin: GPIO21
  gdo0_pin: GPIO20
  frequency: 868.950
  log_all: True
  sync_mode: True
# 🔴 SENSORY
  - platform: wmbus
    meter_id: 0x00473662
    type: apator
    sensors:
      - name: "Wodomierz - Woda"
        field: total
        accuracy_decimals: 3
        unit_of_measurement: "m³"
        device_class: water
        state_class: total_increasing
      - name: "Wodomierz - RSSI"
        field: rssi
        accuracy_decimals: 0
        unit_of_measurement: "dBm"
        device_class: signal_strength
        state_class: measurement
        entity_category: diagnostic
  - platform: wifi_signal
    name: "${upper_devicename} - Wifi Signal"
    update_interval: 60s
  - platform: uptime
    name: "${upper_devicename} - Uptime"
log:
\[21:34:20.064\]\[S\]\[sensor\]: 'Wodomierz - Wifi Signal' >> -81 dBm
\[21:34:20.123\]\[D\]\[packet:097\]: Have data from radio (8 bytes)
\[21:34:20.157\]\[D\]\[wmbusmeters:351\]: raw packet "2049002605B35A30"
\[21:34:34.473\]\[D\]\[packet:097\]: Have data from radio (8 bytes)
\[21:34:34.474\]\[D\]\[wmbusmeters:351\]: raw packet "73273C58D59A5937"
\[21:34:40.990\]\[D\]\[packet:097\]: Have data from radio (137 bytes)
\[21:34:40.992\]\[D\]\[wmbusmeters:351\]: raw packet "73271C58D59A4D958B4DA58E5995936698E64E634D596716B198D698B2EC723B3A6A32CD969D9AD992E6671999D1EC9C4F264D6B1C96C4B596689CA73A69CB2DCB13CD74CE6B92F4661C737367E558DC8D9743987165B26B297E2D939368BB8DB2639C2D395A9A9671CDAB2D727D6C693D0D74EA65354AE9374356CD3C965936DA70EB2CCD6C7A76C5"
\[21:34:40.995\]\[D\]\[wmbusmeters:351\]: (wmbus) trimming frame A "73271C58D59A4D958B4DA58E5995936698E64E634D596716B198D698B2EC723B3A6A32CD969D9AD992E6671999D1EC9C4F264D6B1C96C4B596689CA73A69CB2DCB13CD74CE6B92F4661C737367E558DC8D9743987165B26B297E2D939368BB8DB2639C2D395A9A9671CDAB2D727D6C693D0D74EA65354AE9374356CD3C965936DA70EB2CCD6C7A76C5"
\[21:34:40.996\]\[W\]\[CC1101:318\]**\[radio_recv\]**: RX timeout after 0 bytes (need 3)
\[21:34:45.573\]\[D\]\[packet:097\]: Have data from radio (8 bytes)
Czy mogę zgadywać, że chodzi o kwietniową aktualizację ESPHome?
Nie mam pojęcia o co chodzi. Kupiłem nową maszynę pod HA i tak na niej śmigają aktualizacje że postanowiłem zaktualizować wszystko. I tu się zrobiły kłopoty. Już nie wiem co jest źle. Starego yamla nie zatrzymałem i rzeźbię teraz różne. Wyczytałem że przy szczepanleon@main nie obsługuje CC1101. W związku z tym wróciłem do v4. Ten z kolei nie dekoduje ramek. ChatGPT majaczy. Wymiękam. Nie wiem czy to wina ESPHome ale to może być trop.
P. S.
Żeby zadziałało tak jak teraz trzeba było zmienić (chyba fork) na arduino. Wówczas przestał brzęczeć że nie ma (chyba) sterowników do CC1101
