DTSU666 + modbus - częstotliwość
Cześć.
Udało mi się uruchomić odczyty z chint dtsu666 za pomocą esp32 rs485 i esphome do home assistanta.
Wszystkie wartości wydają się być w normie, “na oko”, za wyjątkiem częstotliwości. Spodziewałbym się 50Hz, ale mam 174,08 Hz. Nie wiem czego to jest częstotliwość.
Logi:
[11:37:03][D][modbus_controller.sensor:025]: Sensor new state: 17408.00
[11:37:03][D][sensor:094]: 'Częstotliwość': Sending state 174.08000 Hz with 2 decimals of accuracy
Dokumentacja:
Konfiguracja:
  friendly_name: main_meter
  board: esp32dev
    type: arduino
# Enable logging
# Enable Home Assistant API
    key: "***"
  - platform: esphome
    password: "***"
  ssid: "***"
  password: "***"
    ssid: "Main-Meter Fallback Hotspot"
    password: "8yretuaeJSX8"
captive_portal:
uart:
  tx_pin: GPIO17
  rx_pin: GPIO16
  baud_rate: 9600
  stop_bits: 1
  # debug:
  #   direction: BOTH
  #   dummy_receiver: false
  #   after:
  #     delimiter: "\n"
  #   sequence:
  #     - lambda: UARTDebug::log_string(direction, bytes);
modbus:
  #flow_control_pin: 23
  send_wait_time: 200ms
modbus_controller:
  - id: vcx
    modbus_id: mod_bus_vcx
    command_throttle: 100ms
    setup_priority: -10
    update_interval: 10s
text_sensor:
    name: "Main-meter Uptime (human readable)"
    icon: "mdi:clock-start"
    update_interval: 5s
# Napięcia
  - platform: modbus_controller
    name: "Faza L1 napięcie"
    state_class: measurement
    register_type: read
    address: 0x2006
    unit_of_measurement: "V"
    value_type: FP32
    accuracy_decimals: 1
    filters:
      - multiply: 0.1
    name: "Faza L2 napięcie"
    register_type: read
    address: 0x2008
    value_type: FP32
    filters:
      - multiply: 0.1
    name: "Faza L3 napięcie"
    address: 0x200A
    register_type: read
    value_type: FP32
    filters:
      - multiply: 0.1
# Częstotliwość
    register_type: read
    address: 0x2044
    unit_of_measurement: "Hz"
    value_type: S_WORD
    accuracy_decimals: 2
    filters:
      - multiply: 0.01
# Prąd
    name: "Faza L1 prąd"
    register_type: read
    address: 0x200C
    unit_of_measurement: "A"
    value_type: FP32
    filters:
      - multiply: 0.001
    name: "Faza L2 prąd"
    register_type: read
    address: 0x200E
    value_type: FP32
    filters:
      - multiply: 0.001
    name: "Faza L3 prąd"
    register_type: read
    address: 0x2010
    value_type: FP32
    filters:
      - multiply: 0.001
# Moc chwilowa
    name: "Faza L1 moc czynna"
    register_type: read
    address: 0x2014
    unit_of_measurement: "W"
    value_type: FP32
    accuracy_decimals: 0
    filters:
      - multiply: 0.1
    name: "Faza L2 moc czynna"
    register_type: read
    address: 0x2016
    value_type: FP32
    filters:
      - multiply: 0.1
    name: "Faza L3 moc czynna"
    register_type: read
    address: 0x2018
    value_type: FP32
    filters:
      - multiply: 0.1
    name: "Całkowita moc czynna"
    register_type: read
    address: 0x2012
    unit_of_measurement: "kW"
    value_type: FP32
    filters:
      - multiply: 0.1
# Energia
    name: "Moc czynna pobrana"
    register_type: read
    icon: mdi:circle-slice-3
    device_class: energy
    state_class: total_increasing
    address: 0x401E
    unit_of_measurement: "kWh"
    value_type: FP32
    #skip_updates: 60
    filters:
      - multiply: 1
    name: "Moc czynna oddana"
    register_type: read
    address: 0x4028
    value_type: FP32
    #skip_updates: 60
    filters:
      - multiply: 1
# wifi signal
  - platform: wifi_signal
    name: "WiFi Signal main-meter"
    update_interval: 60s
    icon: "mdi:wifi"
  - platform: uptime
    filters:
      - lambda: return x / 60.0;
    unit_of_measurement: minutes
  - platform: uptime
    update_interval: 5s
    internal: true
    on_raw_value:
      then:
            state: !lambda |-
              int seconds = round(id(uptime_sensor).raw_state);
              seconds = seconds % (24 * 3600);
              int hours = seconds / 3600;
              seconds = seconds % 3600;
              int minutes = seconds /  60;
              seconds = seconds % 60;
              return (
                (hours ? to_string(hours) + "h " : "") +
                (minutes ? to_string(minutes) + "m " : "") +
                (to_string(seconds) + "s")
              ).c_str();
    unit_of_measurement: "%"
    name: "Main-meter WiFi Signal (human readable)"
    update_interval: 30s
    icon: "mdi:wifi"
    lambda: return (-0.0134 * (id(dtsu_wifi_signal).state * id(dtsu_wifi_signal).state ) ) + (-0.2228 * id(dtsu_wifi_signal).state) + 100.2;
Dobra, tutaj jest błąd. Powinno być value_type: FP32
