HA na RPI5/8GB/M2-512GB Node-RED nie uruchamia się
Cześć Witam wszystkich.
Czy może ktoś mi doradzić co mam zrobić, czemu się nie uruchamia?.
HA najnowszy.
RPI 5 / 8GB / M2-1TB
A jakieś logi pokażesz (wklej jako kod, nie obrazek…)?
Jak ma to zrobić . Jak wysłać?
[21:49:56] FATAL: e[31mSSL with this add-on.e[0m
[21:49:56] FATAL: e[31me[0m
[21:49:56] FATAL: e[31mCheck the add-on manual for more information.e[0m
s6-rc: warning: unable to start service init-nginx: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service nodered: stopping
[21:49:56] INFO: e[32mService Node-RED exited with code 256 (by signal 15)e[0m
s6-rc: info: service nodered successfully stopped
s6-rc: info: service init-nodered: stopping
s6-rc: info: service init-nodered successfully stopped
s6-rc: info: service init-customizations: stopping
s6-rc: info: service init-customizations successfully stopped
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service base-addon-banner: starting
e[34m-----------------------------------------------------------e[0m
e[34m Add-on: Node-REDe[0m
e[34m Flow-based programming for the Internet of Thingse[0m
e[34m Add-on version: 20.2.4e[0m
e[32m You are running the latest version of this add-on.e[0m
e[34m System: Home Assistant OS 17.0 (aarch64 / raspberrypi5-64)e[0m
e[34m Home Assistant Core: 2026.1.2e[0m
e[34m Home Assistant Supervisor: 2026.01.1e[0m
e[34m Please, share the above information when looking for helpe[0m
e[34m or support in, e.g., GitHub, forums or the Discord chat.e[0m
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
[21:49:59] FATAL: e[31me[0m
[21:49:59] FATAL: e[31mSSL has been enabled using the ‘ssl’ option,e[0m
[21:49:59] FATAL: e[31mthis requires an SSL certificate file which ise[0m
[21:49:59] FATAL: e[31mconfigured using the ‘certfile’ option in thee[0m
[21:49:59] FATAL: e[31madd-on configuration.e[0m
[21:49:59] FATAL: e[31mUnfortunately, the file specified in thee[0m
[21:49:59] FATAL: e[31m’certfile’ option does not exist.e[0m
[21:49:59] FATAL: e[31mPlease ensure the certificate file exists ande[0m
[21:49:59] FATAL: e[31mis placed in the ‘/ssl/’ directory.e[0m
[21:49:59] FATAL: e[31mIn case you don’t have SSL yet, consider gettinge[0m
s6-rc: info: service init-nodered successfully started
s6-rc: info: service nodered: starting
[21:49:59] FATAL: e[31man SSL certificate or setting the ‘ssl’ optione[0m
[21:49:59] FATAL: e[31mto ‘false’ in case you are not planning on usinge[0m
s6-rc: info: service nodered successfully started
[21:49:59] FATAL: e[31mSSL with this add-on.e[0m
[21:49:59] FATAL: e[31mCheck the add-on manual for more information.e[0m
[21:49:59] INFO: e[32mService Node-RED exited with code 256 (by signal 15)e[0m
[21:50:03] FATAL: e[31me[0m
[21:50:03] FATAL: e[31mSSL has been enabled using the ‘ssl’ option,e[0m
[21:50:03] FATAL: e[31mthis requires an SSL certificate file which ise[0m
[21:50:03] FATAL: e[31mconfigured using the ‘certfile’ option in thee[0m
[21:50:03] FATAL: e[31madd-on configuration.e[0m
[21:50:03] FATAL: e[31mUnfortunately, the file specified in thee[0m
[21:50:03] FATAL: e[31m’certfile’ option does not exist.e[0m
[21:50:03] FATAL: e[31mPlease ensure the certificate file exists ande[0m
[21:50:03] FATAL: e[31mis placed in the ‘/ssl/’ directory.e[0m
[21:50:03] FATAL: e[31mIn case you don’t have SSL yet, consider gettinge[0m
[21:50:03] FATAL: e[31man SSL certificate or setting the ‘ssl’ optione[0m
[21:50:03] FATAL: e[31mto ‘false’ in case you are not planning on usinge[0m
[21:50:03] FATAL: e[31mSSL with this add-on.e[0m
[21:50:03] FATAL: e[31mCheck the add-on manual for more information.e[0m
[21:50:03] INFO: e[32mService Node-RED exited with code 256 (by signal 15)e[0m
[21:50:07] FATAL: e[31me[0m
[21:50:07] FATAL: e[31mSSL has been enabled using the ‘ssl’ option,e[0m
[21:50:07] FATAL: e[31mthis requires an SSL certificate file which ise[0m
[21:50:07] FATAL: e[31mconfigured using the ‘certfile’ option in thee[0m
[21:50:07] FATAL: e[31madd-on configuration.e[0m
[21:50:07] FATAL: e[31mUnfortunately, the file specified in thee[0m
[21:50:07] FATAL: e[31m’certfile’ option does not exist.e[0m
[21:50:07] FATAL: e[31mPlease ensure the certificate file exists ande[0m
[21:50:07] FATAL: e[31mis placed in the ‘/ssl/’ directory.e[0m
[21:50:07] FATAL: e[31mIn case you don’t have SSL yet, consider gettinge[0m
[21:50:07] FATAL: e[31man SSL certificate or setting the ‘ssl’ optione[0m
[21:50:07] FATAL: e[31mto ‘false’ in case you are not planning on usinge[0m
[21:50:07] FATAL: e[31mSSL with this add-on.e[0m
[21:50:07] FATAL: e[31mCheck the add-on manual for more information.e[0m
[21:50:07] INFO: e[32mService Node-RED exited with code 256 (by signal 15)e[0m
[21:50:11] FATAL: e[31me[0m
[21:50:11] FATAL: e[31mSSL has been enabled using the ‘ssl’ option,e[0m
[21:50:11] FATAL: e[31mthis requires an SSL certificate file which ise[0m
[21:50:11] FATAL: e[31mconfigured using the ‘certfile’ option in thee[0m
[21:50:11] FATAL: e[31madd-on configuration.e[0m
[21:50:11] FATAL: e[31mUnfortunately, the file specified in thee[0m
[21:50:11] FATAL: e[31m’certfile’ option does not exist.e[0m
[21:50:11] FATAL: e[31mPlease ensure the certificate file exists ande[0m
[21:50:11] FATAL: e[31mis placed in the ‘/ssl/’ directory.e[0m
[21:50:11] FATAL: e[31mIn case you don’t have SSL yet, consider gettinge[0m
[21:50:11] FATAL: e[31man SSL certificate or setting the ‘ssl’ optione[0m
[21:50:11] FATAL: e[31mto ‘false’ in case you are not planning on usinge[0m
[21:50:11] FATAL: e[31mSSL with this add-on.e[0m
[21:50:11] FATAL: e[31mCheck the add-on manual for more information.e[0m
[21:50:11] INFO: e[32mService Node-RED exited with code 256 (by signal 15)e[0m
[21:50:15] FATAL: e[31me[0m
[21:50:15] FATAL: e[31mSSL has been enabled using the ‘ssl’ option,e[0m
[21:50:15] FATAL: e[31mthis requires an SSL certificate file which ise[0m
[21:50:15] FATAL: e[31mconfigured using the ‘certfile’ option in thee[0m
[21:50:15] FATAL: e[31madd-on configuration.e[0m
[21:50:15] FATAL: e[31mUnfortunately, the file specified in thee[0m
[21:50:15] FATAL: e[31m’certfile’ option does not exist.e[0m
[21:50:15] FATAL: e[31mPlease ensure the certificate file exists ande[0m
[21:50:15] FATAL: e[31mis placed in the ‘/ssl/’ directory.e[0m
[21:50:15] FATAL: e[31mIn case you don’t have SSL yet, consider gettinge[0m
[21:50:15] FATAL: e[31man SSL certificate or setting the ‘ssl’ optione[0m
[21:50:15] FATAL: e[31mto ‘false’ in case you are not planning on usinge[0m
[21:50:15] FATAL: e[31mSSL with this add-on.e[0m
[21:50:15] FATAL: e[31mCheck the add-on manual for more information.e[0m
[21:50:15] INFO: e[32mService Node-RED exited with code 256 (by signal 15)e[0m
[21:50:19] FATAL: e[31me[0m
[21:50:19] FATAL: e[31mSSL has been enabled using the ‘ssl’ option,e[0m
[21:50:19] FATAL: e[31mthis requires an SSL certificate file which ise[0m
[21:50:19] FATAL: e[31mconfigured using the ‘certfile’ option in thee[0m
[21:50:19] FATAL: e[31madd-on configuration.e[0m
[21:50:19] FATAL: e[31mUnfortunately, the file specified in thee[0m
[21:50:19] FATAL: e[31m’certfile’ option does not exist.e[0m
[21:50:19] FATAL: e[31mPlease ensure the certificate file exists ande[0m
[21:50:19] FATAL: e[31mis placed in the ‘/ssl/’ directory.e[0m
[21:50:19] FATAL: e[31mIn case you don’t have SSL yet, consider gettinge[0m
[21:50:19] FATAL: e[31man SSL certificate or setting the ‘ssl’ optione[0m
[21:50:19] FATAL: e[31mto ‘false’ in case you are not planning on usinge[0m
[21:50:19] FATAL: e[31mSSL with this add-on.e[0m
[21:50:19] FATAL: e[31mCheck the add-on manual for more information.e[0m
[21:50:19] INFO: e[32mService Node-RED exited with code 256 (by signal 15)e[0m
Taki pomysł, wrzuć te logi do dowolnego chata AI i zobacz co Ci odpowie.
Tego nie robiłem???
Sprawdźmy.
Widzę tu błąd SSL to może być od tego. Musisz dopisać w pliku config.
Pomogło. Dokładnie o to chodziło (ssl)!!!
Dzięki
