Komenda ssh zmieniająca podświetlenie tabletu
Witam potrzebuje zautomatyzować podświetlenie tabletu, który służy jako wallpanel do HA.
        "id": "7cb4e1420a0c4077",
        "type": "tab",
        "label": "Podświetlenie_tabletu",
        "disabled": false,
        "info": "",
        "env": []
        "id": "5e56ab05b656c991",
        "type": "inject",
        "z": "7cb4e1420a0c4077",
        "name": "Co 10 minut",
        "props": [
                "p": "payload"
        "repeat": "600",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "{}",
        "payloadType": "json",
        "x": 140,
        "y": 80,
        "wires": [
                "e3e41119e4202f16"
        "id": "e3e41119e4202f16",
        "type": "api-current-state",
        "name": "Sprawdź zachód słońca",
        "server": "f8e3f945.af0568",
        "version": 3,
        "outputs": 1,
        "halt_if": "",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "entity_id": "sun.sun",
        "state_type": "str",
        "blockInputOverrides": true,
        "outputProperties": [
                "property": "payload",
                "propertyType": "msg",
                "value": "string",
                "valueType": "entityState"
                "property": "data",
                "value": "",
                "valueType": "entity"
        "for": "0",
        "forType": "num",
        "forUnits": "minutes",
        "override_topic": false,
        "state_location": "payload",
        "override_payload": "msg",
        "entity_location": "data",
        "override_data": "msg",
        "x": 290,
        "y": 240,
        "wires": [
                "b917521123998984"
        "id": "b917521123998984",
        "type": "function",
        "name": "Ustaw podświetlenie",
        "func": "let brightness = 0;\n\nif (msg.payload === \"below_horizon\") {\n    brightness = 0.25;\n} else {\n    brightness = 0.5;\n}\n\nmsg.payload =\n    `ssh -o StrictHostKeyChecking=no -o UserKnownHostsFile=/dev/null kiosk@192.168.10.106 ` +\n    `'sudo -u kiosk DISPLAY=:0 xrandr --output eDP-1 --brightness ${brightness}'`;\n\nnode.warn(\"Komenda wysyłana do exec: \" + msg.payload);\n\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 520,
        "y": 80,
        "wires": [
                "5104ecd85c46462d"
        "id": "5104ecd85c46462d",
        "type": "exec",
        "command": "/bin/bash",
        "addpay": "payload",
        "append": "which ssh",
        "useSpawn": "false",
        "timer": "",
        "winHide": false,
        "oldrc": false,
        "name": "",
        "x": 680,
        "y": 240,
        "wires": [
        "id": "f8e3f945.af0568",
        "type": "server",
        "name": "Home Assistant",
        "addon": true
        "id": "7c0b9f6fe3bd533c",
        "type": "global-config",
        "env": [],
        "modules": {
            "node-red-contrib-home-assistant-websocket": "0.80.3"
w exec dostaję error126. Komenda ssh -o StrictHostKeyChecking=no -o UserKnownHostsFile=/dev/null kiosk@192.168.10.106 "sudo -u kiosk DISPLAY=:0 xrandr --output eDP-1 --brightness 0.5" z terminala HA działa ok.
Zapewne brak odpowiednich uprawnień, error126 odczyt,wykonanie…
Sorki, ale nie bardzo rozumiem jakich uprawnień (dla kogo i do czego), skoro komendy działają w terminalu HA?
Dla tego kto chce się połączyć po SSH. W tym wypadku mamy tylko dużo domysłów, bo praktycznie widać, że temat jest przypisany przez ciebie do kategorii NR i chcesz z niego jak sądzę po kodzie json, sterować tabletem z jakąś aplikacją zapewne. Jeśli wywołana komenda z terminala HA działa, to wywoływanie takiej komendy z osobnego bytu jakim jest NR potrzebuje uwierzytelnienia aby komunikacja została dopuszczona po SSH. Jak to zrobić musisz doczytać z uwzględnieniem własnej konfiguracji, której tu nie znamy. Nie używam NR i tym bardziej nie czuję się kompetentny w tej kwestii. Generalnie chodzi o podstawy komunikacji po SSH, czyli uprawnienia i klucze pomiędzy nadawcą i odbiorcą.
A jakie znaczenie ma to gdzie ta komenda (ssh) trafia??? Istotne jest to że działa (także z poziomu HA na którym jest zainstalowany NR).
Ale NR jest zupełnie obcym bytem (kontenerem Docker) działającym niezależnie od HA Core i dla komunikacji SSH to jak byś łączył się z innego komputera/serwera. To, że coś jest na jednym serwerze nie oznacza, że jest jednym, wspólnym oprogramowaniem.
Ok, ale jakie znaczenie ma punkt docelowy komendy ssh??? Wg mnie żadne, tylko dodanie kluczy ssh do NR w HA, a tego nie potrafię.
Zrezygnowałem z noda “exec” i skorzystałem z “ssh-v3”.
Pozdrawiam
Jak już kolega @angler ci wyjaśnił HA i NR to zupełnie inne kontenery, to że HA i NR się widzą, i komunikują, to wymagają do tego mostów w postaci node-red-contrib-home-assistant-websocket Node-RED Companion i żadne uprawnienia w postaci ssh o których mówisz nie są między nimi przekazywane.
