### What happened?
I bought and added a Tuya Zigbee Temperature and humidity …sensor with clock device to my Z2M instance and it is displayed the expected values:
The problem is that, if I try to change some of the settings (see screenshot) the changes are not applied and the default values are displayed again
### What did you expect to happen?
N/A
### How to reproduce it (minimal and precise)
N/A
### Zigbee2MQTT version
1.30.1-dev commit: fec7fca
### Adapter firmware version
7.2.0.0 build 108
### Adapter
Zigbee Model TS0601 Zigbee Manufacturer _TZE200_locansqn
### Debug log
Debug 2023-05-08 14:58:00Received MQTT message on 'zigbee2mqtt/Nous Temp Quarto Pais/set' with data '{"temperature_report_interval":5}'
Debug 2023-05-08 14:58:00Publishing 'set' 'temperature_report_interval' to 'Nous Temp Quarto Pais'
Debug 2023-05-08 14:58:01Received MQTT message on 'zigbee2mqtt/Nous Temp Quarto Pais/set' with data '{"humidity_report_interval":120}'
Debug 2023-05-08 14:58:01Publishing 'set' 'humidity_report_interval' to 'Nous Temp Quarto Pais'
Debug 2023-05-08 14:58:01Received MQTT message on 'zigbee2mqtt/Nous Temp Quarto Pais/set' with data '{"humidity_report_interval":10}'
Debug 2023-05-08 15:01:02Received MQTT message on 'zigbee2mqtt/Nous Temp Quarto Pais/set' with data '{"temperature_report_interval":5}'
Debug 2023-05-08 15:01:02Publishing 'set' 'temperature_report_interval' to 'Nous Temp Quarto Pais'
Debug 2023-05-08 15:01:08Received MQTT message on 'zigbee2mqtt/Nous Temp Quarto Pais/set' with data '{"temperature_report_interval":5}'
Debug 2023-05-08 15:01:08Publishing 'set' 'temperature_report_interval' to 'Nous Temp Quarto Pais'
Debug 2023-05-08 15:01:58Received Zigbee message from 'Nous Temp Quarto Pais', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0],"type":"Buffer"},"datatype":4,"dp":9}],"seq":43008}' from endpoint 1 with groupID 0
Info 2023-05-08 15:01:58MQTT publish: topic 'zigbee2mqtt/Nous Temp Quarto Pais', payload '{"battery":18,"humidity":64,"humidity_alarm":"upper_alarm","humidity_report_interval":120,"humidity_sensitivity":6,"linkquality":196,"max_humidity":60,"max_temperature":39,"min_humidity":20,"min_temperature":0,"temperature":20.1,"temperature_alarm":null,"temperature_report_interval":120,"temperature_sensitivity":0.6,"temperature_unit_convert":"celsius"}'
Debug 2023-05-08 15:01:58Received Zigbee message from 'Nous Temp Quarto Pais', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,1,134],"type":"Buffer"},"datatype":2,"dp":10}],"seq":43264}' from endpoint 1 with groupID 0
Debug 2023-05-08 15:01:58Received Zigbee message from 'Nous Temp Quarto Pais', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,0],"type":"Buffer"},"datatype":2,"dp":11}],"seq":43520}' from endpoint 1 with groupID 0
Debug 2023-05-08 15:01:58Received Zigbee message from 'Nous Temp Quarto Pais', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,60],"type":"Buffer"},"datatype":2,"dp":12}],"seq":43776}' from endpoint 1 with groupID 0
Debug 2023-05-08 15:01:58Received Zigbee message from 'Nous Temp Quarto Pais', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,20],"type":"Buffer"},"datatype":2,"dp":13}],"seq":44032}' from endpoint 1 with groupID 0
Debug 2023-05-08 15:01:58Received Zigbee message from 'Nous Temp Quarto Pais', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,120],"type":"Buffer"},"datatype":2,"dp":17}],"seq":44288}' from endpoint 1 with groupID 0
Debug 2023-05-08 15:01:59Received Zigbee message from 'Nous Temp Quarto Pais', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,120],"type":"Buffer"},"datatype":2,"dp":18}],"seq":44544}' from endpoint 1 with groupID 0
Info 2023-05-08 15:01:59MQTT publish: topic 'zigbee2mqtt/Nous Temp Quarto Pais', payload '{"battery":18,"humidity":64,"humidity_alarm":"upper_alarm","humidity_report_interval":120,"humidity_sensitivity":6,"linkquality":196,"max_humidity":60,"max_temperature":39,"min_humidity":20,"min_temperature":0,"temperature":20.1,"temperature_alarm":null,"temperature_report_interval":120,"temperature_sensitivity":0.6,"temperature_unit_convert":"celsius"}'
Debug 2023-05-08 15:01:59Received Zigbee message from 'Nous Temp Quarto Pais', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,6],"type":"Buffer"},"datatype":2,"dp":19}],"seq":44800}' from endpoint 1 with groupID 0
Debug 2023-05-08 15:01:59Received Zigbee message from 'Nous Temp Quarto Pais', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,6],"type":"Buffer"},"datatype":2,"dp":20}],"seq":45056}' from endpoint 1 with groupID 0
Debug 2023-05-08 15:01:59Received Zigbee message from 'Nous Temp Quarto Pais', type 'commandMcuSyncTime', cluster 'manuSpecificTuya', data '{"payloadSize":177}' from endpoint 1 with groupID 0
Debug 2023-05-08 15:01:59Received Zigbee message from 'Nous Temp Quarto Pais', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,201],"type":"Buffer"},"datatype":2,"dp":1}],"seq":45568}' from endpoint 1 with groupID 0
Debug 2023-05-08 15:01:59Received Zigbee message from 'Nous Temp Quarto Pais', type 'commandDataReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[0,0,0,63],"type":"Buffer"},"datatype":2,"dp":2}],"seq":45824}' from endpoint 1 with groupID 0
Info 2023-05-08 15:01:59MQTT publish: topic 'zigbee2mqtt/Nous Temp Quarto Pais', payload '{"battery":18,"humidity":63,"humidity_alarm":"upper_alarm","humidity_report_interval":120,"humidity_sensitivity":6,"linkquality":196,"max_humidity":60,"max_temperature":39,"min_humidity":20,"min_temperature":0,"temperature":20.1,"temperature_alarm":null,"temperature_report_interval":120,"temperature_sensitivity":0.6,"temperature_unit_convert":"celsius"}'
Debug 2023-05-08 15:02:00Received Zigbee message from 'Nous Temp Quarto Pais', type 'commandMcuSyncTime', cluster 'manuSpecificTuya', data '{"payloadSize":181}' from endpoint 1 with groupID 0
