Integracja-Komunikacja modbus RS485 z licznikiem DTS238-7
Jak w tytule chciałbym wykonać integrację z moim licznikiem Hiking Tomzn DTS238-7.
posiadam konwerter RS485-TTL, esp d1_mini oraz dokumentację modbus do licznika.
Planuje wzorować się na kodzie znalezionym na naszym forum lecz do innego licznika:
substitutions:
  devicename: "dtsu-logger"
  friendly_name: DTSU-Logger
  ssid: "xxxx"
  password: "xxx"
    ssid: "dstu666 Fallback Hotspot"
    password: "xxx"
#captive_portal:
# Enable Home Assistant API
    key: "xxx"
  password: "xxx"
# Enable Web server
#web_server:
#  port: 80
  platform: ESP8266
  board: esp07
  board_flash_mode: dout
  comment: DTSU666 Logger (Modbus/RS485)
    level: debug
    baud_rate: 0
uart:
  tx_pin: 1
  rx_pin: 3
  rx_buffer_size: 512
  baud_rate: 9600
  parity: NONE
  data_bits: 8
  stop_bits: 1
modbus:
  send_wait_time: 500ms
  uart_id: uart_to_modbus
modbus_controller:
  - id: dtsu666_modbus_controler
    address: 0x02
    modbus_id: modbus_component_hub
    update_interval: 2s
text_sensor:
    name: "ESP-DTSU Uptime (human readable)"
    icon: "mdi:clock-start"
    update_interval: 5s
# Energia
  - platform: modbus_controller
    modbus_controller_id: dtsu666_modbus_controler
    name: "Energia pobrana z sieci kwh"
    address: 0x101E
    unit_of_measurement: "kWh"
    device_class: "energy"
    register_type: read
    value_type: FP32
    accuracy_decimals: 2
    skip_updates: 12
    filters:
      - multiply: 1
    name: "Energia oddana do sieci kwh"
    address: 0x1028
    register_type: read
    value_type: FP32
    skip_updates: 12
    filters:
      - multiply: 1
# Napięcia
    address: 0x200A
    unit_of_measurement: "V"
    register_type: read
    value_type: FP32
    accuracy_decimals: 1
    filters:
      - multiply: 0.1
    address: 0x2008
    register_type: read
    value_type: FP32
    filters:
      - multiply: 0.1
    address: 0x2006
    register_type: read
    value_type: FP32
    filters:
      - multiply: 0.1
# Prądy
    address: 0x2010
    unit_of_measurement: "A"
    register_type: read
    value_type: FP32
    filters:
      - multiply: 0.001
    address: 0x200E
    register_type: read
    value_type: FP32
    filters:
      - multiply: 0.001
    address: 0x200C
    register_type: read
    value_type: FP32
    filters:
      - multiply: 0.001
  # moc chwilowa
    name: "Moc chwilowa całkowita"
    address: 0x2012
    unit_of_measurement: "W"
    register_type: read
    value_type: FP32
    accuracy_decimals: 0
    filters:
      - multiply: 0.1
    name: "Moc chwilowa L3"
    address: 0x2018
    register_type: read
    value_type: FP32
    filters:
      - multiply: 0.1
    name: "Moc chwilowa L2"
    address: 0x2016
    register_type: read
    value_type: FP32
    filters:
      - multiply: 0.1
    name: "Moc chwilowa L1"
    address: 0x2014
    register_type: read
    value_type: FP32
    filters:
      - multiply: 0.1
# power factor
    address: 0x202A
    unit_of_measurement: "Pf"
    register_type: read
    value_type: FP32
    filters:
      - multiply: 0.001
    name: "Power Factor L1"
    address: 0x202c
    register_type: read
    value_type: FP32
    filters:
      - multiply: 0.001
    name: "Power Factor L2"
    address: 0x202e
    register_type: read
    value_type: FP32
    filters:
      - multiply: 0.001
    name: "Power Factor L3"
    address: 0x2030
    register_type: read
    value_type: FP32
    filters:
      - multiply: 0.001
  # wifi signal
  - platform: wifi_signal
    name: "WiFi Signal DTSU-Logger"
    update_interval: 60s
    icon: "mdi:wifi"
  - platform: uptime
    filters:
      - lambda: return x / 60.0;
    unit_of_measurement: minutes
  - platform: uptime
    update_interval: 5s
    internal: true
    on_raw_value:
      then:
            state: !lambda |-
              int seconds = round(id(uptime_sensor).raw_state);
              seconds = seconds % (24 * 3600);
              int hours = seconds / 3600;
              seconds = seconds % 3600;
              int minutes = seconds /  60;
              seconds = seconds % 60;
              return (
                (hours ? to_string(hours) + "h " : "") +
                (minutes ? to_string(minutes) + "m " : "") +
                (to_string(seconds) + "s")
              ).c_str();
    unit_of_measurement: "%"
    name: "ESP-DTSU WiFi Signal (human readable)"
    update_interval: 30s
    icon: "mdi:wifi"
    lambda: return (-0.0134 * (id(dtsu_wifi_signal).state * id(dtsu_wifi_signal).state ) ) + (-0.2228 * id(dtsu_wifi_signal).state) + 100.2;
# Basic switch to allow you to restart the device remotely
switch:
  - platform: restart
binary_sensor:
  - platform: status
Teraz pytanie czy w wierszach wystarczy pozmieniać adresację tak jak na przykładzie poniżej czy coś jeszcze będę musiał pozmieniać?
Być może parametry transmisji, prawdopodobnie też mnożniki.
Niestety po podmianie adresów na takie jak w instrukcji modbus od mojego licznika encje są niedostępne. logi z esphome wyglądają tak:
[18:24:50][C][uart.arduino_esp8266:102]: UART Bus:
[18:24:50][C][uart.arduino_esp8266:103]: TX Pin: GPIO1
[18:24:50][C][uart.arduino_esp8266:104]: RX Pin: GPIO3
[18:24:50][C][uart.arduino_esp8266:106]: RX Buffer Size: 512
[18:24:50][C][uart.arduino_esp8266:108]: Baud Rate: 9600 baud
[18:24:50][C][uart.arduino_esp8266:109]: Data Bits: 8
[18:24:50][C][uart.arduino_esp8266:110]: Parity: NONE
[18:24:50][C][uart.arduino_esp8266:111]: Stop bits: 1
[18:24:50][C][uart.arduino_esp8266:113]: Using hardware serial interface.
[18:24:50][C][modbus:139]: Modbus:
[18:24:50][C][modbus:141]: Send Wait Time: 500 ms
[18:24:50][C][template.text_sensor:021]: Template Sensor ‘ESP-DTSU Uptime (human readable)’
[18:24:50][C][template.text_sensor:021]: Icon: ‘mdi:clock-start’
[18:24:50][C][uptime.sensor:031]: Uptime Sensor ‘ESP-DTSU Uptime’
[18:24:50][C][uptime.sensor:031]: Device Class: ‘duration’
[18:24:50][C][uptime.sensor:031]: State Class: ‘total_increasing’
[18:24:50][C][uptime.sensor:031]: Unit of Measurement: ‘minutes’
[18:24:50][C][uptime.sensor:031]: Accuracy Decimals: 0
[18:24:50][C][uptime.sensor:031]: Icon: ‘mdi:clock-start’
[18:24:50][C][uptime.sensor:031]: Uptime Sensor ‘DTSU-Logger Uptime’
[18:24:50][C][uptime.sensor:031]: Unit of Measurement: ‘s’
[18:24:50][C][template.sensor:023]: Template Sensor ‘ESP-DTSU WiFi Signal (human readable)’
[18:24:50][C][template.sensor:023]: Device Class: ‘signal_strength’
[18:24:50][C][template.sensor:023]: State Class: ‘’
[18:24:50][C][template.sensor:023]: Unit of Measurement: ‘%’
[18:24:50][C][template.sensor:023]: Accuracy Decimals: 0
[18:24:50][C][template.sensor:023]: Icon: ‘mdi:wifi’
[18:24:50][C][template.sensor:024]: Update Interval: 30.0s
[18:24:50][C][modbus_controller:275]: ModbusController:
[18:24:50][C][modbus_controller:276]: Address: 0x04
[18:24:50][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=0 count=6
[18:24:50][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8 count=6
[18:24:50][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8210 count=2
[18:24:50][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8234 count=8
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor ‘Energia pobrana z sieci kwh’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensor Device Class: ‘energy’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensor State Class: ‘total_increasing’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensor Unit of Measurement: ‘kWh’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensor Accuracy Decimals: 2
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor ‘NapiÄ™cie L3’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensor State Class: ‘’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensor Unit of Measurement: ‘V’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensor Accuracy Decimals: 1
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor ‘NapiÄ™cie L2’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor ‘NapiÄ™cie L1’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor ‘PrÄ…d L3’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensor Unit of Measurement: ‘A’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor ‘PrÄ…d L2’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor ‘PrÄ…d L1’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor ‘Moc chwilowa caĹ‚kowita’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensor Unit of Measurement: ‘W’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensor Accuracy Decimals: 0
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor ‘Moc chwilowa L3’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor ‘Moc chwilowa L2’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor ‘Moc chwilowa L1’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor ‘Power Factor’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensor Unit of Measurement: ‘Pf’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor ‘Power Factor L1’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor ‘Power Factor L2’
[18:24:50][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor ‘Power Factor L3’
[18:24:50][C][restart:076]: Restart Switch ‘DTSU-Loger Restart’
[18:24:50][C][restart:078]: Icon: ‘mdi:restart’
[18:24:50][C][restart:098]: Restore Mode: restore defaults to OFF
[18:24:50][C][status:034]: Status Binary Sensor ‘DTSU-Loger Status’
[18:24:50][C][status:034]: Device Class: ‘connectivity’
[18:24:50][C][mdns:103]: mDNS:
[18:24:50][C][mdns:104]: Hostname: dtsu-logger
[18:24:50][C][ota:093]: Over-The-Air Updates:
[18:24:50][C][ota:094]: Address: dtsu-logger.local:8266
[18:24:50][C][ota:097]: Using Password.
[18:24:50][C][api:138]: API Server:
[18:24:50][C][api:139]: Address: dtsu-logger.local:6053
[18:24:50][C][api:141]: Using noise encryption: YES
[18:24:50][C][wifi_signal.sensor:009]: WiFi Signal ‘WiFi Signal DTSU-Logger’
[18:24:50][C][wifi_signal.sensor:009]: Device Class: ‘signal_strength’
[18:24:50][C][wifi_signal.sensor:009]: State Class: ‘measurement’
[18:24:50][C][wifi_signal.sensor:009]: Unit of Measurement: ‘dBm’
[18:24:50][C][wifi_signal.sensor:009]: Accuracy Decimals: 0
[18:24:50][C][wifi_signal.sensor:009]: Icon: ‘mdi:wifi’
[18:24:52][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=0 count=6
[18:24:52][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8 count=6
[18:24:52][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=42 count=6
[18:24:52][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8210 count=2
[18:24:52][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8234 count=8
[18:24:52][D][modbus_controller:029]: Modbus command to device=4 register=0x2012 countdown=0 no response received - removed from send queue
[18:24:53][D][text_sensor:067]: ‘ESP-DTSU Uptime (human readable)’: Sending state ‘1m 44s’
[18:24:53][D][sensor:126]: ‘DTSU-Logger Uptime’: Sending state 103.68400 s with 0 decimals of accuracy
[18:24:54][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=0 count=6
[18:24:54][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8 count=6
[18:24:54][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=42 count=6
[18:24:54][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8234 count=8
[18:24:55][D][modbus_controller:029]: Modbus command to device=4 register=0x202A countdown=0 no response received - removed from send queue
[18:24:56][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=0 count=6
[18:24:56][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8 count=6
[18:24:56][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=42 count=6
[18:24:56][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8210 count=2
[18:24:57][D][modbus_controller:029]: Modbus command to device=4 register=0x00 countdown=0 no response received - removed from send queue
[18:24:57][D][text_sensor:067]: ‘ESP-DTSU Uptime (human readable)’: Sending state ‘1m 49s’
[18:24:57][D][sensor:126]: ‘DTSU-Logger Uptime’: Sending state 108.67900 s with 0 decimals of accuracy
[18:24:58][D][text_sensor:067]: ‘ESP-DTSU Uptime (human readable)’: Sending state ‘1m 49s’
[18:24:58][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8 count=6
[18:24:58][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=42 count=6
[18:24:58][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8210 count=2
[18:24:58][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8234 count=8
[18:24:59][D][sensor:126]: ‘ESP-DTSU Uptime’: Sending state 1.84135 minutes with 0 decimals of accuracy
[18:25:00][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=0 count=6
[18:25:00][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8 count=6
[18:25:00][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=42 count=6
[18:25:00][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8210 count=2
[18:25:00][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8234 count=8
[18:25:00][D][modbus_controller:029]: Modbus command to device=4 register=0x1010 countdown=0 no response received - removed from send queue
[18:25:02][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=0 count=6
[18:25:02][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8 count=6
[18:25:02][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=42 count=6
[18:25:02][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8210 count=2
[18:25:02][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8234 count=8
[18:25:02][D][modbus_controller:029]: Modbus command to device=4 register=0x08 countdown=0 no response received - removed from send queue
[18:25:03][D][text_sensor:067]: ‘ESP-DTSU Uptime (human readable)’: Sending state ‘1m 54s’
[18:25:03][D][sensor:126]: ‘DTSU-Logger Uptime’: Sending state 113.69300 s with 0 decimals of accuracy
[18:25:04][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=0 count=6
[18:25:04][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=42 count=6
[18:25:04][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8210 count=2
[18:25:04][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8234 count=8
[18:25:05][D][modbus_controller:029]: Modbus command to device=4 register=0x2A countdown=0 no response received - removed from send queue
[18:25:06][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=0 count=6
[18:25:06][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8 count=6
[18:25:06][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8210 count=2
[18:25:06][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8234 count=8
[18:25:07][D][text_sensor:067]: ‘ESP-DTSU Uptime (human readable)’: Sending state ‘1m 59s’
[18:25:07][D][sensor:126]: ‘DTSU-Logger Uptime’: Sending state 118.67900 s with 0 decimals of accuracy
[18:25:08][D][text_sensor:067]: ‘ESP-DTSU Uptime (human readable)’: Sending state ‘1m 59s’
[18:25:08][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=0 count=6
[18:25:08][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8 count=6
[18:25:08][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=42 count=6
[18:25:08][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8210 count=2
[18:25:08][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8234 count=8
[18:25:08][D][modbus_controller:029]: Modbus command to device=4 register=0x2012 countdown=0 no response received - removed from send queue
[18:25:10][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=0 count=6
[18:25:10][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8 count=6
[18:25:10][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=42 count=6
[18:25:10][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8234 count=8
[18:25:10][D][modbus_controller:029]: Modbus command to device=4 register=0x202A countdown=0 no response received - removed from send queue
[18:25:12][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=0 count=6
[18:25:12][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8 count=6
[18:25:12][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=42 count=6
[18:25:12][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8210 count=2
[18:25:12][D][text_sensor:067]: ‘ESP-DTSU Uptime (human readable)’: Sending state ‘2m 4s’
[18:25:13][D][sensor:126]: ‘DTSU-Logger Uptime’: Sending state 123.68600 s with 0 decimals of accuracy
[18:25:13][D][text_sensor:067]: ‘ESP-DTSU Uptime (human readable)’: Sending state ‘2m 4s’
[18:25:13][D][modbus_controller:029]: Modbus command to device=4 register=0x00 countdown=0 no response received - removed from send queue
[18:25:14][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8 count=6
[18:25:14][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=42 count=6
[18:25:14][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8210 count=2
[18:25:14][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8234 count=8
[18:25:15][D][sensor:126]: ‘ESP-DTSU WiFi Signal (human readable)’: Sending state 68.04480 % with 0 decimals of accuracy
[18:25:15][D][modbus_controller:029]: Modbus command to device=4 register=0x08 countdown=0 no response received - removed from send queue
[18:25:16][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=0 count=6
[18:25:16][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=42 count=6
[18:25:16][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8210 count=2
[18:25:16][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8234 count=8
[18:25:17][D][text_sensor:067]: ‘ESP-DTSU Uptime (human readable)’: Sending state ‘2m 9s’
[18:25:17][D][sensor:126]: ‘DTSU-Logger Uptime’: Sending state 128.68201 s with 0 decimals of accuracy
[18:25:18][D][text_sensor:067]: ‘ESP-DTSU Uptime (human readable)’: Sending state ‘2m 9s’
[18:25:18][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=0 count=6
[18:25:18][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8 count=6
[18:25:18][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=42 count=6
[18:25:18][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8210 count=2
[18:25:18][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8234 count=8
[18:25:18][D][modbus_controller:029]: Modbus command to device=4 register=0x2A countdown=0 no response received - removed from send queue
[18:25:20][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=0 count=6
[18:25:20][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8 count=6
[18:25:20][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8210 count=2
[18:25:20][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8234 count=8
[18:25:21][D][modbus_controller:029]: Modbus command to device=4 register=0x2012 countdown=0 no response received - removed from send queue
[18:25:22][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=0 count=6
[18:25:22][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8 count=6
[18:25:22][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=42 count=6
[18:25:22][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=8234 count=8
[18:25:22][D][text_sensor:067]: ‘ESP-DTSU Uptime (human readable)’: Sending state ‘2m 14s’
[18:25:22][D][sensor:126]: ‘DTSU-Logger Uptime’: Sending state 133.67900 s with 0 decimals of accuracy
[18:25:23][D][text_sensor:067]: ‘ESP-DTSU Uptime (human readable)’: Sending state ‘2m 14s’
[18:25:23][D][modbus_controller:029]: Modbus command to device=4 register=0x1010 countdown=0 no response received - removed from send queue
[18:25:24][W][modbus_controller:112]: Duplicate modbus command found: type=0x4 address=0 count=6
W instrukcji znalazłem jeszcze taki opis do modbus:
Przechwytywanie8
Jakaś podpowiedź który parametr muszę poprawić?
Witam. Czy dało się skomunikować z licznikiem DTS? Walczę także w tej materii bez powodzenia i wydaje mi się że wyważam otwarte drzwi. Jeśli masz rozwiązanie to poroszę o podpowiedź :slight_smile:
Dostałem kolejne kody od producenta i próbowałem odczytywać licznik za pomocą oprogramowania do modbus. Niesyty większość z nich nie działa. Producent przestał mi odpisywać więc temat umarł.
Bardzo ogólnie oznacza tyle, że do kolejki wpisujesz kolejną, taką samą komendę a poprzednia nie została obsłużona. Np. za często wysyłasz zapytanie lub jakieś “timeout” jest niewłaściwy.
Nie rozwiązuj równania z dwiema niewiadomymi na raz (licznik i ESPHome).
Na początek “naucz” się licznika podłączając go do PC przez zwykły konwerter USB<>RS485.
Tak też zrobiłem, że PC z licznikiem. Okazało się, że komendy otrzymane od producenta nie działają. Udało mi się odczytać tylko nie liczne dane
Pokaż jak to robisz i czego nie możesz odczytać.
Oficjalne dane.
DTS 238-7 Manual RS485 Modbus Protokol.zip (254,6 KB)
