Sprawdziłem logi w Mosquitto.
Brak informacji o urządzeniu ESPHome.
Poniżej log ze startu Mosquitto:
cont-init: info: running /etc/cont-init.d/mosquitto.sh
[15:19:22] INFO: Setting up user mosha
[15:19:23] INFO: SSL is not enabled
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
services-up: info: copying legacy longrun mosquitto (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
[15:19:25] INFO: Starting NGINX for authentication handling...
[15:19:26] INFO: Starting mosquitto MQTT broker...
1707661166: Loading config file /share/mosquitto/bridge.conf
1707661166: Loading config file /share/mosquitto/mosquitto.conf
2024-02-11 15:19:26: Warning: Mosquitto should not be run as root/administrator.
2024-02-11 15:19:26: mosquitto version 2.0.18 starting
2024-02-11 15:19:26: Config loaded from /etc/mosquitto/mosquitto.conf.
2024-02-11 15:19:26: Loading plugin: /usr/share/mosquitto/go-auth.so
2024-02-11 15:19:26: ├── Username/password checking enabled.
2024-02-11 15:19:26: ├── TLS-PSK checking enabled.
2024-02-11 15:19:26: └── Extended authentication not enabled.
2024-02-11 15:19:26: Opening ipv4 listen socket on port 1883.
2024-02-11 15:19:26: Opening ipv6 listen socket on port 1883.
2024-02-11 15:19:26: Opening websockets listen socket on port 1884.
2024-02-11 15:19:26: Bridge local.beebotte doing local SUBSCRIBE on topic homeassistant/#
2024-02-11 15:19:26: Connecting bridge bridge-khjhgdfgcbvjhhh623364gfrt (mqtt.beebotte.com:1883)
2024-02-11 15:19:26: Bridge beebotte sending CONNECT
2024-02-11 15:19:26: mosquitto version 2.0.18 running
2024-02-11 15:19:26: New connection from 127.0.0.1:50222 on port 1883.
2024-02-11 15:19:26: Client <unknown> disconnected due to protocol error.
2024-02-11 15:19:26: New connection from 172.30.32.1:44499 on port 1883.
i ciąg dalszy już po starcie:
2024-02-11 15:20:32: Bridge local.beebotte doing local SUBSCRIBE on topic homeassistant/#
2024-02-11 15:20:32: Connecting bridge bridge-khjhgdfgcbvjhhh623364gfrt (mqtt.beebotte.com:1883)
2024-02-11 15:20:32: Bridge beebotte sending CONNECT
2024-02-11 15:20:33: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:20:33: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:20:33: Sending PUBLISH to mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:20:33: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:20:33: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:20:33: Sending PUBLISH to mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:20:39: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Vici_wallplug', ... (86 bytes))
2024-02-11 15:20:39: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/Vici_wallplug', ... (86 bytes))
2024-02-11 15:20:39: Sending PUBLISH to mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Vici_wallplug', ... (86 bytes))
2024-02-11 15:20:43: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:20:43: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:20:43: Sending PUBLISH to mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:20:43: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:20:43: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:20:43: Sending PUBLISH to mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:20:53: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:20:53: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:20:53: Sending PUBLISH to mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:20:53: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:20:53: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:20:53: Sending PUBLISH to mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:21:03: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:21:03: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:21:03: Sending PUBLISH to mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:21:03: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:21:03: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:21:03: Sending PUBLISH to mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:21:13: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:21:13: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:21:13: Sending PUBLISH to mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:21:13: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:21:13: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:21:13: Sending PUBLISH to mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:21:23: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:21:23: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:21:23: Sending PUBLISH to mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:21:23: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:21:23: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:21:23: Sending PUBLISH to mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:21:27: Received PINGREQ from 1TrXodH2xzTXLuxvTukxRe
2024-02-11 15:21:27: Sending PINGRESP to 1TrXodH2xzTXLuxvTukxRe
2024-02-11 15:21:30: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/TV_wallplug', ... (87 bytes))
2024-02-11 15:21:30: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/TV_wallplug', ... (87 bytes))
2024-02-11 15:21:30: Sending PUBLISH to mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/TV_wallplug', ... (87 bytes))
2024-02-11 15:21:31: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Vici_wallplug', ... (86 bytes))
2024-02-11 15:21:31: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/Vici_wallplug', ... (86 bytes))
2024-02-11 15:21:31: Sending PUBLISH to mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Vici_wallplug', ... (86 bytes))
2024-02-11 15:21:31: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Okap_wallplug', ... (83 bytes))
2024-02-11 15:21:31: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/Okap_wallplug', ... (83 bytes))
2024-02-11 15:21:31: Sending PUBLISH to mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Okap_wallplug', ... (83 bytes))
2024-02-11 15:21:31: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/pralka_wallplug', ... (88 bytes))
2024-02-11 15:21:31: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/pralka_wallplug', ... (88 bytes))
2024-02-11 15:21:31: Sending PUBLISH to mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/pralka_wallplug', ... (88 bytes))
2024-02-11 15:21:33: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:21:33: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:21:33: Sending PUBLISH to mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:21:33: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:21:33: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:21:33: Sending PUBLISH to mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:21:38: New connection from 172.30.32.2:42732 on port 1883.
2024-02-11 15:21:38: Client <unknown> closed its connection.
2024-02-11 15:21:43: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:21:43: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:21:43: Sending PUBLISH to mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:21:43: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:21:43: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:21:43: Sending PUBLISH to mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1066 bytes))
2024-02-11 15:21:48: Bridge local.beebotte doing local SUBSCRIBE on topic homeassistant/#
2024-02-11 15:21:48: Connecting bridge bridge-khjhgdfgcbvjhhh623364gfrt (mqtt.beebotte.com:1883)
2024-02-11 15:21:48: Bridge beebotte sending CONNECT
2024-02-11 15:21:53: Received PUBLISH from mqttjs_1560d55d (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
2024-02-11 15:21:53: Sending PUBLISH to 1TrXodH2xzTXLuxvTukxRe (d0, q0, r0, m0, 'zigbee2mqtt/Trrmostat_Vici', ... (1067 bytes))
Wyczyściłem też wszystkie wiadomośći w MQTT Explorerze i zrestetowałem Mosquitto żeby sprawdzić połączenie - żadna wiadomość nie została przesłana do beebotte.
