Witam specjalistów ![]()
Mam problem z zainstalowaniem ESP Home na płytce ESP32-S3 N16R8.
Próbowałem przez esptool, czy tez z HA ESPHome.
nawet jak chcę wrzucić gołą konfigurację to jest boot loop
Yaml
friendly_name: ESP32 S3 N16R8
platformio_options:
board_build.flash_mode: dio
board: esp32-s3-devkitc-1
type: arduino
version: latest
# Enable logging
# Enable Home Assistant API
key: "pmQh7bK6A5jSk97um2o8ps1dZTjHaZgdYJR8ang4S9I="
- platform: esphome
password: "375da47cc7def8f78c51ba10651c86f5"
ssid: !secret wifi_ssid
ssid: "Esp32-S3-N16R8 Fallback Hotspot"
password: "nveuu9pqiePq"
captive_portal:
i po zainstalowaniu w logach pokazuję się:
[20:52:10]8�c"�1����bk�ۅt�ᢍ��Zg�ZESP-ROM:esp32s3-20210327
[20:52:10]Build:Mar 27 2021
[20:52:10]rst:0x7 (TG0WDT_SYS_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
[20:52:10]Saved PC:0x403743c0
[20:52:10]SPIWP:0xee
[20:52:10]mode:DIO, clock div:1
[20:52:10]load:0x3c0d0020,len:0x39b5c
[20:52:10]load:0x3fc97830,len:0x3fcc
[20:52:10]load:0x40374000,len:0x24c0
[20:52:10]load:0x42000020,len:0xc1c5c
[20:52:10]load:0x403764c0,len:0x11364
[20:52:10]SHA-256 comparison failed:
[20:52:10]Calculated: 998e757f1458913ddf0fe9bd35cf90515d24bb4db2988cb26770e5c048ff6a69
[20:52:10]Expected: 37f1ce50e03d55149db9b2a2661aee190a617d61967deaa17fd3bf8fc26c929e
[20:52:10]Attempting to boot anyway...
[20:52:10]entry 0x40376480
[20:52:11]ESP-ROM:esp32s3-20210327
[20:52:11]Build:Mar 27 2021
[20:52:11]rst:0x7 (TG0WDT_SYS_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
[20:52:11]Saved PC:0x4037ac66
[20:52:11]SPIWP:0xee
[20:52:11]mode:DIO, clock div:1
[20:52:11]load:0x3c0d0020,len:0x39b5c
[20:52:11]load:0x3fc97830,len:0x3fcc
[20:52:11]load:0x40374000,len:0x24c0
[20:52:11]load:0x42000020,len:0xc1c5c
[20:52:11]rst:0x10 (RTCWDT_RTC_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
[20:52:12]load:0x3fc97830,len:0x3fcc
[20:52:12]load:0x40374000,len:0x24c0
[20:52:12]load:0x42000020,len:0xc1c5c
[20:52:12]load:0x403764c0,len:0x11364
[20:52:12]SHA-256 comparison failed:
[20:52:12]Calculated: 998e757f1458913ddf0fe9bd35cf90515d24bb4db2988cb26770e5c048ff6a69
[20:52:12]Expected: 37f1ce50e03d55149db9b2a2661aee190a617d61967deaa17fd3bf8fc26c929e
[20:52:12]Attempting to boot anyway...
[20:52:12]entry 0x40376480
[20:52:13]ESP-ROM:esp32s3-20210327
[20:52:13]Build:Mar 27 2021
[20:52:13]rst:0x7 (TG0WDT_SYS_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
Widzę że problem wskazuje na niepowodzenie weryfikacji sumy kontrolnej SHA-256 podczas uruchamiania ESP32 S3.
ale jak to naprawić ?
Mam dwie takie nowe płytki i na obu ten sam problem.
Dziekuję za podpowiedzi
