Frigate + ,docker problem z przesyłaniem plików
Witam , frigate zainstalowane w dockerze na proxmox .
Błąd podczas przesyłania na frigate+
2023-06-05 11:53:39.531087777 requests.exceptions.SSLError: HTTPSConnectionPool(host=‘api.frigate.video’, port=443): Max retries exceeded with url: /v1/auth/token (Caused by SSLError(SSLCertVerificationError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self signed certificate (_ssl.c:1123)’)))
2023-06-05 11:53:39.533975526 192.168.1.4 - - [05/Jun/2023:11:53:39 +0000] “POST /api/events/1685965432.799026-4udy92/plus HTTP/1.1” 400 284 “https://dom.drawno.com.pl/events” “Mozilla/5.0 (X11; CrOS x86_64 14541.0.0) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/113.0.0.0 Safari/537.36” “37.47.188.35, 172.30.33.7, 172.30.32.1, 172.30.32.2”
Konfiguracja w portainer ,nie wiem czy w dobrym miejscu wpisany api key?:
version: “3.9”
services:
frigate:
container_name: frigate
privileged: true # this may not be necessary for all setups
restart: unless-stopped
image: Package frigate · GitHub
shm_size: “64mb” # update for your cameras based on calculation above
devices:
- /dev/bus/usb:/dev/bus/usb # passes the USB Coral, needs to be modified for other versions
- /dev/apex_0:/dev/apex_0 # passes a PCIe Coral, follow driver instructions here Get started with the M.2 or Mini PCIe Accelerator | Coral
- /dev/dri/renderD128 # for intel hwaccel, needs to be updated for your hardware
volumes:
- /etc/localtime:/etc/localtime:ro
- /root/frigate/config.yml:/config/config.yml
- /root/frigate/storage:/media/frigate
- type: tmpfs # Optional: 1GB of memory, reduces SSD/SD Card wear
target: /tmp/cache
tmpfs:
ports:
- “5000:5000”
- “8557:8557” # RTSP feeds
- “8556:8556/tcp” # WebRTC over tcp
- “8556:8556/udp” # WebRTC over udp
environment:
FRIGATE_RTSP_PASSWORD: “password”
PLUS_API_KEY: *********
Z Home assistant integracja przez frigate proxy ,sam HA łączy się ze światem przez ngnix proxy
“[SSL: CERTIFICATE_VERIFY_FAILED] weryfikacja certyfikatu nie powiodła się: certyfikat z podpisem własnym” - jakiś element całej integracji/systemu nie ma publicznego certyfikatu tylko tzw. “self signed certificate” dlatego nie dochodzi do połączenia.
“Błąd 400 (bad request) oznacza, że serwer nie przetworzył żądania ze względu na niepoprawną składnię, sformułowanie lub fałszywy routing.” - nie ma czegość takiego jak URL https://<adres-home-assistanta>/events
Nie bardzo wiem jak to naprawić …
