GAMA 150 G15 wM-Bus v 4.x - nodemcu-32s
Może komuś się przyda sprawdzony config YAML do licznika Gama 150 G15.
dashboard_import:
  package_import_url: github://MariuszWoszczynski/WMBUS-reader/WMBUS-reader.yaml@main
  import_full_config: true
substitutions:
  friendly_name: "wmbus-reader"
  friendly_name: "${friendly_name}"
  project:
    version: "1.0"
  # only for RPI
#  compile_process_limit: 1
  board: nodemcu-32s
    type: arduino
external_components:
    components: [ wmbus ]
    refresh: 0d
# Status LED for connection
status_led:
  pin:
    # Blue LED
    number: GPIO02
mdns:
  disabled: false
time:
 - platform: sntp
# Enable logging
  level: DEBUG
# Enable Home Assistant API
    key: "9p2efbtoh/7izZ93LRVsgSXsL1JAoP07YQeoyATI7IE="
  - platform: esphome
  ssid: !secret wifi_ssid
  output_power: 18dB
#  static IP configuration (instead of data from the secret file)
#  manual_ip:
#    static_ip: 192.168.10.200
#    gateway: 192.168.10.1
#    subnet: 255.255.255.0
    ssid: "WMBUS Reader - Fallback Hotspot"
#    password: "password_12345678"
captive_portal:
web_server:
  port: 80
  version: 3
wmbus:
  mosi_pin: GPIO32
  miso_pin: GPIO19
  clk_pin:  GPIO33
  cs_pin:   GPIO23
  gdo0_pin: GPIO22
  gdo2_pin: GPIO21
  frequency: 868.950
  all_drivers: False
  sync_mode: True
  log_all: True
# add more sensors, one without field (name will be used)
  - platform: wmbus
    meter_id: 0x00000000
    type: amiplus
    key: 'xxxxxxxxxxxxxxxxxxxxxxxxxxx'
    sensors:
      - name: "GAMA 150 G15 RSSI"
        field: "rssi"
        accuracy_decimals: 0
        unit_of_measurement: "dBm"
        state_class: "measurement"
        entity_category: "diagnostic"
      - name: "Aktualne zużycie w kw"
        field: "current_power_consumption"
        accuracy_decimals: 1
        unit_of_measurement: "kw"
        device_class: "power"
        icon: "mdi:transmission-tower-import"
      - name: "Całkowite zużycie "
        field: "total_energy_consumption"
        accuracy_decimals: 3
        unit_of_measurement: "kwh"
        device_class: "energy"
      - name: "Całkowite zużycie T1"
        field: "total_energy_consumption_tariff_1"
      - name: "Całkowite zużycie T2"
        field: "total_energy_consumption_tariff_2"
      - name: "Napięcie w sieci"
        field: "voltage_at_phase_1"
        unit_of_measurement: "v"
        device_class: "voltage"
        icon: "mdi:sine-wave"
  - platform: uptime
  - platform: wifi_signal
    update_interval: 60s
  - platform: copy
    source_id: wifi_signal_db
    name: "WiFi signal %"
    filters:
    unit_of_measurement: "%"
text_sensor:
  - platform: wifi_info
    ip_address:
    ssid:
    mac_address:
