ESPHome + ESP32 Wroom 32 + Xiaomi HHCCJCY01
Witam, coś mnie podkusiło i postanowiłem uporządkować ESP. Skasowałem wszystko i zacząłem od nowa i tu zonk, coś co działało poprzednio teraz stwarza problemy. Wygląda to tak
  friendly_name: ESPHome02
  board: esp32dev
    type: arduino
esp32_ble_tracker:
# Enable logging
# Enable Home Assistant API
    key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
  password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
  - platform: xiaomi_hhccjcy01
    mac_address: 'xxxxxxxxxxxxx'
    temperature:
      name: "03 Xiaomi HHCCJCY01 Temperature"
    moisture:
      name: "03 Xiaomi HHCCJCY01 Moisture"
    illuminance:
      name: "03 Xiaomi HHCCJCY01 Illuminance"
    conductivity:
      name: "03 Xiaomi HHCCJCY01 Soil Conductivity"
    battery_level:
      name: "03 Xiaomi HHCCJCY01 Battery Level"
    mac_address: 'xxxxxxxxxxxxxxxxx'
    temperature:
      name: "04 Xiaomi HHCCJCY01 Temperature"
    moisture:
      name: "04 Xiaomi HHCCJCY01 Moisture"
    illuminance:
      name: "04 Xiaomi HHCCJCY01 Illuminance"
    conductivity:
      name: "04 Xiaomi HHCCJCY01 Soil Conductivity"
    battery_level:
      name: "04 Xiaomi HHCCJCY01 Battery Level"
  ssid: !secret wifi_ssid
    ssid: "Esphome02 Fallback Hotspot"
    password: "xxxxxxxxxxxx"
captive_portal:
Nie potrafię znaleźć źródła problemu
W logach jest zapis “Component sensor.xiaomi_hhccjcy01 requires component esp32_ble_tracker.”
co to za twór?
INFO ESPHome 2023.9.3
INFO Reading configuration /config/esphome/esphomebz.yaml...
Failed config
sensor.xiaomi_hhccjcy01: [source /config/esphome/esphomebz.yaml:22]
  mac_address: 5c:85:7e:b0:4d:22
  temperature:
    name: 03 Xiaomi HHCCJCY01 Temperature
  moisture:
    name: 03 Xiaomi HHCCJCY01 Moisture
  illuminance:
    name: 03 Xiaomi HHCCJCY01 Illuminance
  conductivity:
    name: 03 Xiaomi HHCCJCY01 Soil Conductivity
sensor.xiaomi_hhccjcy01: [source /config/esphome/esphomebz.yaml:33]
  mac_address: 5C:85:7E:B0:95:DC
  temperature:
    name: 04 Xiaomi HHCCJCY01 Temperature
  moisture:
    name: 04 Xiaomi HHCCJCY01 Moisture
  illuminance:
    name: 04 Xiaomi HHCCJCY01 Illuminance
  conductivity:
    name: 04 Xiaomi HHCCJCY01 Soil Conductivity
xiaomi_ble: None
Component xiaomi_ble requires component esp32_ble_tracker
Cały temat jest tu i zrozumiałem, że nie potrzeba trakera
Zawsze tego wymagał, nie możesz wywaliać z YAMLa czegokolwiek bez sprawdzania dokumentacji
No to źle zrozumiałeś - tracker hub jest integracją nadrzędną - integracja xiaomi ble używa kodu trackera
Ups, jak to naprawić?
Dodać brakującą linijkę aktywującą hub? esp32_ble_tracker:
a skoro porządkujesz kod to zrób to porządnie nie mieszając bloków funkcjonalnych, przykład poniżej, oczywiście wziąłem twój kod i go poprzekładałem, więc jeśli nadal się nie kompiluje to sprawdź dokumentację
# tu masz definicje niezbędne do działania więc są na początku
  board: esp32dev
    type: arduino
# blok dotyczący komunikacji ze światem też na początku
captive_portal:
# Enable logging
# tu się kończy blok wygenerowany przez kreator umożliwiający działanie ESPHome
# więc swój kod dodawaj poniżej
# (chyba że modyfikujesz działanie jakiegoś z komponentów powyżej, to modyfikujesz na swoim miejscu)
# tu aktywujesz hub
esp32_ble_tracker:
# a tuy definiujesz sensory z niego korzystające
    temperature:
    moisture:
    illuminance:
    conductivity:
    battery_level:
    temperature:
    moisture:
    illuminance:
    conductivity:
    battery_level:
Ponadto jeśli nie korzystasz z połączeń aktywnych, to możesz to nieco ulepszyć, tak jak masz to w dokumentacji - dla większości modeli (a może i dla wszystkich?) xiaomi wystarcza nasłuch, czyli połączenie pasywne:
esp32_ble_tracker:
  scan_parameters:
    active: false
Tak to pomogło i wygładziłem to wszystko. Już działa, dzięki za pomoc.
