To chyba dobrze.
A teraz log z komponentem wmbus:
E (23960) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
E (23960) task_wdt: - loopTask (CPU 1)
E (23960) task_wdt: Tasks currently running:
E (23960) task_wdt: CPU 0: IDLE
E (23960) task_wdt: CPU 1: loopTask
E (23960) task_wdt: Aborting.
abort() was called at PC 0x400f6cc8 on core 0
Backtrace:0x400838d9:0x3ffbe9cc |<-CORRUPTED
ELF file SHA256: 0000000000000000
Rebooting...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:1184
load:0x40078000,len:13132
load:0x40080400,len:3036
entry 0x400805e4
[I][logger:259]: Log initialized
[C][ota:469]: There have been 5 suspected unsuccessful boot attempts.
[D][esp32.preferences:114]: Saving 1 preferences to flash...
[D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[I][app:029]: Running through setup()...
[C][wifi:038]: Setting up WiFi...
[C][wifi:039]: Local MAC: 30:C6:F7:2C:B3:3C
[D][wifi:387]: Starting scan...
[D][wifi:402]: Found networks:
[I][wifi:446]: - 'SYRION16262' (78:98:E8:34:FA:5A) [redacted]▂▄▆█
[D][wifi:447]: Channel: 5
[D][wifi:448]: RSSI: -58 dB
[I][wifi:446]: - 'SYRION16262' (10:27:F5:B0:6B:55) [redacted]▂▄▆█
[D][wifi:447]: Channel: 1
[D][wifi:448]: RSSI: -73 dB
[I][wifi:446]: - 'SYRION16262' (10:27:F5:B0:69:12) [redacted]▂▄▆█
[D][wifi:447]: Channel: 10
[D][wifi:448]: RSSI: -74 dB
[I][wifi:258]: WiFi Connecting to 'SYRION16262'...
[I][wifi:519]: WiFi Connected!
[C][wifi:363]: Local MAC: 30:C6:F7:2C:B3:3C
[C][wifi:364]: SSID: 'SYRION16262'[redacted]
[C][wifi:365]: IP Address: 192.168.254.7
[C][wifi:367]: BSSID: 78:98:E8:34:FA:5A[redacted]
[C][wifi:368]: Hostname: 'esp32-parter'
[C][wifi:370]: Signal strength: -61 dB ▂▄▆█
[C][wifi:374]: Channel: 5
[C][wifi:375]: Subnet: 255.255.255.0
[C][wifi:376]: Gateway: 192.168.254.254
[C][wifi:377]: DNS1: 192.168.254.254
[C][wifi:378]: DNS2: 192.168.254.254
[D][wifi:528]: Disabling AP...
[C][ota:093]: Over-The-Air Updates:
[C][ota:094]: Address: esp32-parter.local:3232
[C][ota:097]: Using Password.
[W][ota:103]: Last Boot was an unhandled reset, will proceed to safe mode in 5 restarts
[C][api:025]: Setting up Home Assistant API server...
[C][sntp:028]: Setting up SNTP...
E (24200) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
E (24200) task_wdt: - loopTask (CPU 1)
E (24200) task_wdt: Tasks currently running:
E (24200) task_wdt: CPU 0: IDLE
E (24200) task_wdt: CPU 1: loopTask
E (24200) task_wdt: Aborting.
Rebooting...
entry 0x400805e4
[C][ota:469]: There have been 6 suspected unsuccessful boot attempts.
[D][wifi:448]: RSSI: -59 dB
[W][ota:103]: Last Boot was an unhandled reset, will proceed to safe mode in 4 restarts
E (23964) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
E (23964) task_wdt: - loopTask (CPU 1)
E (23964) task_wdt: Tasks currently running:
E (23964) task_wdt: CPU 0: IDLE
E (23964) task_wdt: CPU 1: loopTask
E (23964) task_wdt: Aborting.
Rebooting...
entry 0x400805e4
[C][ota:469]: There have been 7 suspected unsuccessful boot attempts.
[D][wifi:448]: RSSI: -60 dB
[D][wifi:448]: RSSI: -70 dB
[C][wifi:370]: Signal strength: -62 dB ▂▄▆█
[W][ota:103]: Last Boot was an unhandled reset, will proceed to safe mode in 3 restarts
E (23958) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
E (23958) task_wdt: - loopTask (CPU 1)
E (23958) task_wdt: Tasks currently running:
E (23958) task_wdt: CPU 0: IDLE
E (23958) task_wdt: CPU 1: loopTask
E (23958) task_wdt: Aborting.
Rebooting...
entry 0x400805e4
[C][ota:469]: There have been 8 suspected unsuccessful boot attempts.
[D][wifi:448]: RSSI: -71 dB
[D][wifi:448]: RSSI: -75 dB
[W][ota:103]: Last Boot was an unhandled reset, will proceed to safe mode in 2 restarts
E (23954) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
E (23954) task_wdt: - loopTask (CPU 1)
E (23954) task_wdt: Tasks currently running:
E (23954) task_wdt: CPU 0: IDLE
E (23954) task_wdt: CPU 1: loopTask
E (23954) task_wdt: Aborting.
Rebooting...
entry 0x400805e4
[C][ota:469]: There have been 9 suspected unsuccessful boot attempts.
[D][wifi:448]: RSSI: -61 dB
[W][ota:103]: Last Boot was an unhandled reset, will proceed to safe mode in 1 restarts
E (23956) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
E (23956) task_wdt: - loopTask (CPU 1)
E (23956) task_wdt: Tasks currently running:
E (23956) task_wdt: CPU 0: IDLE
E (23956) task_wdt: CPU 1: loopTask
E (23956) task_wdt: Aborting.
Rebooting...
entry 0x400805e4
[C][ota:469]: There have been 10 suspected unsuccessful boot attempts.
[E][ota:476]: Boot loop detected. Proceeding to safe mode.
[D][wifi:448]: RSSI: -62 dB
[C][wifi:370]: Signal strength: -63 dB ▂▄▆█
[W][ota:103]: Last Boot was an unhandled reset, will proceed to safe mode in 0 restarts
[I][app:062]: setup() finished successfully!
[I][ota:489]: Waiting for OTA attempt.
[I][app:102]: ESPHome version 2023.4.0 compiled on Apr 24 2023, 23:45:12
[C][wifi:505]: WiFi:
[C][logger:294]: Logger:
[C][logger:295]: Level: DEBUG
[C][logger:296]: Log Baud Rate: 115200
[C][logger:297]: Hardware UART: UART0
[C][captive_portal:088]: Captive Portal:
[C][mdns:108]: mDNS:
[C][mdns:109]: Hostname: esp32-parter
