Po pierwsze z uwagi na mój pierwszy post - Cześć !
HA mam postawione na proxmox sprzętowo na terminalu HP T620 i conbee2.
Jako, że dopiero się wdrażam, bardzo proszę o wyrozumiałość ![]()
Problem:
Utawienia - Urządzenia oraz usługi - tam kafelek ConbeeII, a pod nim ! błąd konfiguracji:
oto log błędu.
pomoże Ktoś mnie oświecić z kąd ten błąd ?
Logger: homeassistant.config_entries
Source: components/zha/core/gateway.py:174
First occurred: 14:37:22 (1 occurrences)
Last logged: 14:37:22
Error setting up entry ConBee II for zha
File “/usr/local/lib/python3.10/asyncio/tasks.py”, line 456, in wait_for
return fut.result()
asyncio.exceptions.CancelledError
The above exception was the direct cause of the following exception:
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 382, in async_setup
result = await component.async_setup_entry(hass, self)
File “/usr/src/homeassistant/homeassistant/components/zha/init.py”, line 111, in async_setup_entry
await zha_gateway.async_initialize()
File “/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py”, line 189, in async_initialize
raise exc
File “/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py”, line 174, in async_initialize
self.application_controller = await app_controller_cls.new(
File “/usr/local/lib/python3.10/site-packages/zigpy/application.py”, line 169, in new
await app.startup(auto_form=auto_form)
File “/usr/local/lib/python3.10/site-packages/zigpy/application.py”, line 145, in startup
await self.connect()
File “/usr/local/lib/python3.10/site-packages/zigpy_deconz/zigbee/application.py”, line 81, in connect
self.version = await api.version()
File “/usr/local/lib/python3.10/site-packages/zigpy_deconz/api.py”, line 457, in version
(self._proto_ver,) = await self.read_parameter(
File “/usr/local/lib/python3.10/site-packages/zigpy_deconz/api.py”, line 422, in read_parameter
r = await self._command(Command.read_parameter, 1 + len(data), param, data)
File “/usr/local/lib/python3.10/site-packages/zigpy_deconz/api.py”, line 306, in _command
return await asyncio.wait_for(fut, timeout=COMMAND_TIMEOUT)
File “/usr/local/lib/python3.10/asyncio/tasks.py”, line 458, in wait_for
raise exceptions.TimeoutError() from exc
asyncio.exceptions.TimeoutError
