Hejka,
czy ktoś umie mi podpowiedzieć w którym momencie robię błąd, bo mam esp32, chcę je zaprogramować, aczkolwiek w pewnym momencie wyskakuje mi błąd:
**Za 1szym razem:**
INFO ESPHome 2023.12.9
INFO Reading configuration /config/esphome/foxess-inverter.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing foxess-inverter (board: esp32dev; framework: arduino; platform: platformio/espressif32@5.4.0)
Platform Manager: Installing platformio/espressif32 @ 5.4.0
INFO Installing platformio/espressif32 @ 5.4.0
Downloading [####################################] 100%
Unpacking [####################################] 100%
Platform Manager: espressif32@5.4.0 has been installed!
INFO espressif32@5.4.0 has been installed!
Tool Manager: Installing espressif/toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
INFO Installing espressif/toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Tool Manager: toolchain-xtensa-esp32@8.4.0+2021r2-patch5 has been installed!
INFO toolchain-xtensa-esp32@8.4.0+2021r2-patch5 has been installed!
Tool Manager: Installing platformio/framework-arduinoespressif32 @ ~3.20005.0
INFO Installing platformio/framework-arduinoespressif32 @ ~3.20005.0
Tool Manager: framework-arduinoespressif32@3.20005.220925 has been installed!
INFO framework-arduinoespressif32@3.20005.220925 has been installed!
Tool Manager: Installing platformio/tool-esptoolpy @ ~1.40400.0
INFO Installing platformio/tool-esptoolpy @ ~1.40400.0
Tool Manager: tool-esptoolpy@1.40400.0 has been installed!
INFO tool-esptoolpy@1.40400.0 has been installed!
Tool Manager: Installing platformio/tool-scons @ ~4.40502.0
INFO Installing platformio/tool-scons @ ~4.40502.0
Tool Manager: tool-scons@4.40502.0 has been installed!
INFO tool-scons@4.40502.0 has been installed!
Library Manager: Installing esphome/AsyncTCP-esphome @ 2.0.1
INFO Installing esphome/AsyncTCP-esphome @ 2.0.1
Library Manager: AsyncTCP-esphome@2.0.1 has been installed!
INFO AsyncTCP-esphome@2.0.1 has been installed!
Library Manager: Installing esphome/ESPAsyncWebServer-esphome @ 3.1.0
INFO Installing esphome/ESPAsyncWebServer-esphome @ 3.1.0
Library Manager: ESPAsyncWebServer-esphome@3.1.0 has been installed!
INFO ESPAsyncWebServer-esphome@3.1.0 has been installed!
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- AsyncTCP-esphome @ 2.0.1
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.1.0
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
Compiling .pioenvs/foxess-inverter/src/esphome/components/api/api_connection.cpp.o
xtensa-esp32-elf-g++: fatal error: Killed signal terminated program cc1plus
compilation terminated.
*** [.pioenvs/foxess-inverter/src/esphome/components/api/api_connection.cpp.o] Error 1
========================= [FAILED] Took 501.94 seconds =========================
**Za drugim razem:**
Dependency Graph
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPmDNS @ 2.0.0
========================= [FAILED] Took 27.90 seconds =========================
natomiast plik yaml, który chcę wgrać to:
includes:
- foxess_t_series.h
board: esp32dev
type: arduino
# Enable logging
level: VERBOSE
baud_rate: 0
# Enable Home Assistant API
password: ""
ssid: "nazwa_sieci"
password: "hasło"
# manual_ip:
# static_ip: xxx.xxx.xxx.xx
# gateway: xxx.xxx.xxx.x
# subnet: 255.255.255.0
ssid: "Inverter Fallback Hotspot"
password: ""
captive_portal:
uart:
tx_pin: 16
rx_pin: 17
baud_rate: 9600
#debug:
button:
- platform: restart
name: "Foxess inverter restart"
switch:
- platform: gpio
pin: 4
name: "T-Series sending mode" #if "on" reading from inverter doesn't work!
internal: true #switch is not exposed to HA frontend, should you ever need to write to the inverter, just comment this line
text_sensor:
name: "T-Series Inverter Mode"
icon: mdi:solar-power-variant
- platform: custom
lambda: |-
auto foxesssensors = new foxesscomponent(id(uart_bus));
App.register_component(foxesssensors);
return {\
foxesssensors->grid_power, \
foxesssensors->generation_power, \
foxesssensors->loads_power, \
foxesssensors->grid_voltage_r, \
foxesssensors->grid_current_r, \
foxesssensors->grid_frequency_r, \
foxesssensors->grid_power_r, \
foxesssensors->grid_voltage_s, \
foxesssensors->grid_current_s, \
foxesssensors->grid_frequency_s, \
foxesssensors->grid_power_s, \
foxesssensors->grid_voltage_T, \
foxesssensors->grid_current_T, \
foxesssensors->grid_frequency_T, \
foxesssensors->grid_power_T, \
foxesssensors->pv1_voltage, \
foxesssensors->pv1_current, \
foxesssensors->pv2_voltage, \
foxesssensors->pv2_current, \
foxesssensors->pv3_voltage, \
foxesssensors->pv3_current, \
foxesssensors->pv4_voltage, \
foxesssensors->pv4_current, \
foxesssensors->boost_temperature, \
foxesssensors->inverter_temperature, \
foxesssensors->ambient_temperature, \
foxesssensors->today_yield, \
foxesssensors->generation_total, \
foxesssensors->pv1_power, \
foxesssensors->pv2_power, \
foxesssensors->pv3_power, \
foxesssensors->pv4_power, \
foxesssensors->inverter_state\
sensors:
- name: "T-Series Grid Power"
unit_of_measurement: W
icon: mdi:lightning-bolt
- name: "T-Series Generation Power"
- name: "T-Series loads Power"
- name: "T-Series Grid Voltage R"
unit_of_measurement: V
accuracy_decimals: 1
icon: mdi:flash
filters:
- multiply: 0.1
- throttle: 1h
- name: "T-Series Grid Current R"
unit_of_measurement: A
icon: mdi:current-ac
filters:
- multiply: 0.1
- throttle: 1h
- name: "T-Series Grid Frequency R"
unit_of_measurement: Hz
accuracy_decimals: 2
icon: mdi:sine-wave
filters:
- multiply: 0.01
- throttle: 1h
- name: "T-Series Grid Power R"
- name: "T-Series Grid Voltage S"
icon: mdi:flash
filters:
- multiply: 0.1
- throttle: 1h
- name: "T-Series Grid Current S"
filters:
- multiply: 0.1
- throttle: 1h
- name: "T-Series Grid Frequency S"
icon: mdi:sine-wave
filters:
- multiply: 0.01
- throttle: 1h
- name: "T-Series Grid Power S"
- name: "T-Series Grid Voltage T"
icon: mdi:flash
filters:
- multiply: 0.1
- throttle: 1h
- name: "T-Series Grid Current T"
filters:
- multiply: 0.1
- throttle: 1h
- name: "T-Series Grid Frequency T"
icon: mdi:sine-wave
filters:
- multiply: 0.01
- throttle: 1h
- name: "T-Series Grid Power T"
- name: "T-Series PV1 Voltage"
icon: mdi:flash
filters:
- multiply: 0.1
- name: "T-Series PV1 Current"
filters:
- multiply: 0.1
- name: "T-Series PV2 Voltage"
icon: mdi:flash
filters:
- multiply: 0.1
- name: "T-Series PV2 Current"
filters:
- multiply: 0.1
- name: "T-Series PV3 Voltage" #only relevant for models T8dual-T12dual and T15-T25
icon: mdi:flash
filters:
- multiply: 0.1
- name: "T-Series PV3 Current" #only relevant for models T8dual-T12dual and T15-T25
filters:
- multiply: 0.1
- name: "T-Series PV4 Voltage" #only relevant for models T8dual-T12dual and T15-T25
icon: mdi:flash
filters:
- multiply: 0.1
- name: "T-Series PV4 Current" #only relevant for models T8dual-T12dual and T15-T25
filters:
- multiply: 0.1
- name: "T-Series Boost Temperature" #boost temperature and inverter temperature seem to be always the same
unit_of_measurement: °C
filters:
- throttle: 10min
- name: "T-Series Inverter Temperature" #boost temperature and inverter temperature seem to be always the same
filters:
- throttle: 10min
- name: "T-Series Ambient Temperature"
filters:
- throttle: 10min
- name: "T-Series Today Yield"
unit_of_measurement: kWh
filters:
- multiply: 0.1
- name: "T-Series Generation Total"
device_class: energy #for use in energy dashboard
state_class: total_increasing #for use in energy dashboard
filters:
- multiply: 0.1
- name: "T-Series PV1 Power" #rs485 comm says this is always 0W, so this is calculated in the .h file by voltage*current
- name: "T-Series PV2 Power" #rs485 comm says this is always 0W, so this is calculated in the .h file by voltage*current
- name: "T-Series PV3 Power" #rs485 comm says this is always 0W, so this is calculated in the .h file by voltage*current
- name: "T-Series PV4 Power" #rs485 comm says this is always 0W, so this is calculated in the .h file by voltage*current
- name: "T-Series Inverter State"
internal: true
on_value:
then:
- lambda: |-
if(x==0) {
id(inverter_mode_text_sensor).publish_state("Offline");
else if(x==1) {
id(inverter_mode_text_sensor).publish_state("Online");
else if(x==2) {
id(inverter_mode_text_sensor).publish_state("Error");
else {
id(inverter_mode_text_sensor).publish_state("Waiting for response...");
Próbuje to skompilować na maszynie: Rpi3b. Miejsca na dysku ma wystarczająco: bo ok 90GB wolnej przestrzeni
