Hej,
Od dłuższego czasu nie zaglądałem do HA, bo skoro działa to co chciałem, to po co zmieniać.
Niestety po ok 2 latach świat HA poszedł mocno do przodu i zaczęło sypać błędami. Ignorowałem je do czasu gdy HA nie chce się dać zrestartować ze względu na błędy, a dokładniej:
Invalid config for [tts.google_translate]: [base_url] is an invalid option for [tts.google_translate]. Check: tts.google_translate->base_url. (See /config/configuration.yaml, line 13). Please check the docs at https://www.home-assistant.io/integrations/google_translate
Generalnie ilośc błędów i ostrzerzeń jest mega długa, czy ktoś zachciałby mi pomóc to ogarnąć?
Tu pełny log ![]()
2023-10-10 22:04:31.470 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-10-10 22:04:31.473 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration burze_dzis_net which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-10-10 22:04:31.476 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-10-10 22:04:36.099 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2023-10-10 22:04:36.168 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=192 from 2023-09-11 07:53:09.329178)
2023-10-10 22:04:42.624 ERROR (MainThread) [homeassistant.components.binary_sensor] The burze_dzis_net platform for the binary_sensor integration does not support platform setup. Please remove it from your config.
2023-10-10 22:04:42.727 ERROR (MainThread) [homeassistant.config] Invalid config for [tts.google_translate]: [base_url] is an invalid option for [tts.google_translate]. Check: tts.google_translate->base_url. (See /config/configuration.yaml, line 13). Please check the docs at https://www.home-assistant.io/integrations/google_translate
2023-10-10 22:04:47.636 ERROR (MainThread) [homeassistant.components.sensor] The waze_travel_time platform for the sensor integration does not support platform setup. Please remove it from your config.
2023-10-10 22:04:47.638 ERROR (MainThread) [homeassistant.components.sensor] The waze_travel_time platform for the sensor integration does not support platform setup. Please remove it from your config.
2023-10-10 22:04:54.667 ERROR (MainThread) [homeassistant.components.remote] The broadlink platform for the remote integration does not support platform setup. Please remove it from your config.
2023-10-10 22:05:00.207 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Tv salon' for androidtv_remote integration not ready yet: Couldn't connect to 192.168.0.153:6466; Retrying in background
2023-10-10 22:05:00.212 WARNING (MainThread) [homeassistant.config_entries] Config entry 'MIBOX4 Sypialnia' for androidtv_remote integration not ready yet: Couldn't connect to 192.168.0.229:6466; Retrying in background
2023-10-10 22:05:00.830 WARNING (MainThread) [homeassistant.components.mqtt.mixins] MQTT entity name starts with the device name in your config {'availability': [{'topic': 'zigbee2mqtt/bridge/state', 'payload_available': 'online', 'payload_not_available': 'offline'}], 'device': {'identifiers': ['zigbee2mqtt_0x00158d00047b4d03'], 'manufacturer': 'Xiaomi', 'model': 'Aqara temperature, humidity and pressure sensor (WSDCGQ11LM)', 'name': '0x00158d00047b4d03', 'sw_version': 'Zigbee2MQTT 1.18.1', 'connections': []}, 'device_class': <SensorDeviceClass.TEMPERATURE: 'temperature'>, 'json_attributes_topic': 'zigbee2mqtt/0x00158d00047b4d03', 'name': '0x00158d00047b4d03 temperature', 'state_topic': 'zigbee2mqtt/0x00158d00047b4d03', 'unique_id': '0x00158d00047b4d03_temperature_zigbee2mqtt', 'unit_of_measurement': '°C', 'value_template': Template<template=({{ value_json.temperature }}) renders=0>, 'payload_not_available': 'offline', 'enabled_by_default': True, 'encoding': 'utf-8', 'availability_mode': 'latest', 'force_update': False, 'qos': 0, 'payload_available': 'online'}, this is not expected. Please correct your configuration. The device name prefix will be stripped off the entity name and becomes 'temperature'
2023-10-10 22:05:00.851 WARNING (MainThread) [homeassistant.components.mqtt.mixins] MQTT entity name starts with the device name in your config {'availability': [{'topic': 'zigbee2mqtt/bridge/state', 'payload_available': 'online', 'payload_not_available': 'offline'}], 'device': {'identifiers': ['zigbee2mqtt_0x00158d00047b4d03'], 'manufacturer': 'Xiaomi', 'model': 'Aqara temperature, humidity and pressure sensor (WSDCGQ11LM)', 'name': '0x00158d00047b4d03', 'sw_version': 'Zigbee2MQTT 1.18.1', 'connections': []}, 'device_class': <SensorDeviceClass.HUMIDITY: 'humidity'>, 'json_attributes_topic': 'zigbee2mqtt/0x00158d00047b4d03', 'name': '0x00158d00047b4d03 humidity', 'state_topic': 'zigbee2mqtt/0x00158d00047b4d03', 'unique_id': '0x00158d00047b4d03_humidity_zigbee2mqtt', 'unit_of_measurement': '%', 'value_template': Template<template=({{ value_json.humidity }}) renders=0>, 'payload_not_available': 'offline', 'enabled_by_default': True, 'encoding': 'utf-8', 'availability_mode': 'latest', 'force_update': False, 'qos': 0, 'payload_available': 'online'}, this is not expected. Please correct your configuration. The device name prefix will be stripped off the entity name and becomes 'humidity'
2023-10-10 22:05:00.857 WARNING (MainThread) [homeassistant.components.mqtt.mixins] MQTT entity name starts with the device name in your config {'availability': [{'topic': 'zigbee2mqtt/bridge/state', 'payload_available': 'online', 'payload_not_available': 'offline'}], 'device': {'identifiers': ['zigbee2mqtt_0x00158d00047b4d03'], 'manufacturer': 'Xiaomi', 'model': 'Aqara temperature, humidity and pressure sensor (WSDCGQ11LM)', 'name': '0x00158d00047b4d03', 'sw_version': 'Zigbee2MQTT 1.18.1', 'connections': []}, 'device_class': <SensorDeviceClass.PRESSURE: 'pressure'>, 'json_attributes_topic': 'zigbee2mqtt/0x00158d00047b4d03', 'name': '0x00158d00047b4d03 pressure', 'state_topic': 'zigbee2mqtt/0x00158d00047b4d03', 'unique_id': '0x00158d00047b4d03_pressure_zigbee2mqtt', 'unit_of_measurement': 'hPa', 'value_template': Template<template=({{ value_json.pressure }}) renders=0>, 'payload_not_available': 'offline', 'enabled_by_default': True, 'encoding': 'utf-8', 'availability_mode': 'latest', 'force_update': False, 'qos': 0, 'payload_available': 'online'}, this is not expected. Please correct your configuration. The device name prefix will be stripped off the entity name and becomes 'pressure'
2023-10-10 22:05:00.870 WARNING (MainThread) [homeassistant.components.mqtt.mixins] MQTT entity name starts with the device name in your config {'availability': [{'topic': 'zigbee2mqtt/bridge/state', 'payload_available': 'online', 'payload_not_available': 'offline'}], 'device': {'identifiers': ['zigbee2mqtt_0x00158d00047b4d03'], 'manufacturer': 'Xiaomi', 'model': 'Aqara temperature, humidity and pressure sensor (WSDCGQ11LM)', 'name': '0x00158d00047b4d03', 'sw_version': 'Zigbee2MQTT 1.18.1', 'connections': []}, 'device_class': <SensorDeviceClass.BATTERY: 'battery'>, 'json_attributes_topic': 'zigbee2mqtt/0x00158d00047b4d03', 'name': '0x00158d00047b4d03 battery', 'state_topic': 'zigbee2mqtt/0x00158d00047b4d03', 'unique_id': '0x00158d00047b4d03_battery_zigbee2mqtt', 'unit_of_measurement': '%', 'value_template': Template<template=({{ value_json.battery }}) renders=0>, 'payload_not_available': 'offline', 'enabled_by_default': True, 'encoding': 'utf-8', 'availability_mode': 'latest', 'force_update': False, 'qos': 0, 'payload_available': 'online'}, this is not expected. Please correct your configuration. The device name prefix will be stripped off the entity name and becomes 'battery'
2023-10-10 22:05:00.876 WARNING (MainThread) [homeassistant.components.mqtt.mixins] MQTT entity name starts with the device name in your config {'availability': [{'topic': 'zigbee2mqtt/bridge/state', 'payload_available': 'online', 'payload_not_available': 'offline'}], 'device': {'identifiers': ['zigbee2mqtt_0x00158d00047b4d03'], 'manufacturer': 'Xiaomi', 'model': 'Aqara temperature, humidity and pressure sensor (WSDCGQ11LM)', 'name': '0x00158d00047b4d03', 'sw_version': 'Zigbee2MQTT 1.18.1', 'connections': []}, 'icon': 'mdi:signal', 'json_attributes_topic': 'zigbee2mqtt/0x00158d00047b4d03', 'name': '0x00158d00047b4d03 linkquality', 'state_topic': 'zigbee2mqtt/0x00158d00047b4d03', 'unique_id': '0x00158d00047b4d03_linkquality_zigbee2mqtt', 'unit_of_measurement': 'lqi', 'value_template': Template<template=({{ value_json.linkquality }}) renders=0>, 'payload_not_available': 'offline', 'enabled_by_default': True, 'encoding': 'utf-8', 'availability_mode': 'latest', 'force_update': False, 'qos': 0, 'payload_available': 'online'}, this is not expected. Please correct your configuration. The device name prefix will be stripped off the entity name and becomes 'linkquality'
2023-10-10 22:05:00.883 WARNING (MainThread) [homeassistant.components.mqtt.mixins] MQTT entity name starts with the device name in your config {'availability': [{'topic': 'zigbee2mqtt/bridge/state', 'payload_available': 'online', 'payload_not_available': 'offline'}], 'device': {'identifiers': ['zigbee2mqtt_0x00158d00047b4d03'], 'manufacturer': 'Xiaomi', 'model': 'Aqara temperature, humidity and pressure sensor (WSDCGQ11LM)', 'name': '0x00158d00047b4d03', 'sw_version': 'Zigbee2MQTT 1.18.1', 'connections': []}, 'device_class': <SensorDeviceClass.VOLTAGE: 'voltage'>, 'json_attributes_topic': 'zigbee2mqtt/0x00158d00047b4d03', 'name': '0x00158d00047b4d03 voltage', 'state_topic': 'zigbee2mqtt/0x00158d00047b4d03', 'unique_id': '0x00158d00047b4d03_voltage_zigbee2mqtt', 'unit_of_measurement': 'V', 'value_template': Template<template=({{ value_json.voltage }}) renders=0>, 'payload_not_available': 'offline', 'enabled_by_default': True, 'encoding': 'utf-8', 'availability_mode': 'latest', 'force_update': False, 'qos': 0, 'payload_available': 'online'}, this is not expected. Please correct your configuration. The device name prefix will be stripped off the entity name and becomes 'voltage'
2023-10-10 22:05:00.893 WARNING (MainThread) [homeassistant.components.mqtt.mixins] MQTT entity name starts with the device name in your config {'availability': [{'topic': 'zigbee2mqtt/bridge/state', 'payload_available': 'online', 'payload_not_available': 'offline'}], 'device': {'identifiers': ['zigbee2mqtt_0x00158d000450a3c6'], 'manufacturer': 'Xiaomi', 'model': 'Aqara wireless switch (WXKG11LM)', 'name': 'Przycisk sypialnia', 'sw_version': 'Zigbee2MQTT 1.18.1', 'connections': []}, 'icon': 'mdi:toggle-switch', 'json_attributes_topic': 'zigbee2mqtt/Przycisk sypialnia', 'name': 'Przycisk sypialnia click', 'state_topic': 'zigbee2mqtt/Przycisk sypialnia', 'unique_id': '0x00158d000450a3c6_click_zigbee2mqtt', 'value_template': Template<template=({{ value_json.click }}) renders=0>, 'payload_not_available': 'offline', 'enabled_by_default': True, 'encoding': 'utf-8', 'availability_mode': 'latest', 'force_update': False, 'qos': 0, 'payload_available': 'online'}, this is not expected. Please correct your configuration. The device name prefix will be stripped off the entity name and becomes 'Click'
2023-10-10 22:05:00.902 WARNING (MainThread) [homeassistant.components.mqtt.mixins] MQTT entity name starts with the device name in your config {'availability': [{'topic': 'zigbee2mqtt/bridge/state', 'payload_available': 'online', 'payload_not_available': 'offline'}], 'device': {'identifiers': ['zigbee2mqtt_0x00158d000450a3c6'], 'manufacturer': 'Xiaomi', 'model': 'Aqara wireless switch (WXKG11LM)', 'name': 'Przycisk sypialnia', 'sw_version': 'Zigbee2MQTT 1.18.1', 'connections': []}, 'device_class': <SensorDeviceClass.BATTERY: 'battery'>, 'json_attributes_topic': 'zigbee2mqtt/Przycisk sypialnia', 'name': 'Przycisk sypialnia battery', 'state_topic': 'zigbee2mqtt/Przycisk sypialnia', 'unique_id': '0x00158d000450a3c6_battery_zigbee2mqtt', 'unit_of_measurement': '%', 'value_template': Template<template=({{ value_json.battery }}) renders=0>, 'payload_not_available': 'offline', 'enabled_by_default': True, 'encoding': 'utf-8', 'availability_mode': 'latest', 'force_update': False, 'qos': 0, 'payload_available': 'online'}, this is not expected. Please correct your configuration. The device name prefix will be stripped off the entity name and becomes 'Battery'
2023-10-10 22:05:00.906 WARNING (MainThread) [homeassistant.components.mqtt.mixins] MQTT entity name starts with the device name in your config {'availability': [{'topic': 'zigbee2mqtt/bridge/state', 'payload_available': 'online', 'payload_not_available': 'offline'}], 'device': {'identifiers': ['zigbee2mqtt_0x00158d000450a3c6'], 'manufacturer': 'Xiaomi', 'model': 'Aqara wireless switch (WXKG11LM)', 'name': 'Przycisk sypialnia', 'sw_version': 'Zigbee2MQTT 1.18.1', 'connections': []}, 'device_class': <SensorDeviceClass.VOLTAGE: 'voltage'>, 'json_attributes_topic': 'zigbee2mqtt/Przycisk sypialnia', 'name': 'Przycisk sypialnia voltage', 'state_topic': 'zigbee2mqtt/Przycisk sypialnia', 'unique_id': '0x00158d000450a3c6_voltage_zigbee2mqtt', 'unit_of_measurement': 'V', 'value_template': Template<template=({{ value_json.voltage }}) renders=0>, 'payload_not_available': 'offline', 'enabled_by_default': True, 'encoding': 'utf-8', 'availability_mode': 'latest', 'force_update': False, 'qos': 0, 'payload_available': 'online'}, this is not expected. Please correct your configuration. The device name prefix will be stripped off the entity name and becomes 'Voltage'
2023-10-10 22:05:00.913 WARNING (MainThread) [homeassistant.components.mqtt.mixins] MQTT entity name starts with the device name in your config {'availability': [{'topic': 'zigbee2mqtt/bridge/state', 'payload_available': 'online', 'payload_not_available': 'offline'}], 'device': {'identifiers': ['zigbee2mqtt_0x00158d000450a3c6'], 'manufacturer': 'Xiaomi', 'model': 'Aqara wireless switch (WXKG11LM)', 'name': 'Przycisk sypialnia', 'sw_version': 'Zigbee2MQTT 1.18.1', 'connections': []}, 'icon': 'mdi:gesture-double-tap', 'json_attributes_topic': 'zigbee2mqtt/Przycisk sypialnia', 'name': 'Przycisk sypialnia action', 'state_topic': 'zigbee2mqtt/Przycisk sypialnia', 'unique_id': '0x00158d000450a3c6_action_zigbee2mqtt', 'value_template': Template<template=({{ value_json.action }}) renders=0>, 'payload_not_available': 'offline', 'enabled_by_default': True, 'encoding': 'utf-8', 'availability_mode': 'latest', 'force_update': False, 'qos': 0, 'payload_available': 'online'}, this is not expected. Please correct your configuration. The device name prefix will be stripped off the entity name and becomes 'Action'
2023-10-10 22:05:00.916 WARNING (MainThread) [homeassistant.components.mqtt.mixins] MQTT entity name starts with the device name in your config {'availability': [{'topic': 'zigbee2mqtt/bridge/state', 'payload_available': 'online', 'payload_not_available': 'offline'}], 'device': {'identifiers': ['zigbee2mqtt_0x00158d000450a3c6'], 'manufacturer': 'Xiaomi', 'model': 'Aqara wireless switch (WXKG11LM)', 'name': 'Przycisk sypialnia', 'sw_version': 'Zigbee2MQTT 1.18.1', 'connections': []}, 'icon': 'mdi:signal', 'json_attributes_topic': 'zigbee2mqtt/Przycisk sypialnia', 'name': 'Przycisk sypialnia linkquality', 'state_topic': 'zigbee2mqtt/Przycisk sypialnia', 'unique_id': '0x00158d000450a3c6_linkquality_zigbee2mqtt', 'unit_of_measurement': 'lqi', 'value_template': Template<template=({{ value_json.linkquality }}) renders=0>, 'payload_not_available': 'offline', 'enabled_by_default': True, 'encoding': 'utf-8', 'availability_mode': 'latest', 'force_update': False, 'qos': 0, 'payload_available': 'online'}, this is not expected. Please correct your configuration. The device name prefix will be stripped off the entity name and becomes 'Linkquality'
2023-10-10 22:05:00.945 WARNING (MainThread) [homeassistant.components.mqtt.mixins] MQTT entity name starts with the device name in your config {'availability': [{'topic': 'zigbee2mqtt/bridge/state', 'payload_available': 'online', 'payload_not_available': 'offline'}], 'device': {'identifiers': ['zigbee2mqtt_0x00158d0004abd8bd'], 'manufacturer': 'Xiaomi', 'model': 'Aqara human body movement and illuminance sensor (RTCGQ11LM)', 'name': 'Czujnik ruchu wejście', 'sw_version': 'Zigbee2MQTT 1.18.1', 'connections': []}, 'device_class': <SensorDeviceClass.BATTERY: 'battery'>, 'json_attributes_topic': 'zigbee2mqtt/Czujnik ruchu wejście', 'name': 'Czujnik ruchu wejście battery', 'state_topic': 'zigbee2mqtt/Czujnik ruchu wejście', 'unique_id': '0x00158d0004abd8bd_battery_zigbee2mqtt', 'unit_of_measurement': '%', 'value_template': Template<template=({{ value_json.battery }}) renders=0>, 'payload_not_available': 'offline', 'enabled_by_default': True, 'encoding': 'utf-8', 'availability_mode': 'latest', 'force_update': False, 'qos': 0, 'payload_available': 'online'}, this is not expected. Please correct your configuration. The device name prefix will be stripped off the entity name and becomes 'Battery'
2023-10-10 22:05:00.948 WARNING (MainThread) [homeassistant.components.mqtt.mixins] MQTT entity name starts with the device name in your config {'availability': [{'topic': 'zigbee2mqtt/bridge/state', 'payload_available': 'online', 'payload_not_available': 'offline'}], 'device': {'identifiers': ['zigbee2mqtt_0x00158d0004abd8bd'], 'manufacturer': 'Xiaomi', 'model': 'Aqara human body movement and illuminance sensor (RTCGQ11LM)', 'name': 'Czujnik ruchu wejście', 'sw_version': 'Zigbee2MQTT 1.18.1', 'connections': []}, 'device_class': <SensorDeviceClass.TEMPERATURE: 'temperature'>, 'json_attributes_topic': 'zigbee2mqtt/Czujnik ruchu wejście', 'name': 'Czujnik ruchu wejście temperature', 'state_topic': 'zigbee2mqtt/Czujnik ruchu wejście', 'unique_id': '0x00158d0004abd8bd_temperature_zigbee2mqtt', 'unit_of_measurement': '°C', 'value_template': Template<template=({{ value_json.temperature }}) renders=0>, 'payload_not_available': 'offline', 'enabled_by_default': True, 'encoding': 'utf-8', 'availability_mode': 'latest', 'force_update': False, 'qos': 0, 'payload_available': 'online'}, this is not expected. Please correct your configuration. The device name prefix will be stripped off the entity name and becomes 'Temperature'
2023-10-10 22:05:00.952 WARNING (MainThread) [homeassistant.components.mqtt.mixins] MQTT entity name starts with the device name in your config {'availability': [{'topic': 'zigbee2mqtt/bridge/state', 'payload_available': 'online', 'payload_not_available': 'offline'}], 'device': {'identifiers': ['zigbee2mqtt_0x00158d0004abd8bd'], 'manufacturer': 'Xiaomi', 'model': 'Aqara human body movement and illuminance sensor (RTCGQ11LM)', 'name': 'Czujnik ruchu wejście', 'sw_version': 'Zigbee2MQTT 1.18.1', 'connections': []}, 'device_class': <SensorDeviceClass.VOLTAGE: 'voltage'>, 'json_attributes_topic': 'zigbee2mqtt/Czujnik ruchu wejście', 'name': 'Czujnik ruchu wejście voltage', 'state_topic': 'zigbee2mqtt/Czujnik ruchu wejście', 'unique_id': '0x00158d0004abd8bd_voltage_zigbee2mqtt', 'unit_of_measurement': 'V', 'value_template': Template<template=({{ value_json.voltage }}) renders=0>, 'payload_not_available': 'offline', 'enabled_by_default': True, 'encoding': 'utf-8', 'availability_mode': 'latest', 'force_update': False, 'qos': 0, 'payload_available': 'online'}, this is not expected. Please correct your configuration. The device name prefix will be stripped off the entity name and becomes 'Voltage'
2023-10-10 22:05:00.957 WARNING (MainThread) [homeassistant.components.mqtt.mixins] MQTT entity name starts with the device name in your config {'availability': [{'topic': 'zigbee2mqtt/bridge/state', 'payload_available': 'online', 'payload_not_available': 'offline'}], 'device': {'identifiers': ['zigbee2mqtt_0x00158d0004abd8bd'], 'manufacturer': 'Xiaomi', 'model': 'Aqara human body movement and illuminance sensor (RTCGQ11LM)', 'name': 'Czujnik ruchu wejście', 'sw_version': 'Zigbee2MQTT 1.18.1', 'connections': []}, 'device_class': <SensorDeviceClass.ILLUMINANCE: 'illuminance'>, 'json_attributes_topic': 'zigbee2mqtt/Czujnik ruchu wejście', 'name': 'Czujnik ruchu wejście illuminance lux', 'state_topic': 'zigbee2mqtt/Czujnik ruchu wejście', 'unique_id': '0x00158d0004abd8bd_illuminance_lux_zigbee2mqtt', 'unit_of_measurement': 'lx', 'value_template': Template<template=({{ value_json.illuminance }}) renders=0>, 'payload_not_available': 'offline', 'enabled_by_default': True, 'encoding': 'utf-8', 'availability_mode': 'latest', 'force_update': False, 'qos': 0, 'payload_available': 'online'}, this is not expected. Please correct your configuration. The device name prefix will be stripped off the entity name and becomes 'Illuminance lux'
2023-10-10 22:05:00.960 WARNING (MainThread) [homeassistant.components.mqtt.mixins] MQTT entity name starts with the device name in your config {'availability': [{'topic': 'zigbee2mqtt/bridge/state', 'payload_available': 'online', 'payload_not_available': 'offline'}], 'device': {'identifiers': ['zigbee2mqtt_0x00158d0004abd8bd'], 'manufacturer': 'Xiaomi', 'model': 'Aqara human body movement and illuminance sensor (RTCGQ11LM)', 'name': 'Czujnik ruchu wejście', 'sw_version': 'Zigbee2MQTT 1.18.1', 'connections': []}, 'device_class': <SensorDeviceClass.ILLUMINANCE: 'illuminance'>, 'json_attributes_topic': 'zigbee2mqtt/Czujnik ruchu wejście', 'name': 'Czujnik ruchu wejście illuminance', 'state_topic': 'zigbee2mqtt/Czujnik ruchu wejście', 'unique_id': '0x00158d0004abd8bd_illuminance_zigbee2mqtt', 'unit_of_measurement': 'lx', 'value_template': Template<template=({{ value_json.illuminance }}) renders=0>, 'payload_not_available': 'offline', 'enabled_by_default': True, 'encoding': 'utf-8', 'availability_mode': 'latest', 'force_update': False, 'qos': 0, 'payload_available': 'online'}, this is not expected. Please correct your configuration. The device name prefix will be stripped off the entity name and becomes 'Illuminance'
2023-10-10 22:05:00.963 WARNING (MainThread) [homeassistant.components.mqtt.mixins] MQTT entity name starts with the device name in your config {'availability': [{'topic': 'zigbee2mqtt/bridge/state', 'payload_available': 'online', 'payload_not_available': 'offline'}], 'device': {'identifiers': ['zigbee2mqtt_0x00158d0004abd8bd'], 'manufacturer': 'Xiaomi', 'model': 'Aqara human body movement and illuminance sensor (RTCGQ11LM)', 'name': 'Czujnik ruchu wejście', 'sw_version': 'Zigbee2MQTT 1.18.1', 'connections': []}, 'icon': 'mdi:signal', 'json_attributes_topic': 'zigbee2mqtt/Czujnik ruchu wejście', 'name': 'Czujnik ruchu wejście linkquality', 'state_topic': 'zigbee2mqtt/Czujnik ruchu wejście', 'unique_id': '0x00158d0004abd8bd_linkquality_zigbee2mqtt', 'unit_of_measurement': 'lqi', 'value_template': Template<template=({{ value_json.linkquality }}) renders=0>, 'payload_not_available': 'offline', 'enabled_by_default': True, 'encoding': 'utf-8', 'availability_mode': 'latest', 'force_update': False, 'qos': 0, 'payload_available': 'online'}, this is not expected. Please correct your configuration. The device name prefix will be stripped off the entity name and becomes 'Linkquality'
2023-10-10 22:05:00.969 WARNING (MainThread) [homeassistant.components.mqtt.mixins] MQTT entity name starts with the device name in your config {'availability': [{'topic': 'zigbee2mqtt/bridge/state', 'payload_available': 'online', 'payload_not_available': 'offline'}], 'device': {'identifiers': ['zigbee2mqtt_0x00158d0004abd8bd'], 'manufacturer': 'Xiaomi', 'model': 'Aqara human body movement and illuminance sensor (RTCGQ11LM)', 'name': 'Czujnik ruchu wejście', 'sw_version': 'Zigbee2MQTT 1.18.1', 'connections': []}, 'device_class': <BinarySensorDeviceClass.MOTION: 'motion'>, 'json_attributes_topic': 'zigbee2mqtt/Czujnik ruchu wejście', 'name': 'Czujnik ruchu wejście occupancy', 'payload_off': 'False', 'payload_on': 'True', 'state_topic': 'zigbee2mqtt/Czujnik ruchu wejście', 'unique_id': '0x00158d0004abd8bd_occupancy_zigbee2mqtt', 'value_template': Template<template=({{ value_json.occupancy }}) renders=0>, 'payload_not_available': 'offline', 'enabled_by_default': True, 'encoding': 'utf-8', 'availability_mode': 'latest', 'force_update': False, 'qos': 0, 'payload_available': 'online'}, this is not expected. Please correct your configuration. The device name prefix will be stripped off the entity name and becomes 'Occupancy'
2023-10-10 22:05:06.785 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Pace Micro Technology plc DMC7002KLG' for upnp integration not ready yet: Device not discovered: uuid:upnp-InternetGatewayDevice-1_0-a0c562743b38::urn:schemas-upnp-org:device:InternetGatewayDevice:1; Retrying in background
2023-10-10 22:05:21.020 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /addons/a0d7b954_nodered/start - Image ghcr.io/hassio-addons/node-red/amd64:14.6.1 does not exist for addon_a0d7b954_nodered
2023-10-10 22:05:40.258 ERROR (SyncWorker_0) [spotipy.client] Max Retries reached
2023-10-10 22:05:40.265 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Marek Duraj' for spotify integration not ready yet: http status: 429, code:-1 - /v1/me/:
Max Retries, reason: too many 429 error responses; Retrying in background
2023-10-10 22:05:41.533 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: upnp
2023-10-10 22:06:26.796 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Compal Broadband Networks, Inc CH7465LG' for upnp integration not ready yet: Error connecting to device at location: http://[2a02:a304:0:1db:2836:f5b8:fcc3:dca3]:5000/rootDesc.xml, err: ("UpnpConnectionTimeoutError('TimeoutError()', None)", None); Retrying in background
2023-10-10 22:06:41.361 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_deconz/info request
2023-10-10 22:06:41.368 ERROR (MainThread) [homeassistant.components.hassio.discovery] Can't read add-on info:
2023-10-10 22:06:41.383 ERROR (MainThread) [homeassistant.components.homeassistant_alerts] Timeout fetching homeassistant_alerts data
2023-10-10 22:06:41.475 WARNING (MainThread) [custom_components.hacs] You have 'AitorDB/home-assistant-sun-card' installed with HACS this repository has been removed from HACS, please consider removing it. Removal reason (Repository is archived)
2023-10-10 22:06:52.003 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform spotify is taking over 10 seconds.
2023-10-10 22:07:12.327 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /addons/a0d7b954_nodered/start - Image ghcr.io/hassio-addons/node-red/amd64:14.6.1 does not exist for addon_a0d7b954_nodered
2023-10-10 22:09:13.249 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /addons/a0d7b954_nodered/start - Image ghcr.io/hassio-addons/node-red/amd64:14.6.1 does not exist for addon_a0d7b954_nodered
2023-10-10 22:09:55.396 WARNING (SyncWorker_7) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
