Podpowiedź prosze gdzie miałeś błąd
Walczę z tym samym i mam dosc
tak, to rozumiem, pytanie gdzie popelnil blad…
ja mam tak i rowniez nie moge dojsc co jest nie tak
setoption19 1 i 0 nie rozwiazuja tematu
mosquitto widzi sprzet:
New client connected from 192.168.0.148 as DVES_AE49FB (p2, c1, k30, u’Posreg’).
Widzi, ale nasłuchuje może na innym temacie.
Użyj programu MQTT Explorer i zobaczysz jak przebiega komunikacja między brokerem a sprzętem Tasmota.
chyba jednak dalej musicie mnie naprowadzic…
dzieki za namiar na apke
oto log:
a to log z konsoli urzadzenia + config urzadzenia
00:00:02 HTP: Web server active on tasmota_AE49FB-2555 with IP address 192.168.0.148
20:39:44 MQT: Attempting connection...
20:39:44 MQT: Connected
20:39:44 MQT: tele/tasmota_AE49FB/LWT = Online (retained)
20:39:44 MQT: cmnd/tasmota_AE49FB/POWER =
20:39:44 MQT: tele/tasmota_AE49FB/INFO1 = {"Module":"SmartDGM Plug","Version":"9.2.0(lite)","FallbackTopic":"cmnd/DVES_AE49FB_fb/","GroupTopic":"cmnd/tasmotas/"}
20:39:44 MQT: tele/tasmota_AE49FB/INFO2 = {"WebServerMode":"Admin","Hostname":"tasmota_AE49FB-2555","IPAddress":"192.168.0.148"}
20:39:44 MQT: tele/tasmota_AE49FB/INFO3 = {"RestartReason":"Software/System restart"}
20:39:44 MQT: stat/tasmota_AE49FB/RESULT = {"POWER":"ON"}
20:39:44 MQT: stat/tasmota_AE49FB/POWER = ON
20:39:47 QPC: Reset
20:39:48 MQT: tele/tasmota_AE49FB/STATE = {"Time":"2021-11-23T20:39:48","Uptime":"0T00:00:09","UptimeSec":9,"Vcc":3.495,"Heap":30,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":36,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"Daros_2.4","BSSId":"98:DA:C4:30:01:A7","Channel":7,"RSSI":100,"Signal":-49,"LinkCount":1,"Downtime":"0T00:00:03"}}
20:39:48 MQT: tele/tasmota_AE49FB/SENSOR = {"Time":"2021-11-23T20:39:48","ENERGY":{"TotalStartTime":"2021-11-23T09:59:25","Total":0.000,"Yesterday":0.000,"Today":0.000,"Period":0,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":274,"Current":0.000}}
"Module": "SmartDGM Plug",
"Version": "9.2.0(lite)",
"FallbackTopic": "cmnd/DVES_AE49FB_fb/",
"GroupTopic": "cmnd/tasmotas/"
Jesli trywialne to wybaczcie, dosc sobie z HA radzilem do tej pory ale tutaj napotkalem sciane
Taka mała uwaga techniczna - tam gdzie możesz nie rób screenshotów, tylko kopiuj i wklejaj logi jako tekst (z takim formatowaniem jak dla kodu, czyli linie z 3x odwrotnym apostrofem).
Masz tasmotę w wersji lite?
to bardzo zle ?
zapalala mi sie lampka jak to zobaczylem, ale jakos poszedlem dalej…
kierowalem sie tym poradnikiem
przy flashowaniu mialem male problemy, stracilem komunikacje (dioda nie reagowala) ale po przytrzymaniu >30 s tuya-convert odpalila
To wgraj pełną wersję lub od razu uaktualnij do najnowszej wersji - najnowsza tasmota to 10.0.0
Należy szukać informacji u źródła:
Pozostaje jeszcze kalibracja:
https://tasmota.github.io/docs/Power-Monitoring-Calibration/
dziekuje Panowie i bije sie w klate!!
6h meczarni i dochodzenia co jest nie tak a wystarczyl upgrade do 10.0.0 + OFICJALNA dokumentacja (jest jak byk aby zrobic upgrade po pierwszym flashowaniu)
Encje pojawily sie doslownie w 5 sekund
