Komponent wM-Bus do ESPHome (SzczepanLeon) wersja 3.x - wątek ogólny
działa jak natura chciała:)
dzięki za pomoc
czy wersji 3.2.3 jest kompatybilna z nową wersją ESPHome ?, dostaję takie błędy jak poniżej. Tylko wersja 4 będzie wspierana? gdyż 4 przechodzi kompilację bez problemu.
INFO ESPHome 2025.2.0
INFO Reading configuration /config/esphome/sihbeta.yaml...
ERROR Unexpected exception while reading configuration:
  File "/usr/local/bin/esphome", line 8, in <module>
    sys.exit(main())
  File "/esphome/esphome/__main__.py", line 1049, in main
    return run_esphome(sys.argv)
  File "/esphome/esphome/__main__.py", line 1027, in run_esphome
    config = read_config(dict(args.substitution) if args.substitution else {})
  File "/esphome/esphome/config.py", line 1095, in read_config
    res = load_config(command_line_substitutions)
  File "/esphome/esphome/config.py", line 949, in load_config
    return _load_config(command_line_substitutions)
  File "/esphome/esphome/config.py", line 939, in _load_config
    return validate_config(config, command_line_substitutions)
  File "/esphome/esphome/config.py", line 835, in validate_config
    target_platform = core_config.preload_core_config(config, result)
  File "/esphome/esphome/core/config.py", line 222, in preload_core_config
    if _is_target_platform(domain):
  File "/esphome/esphome/core/config.py", line 184, in _is_target_platform
    if get_component(name, True).is_target_platform:
  File "/esphome/esphome/loader.py", line 205, in get_component
    return _lookup_module(domain, exception)
  File "/esphome/esphome/loader.py", line 181, in _lookup_module
    module = importlib.import_module(f"esphome.components.{domain}")
  File "/usr/lib/python3.11/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1206, in _gcd_import
  File "<frozen importlib._bootstrap>", line 1178, in _find_and_load
  File "<frozen importlib._bootstrap>", line 1149, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 690, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 940, in exec_module
  File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
  File "/data/external_components/0e75e1a4/components/wmbus/__init__.py", line 62, in <module>
    cv.Required(CONF_IP_ADDRESS): cv.ipv4,
AttributeError: module 'esphome.config_validation' has no attribute 'ipv4'
Info jest kilka postów wyżej
zmień konfigurację (zamiast linka do konkretnego wydania 2.x i 3.x jest link do brancha)
faktycznie odnosiłem się do konkretnej wersji oprogramowania i to był błąd, dzięki wielkie.
Po ostatniej aktualizacji esphome Mam problem z aktualizacją wodomierza. Ktoś ma podobny problem??
Poniżej log.
INFO Reading configuration /config/esphome/wodomierz.yaml...
INFO Updating https://github.com/SzczepanLeon/esphome-components.git@3.2.3
    sys.exit(main())
@Spatz
Nie ten wątek, używasz chyba jakiegoś komponentu niestandardowego.
Tzn. nie chyba tylko na pewno.
Ale tak działało od początku z rok albo i dłużej. Teraz przy aktualizacji coś wysypało. Masz może poprawny kod?? Możesz udostępnić?
Dobra zlituję się i przeniosę te posty gdzie należy…
Zrobione, czytaj wyżej, czy to był problem przejrzeć kilka wątków ze świeżymi postami?
Błąd nie wiem czy wina komponentu Szczepana czy składni esp
INFO Reading configuration /config/esphome/licznik.yaml...
    sys.exit(main())
Nie no, przeczytaj chociaż parę postów wyżej.
Wiem.breaking change ale co dalej dobra juz rozumiem podmiana
    refresh: 0dexternal_components:
  - source: github://SzczepanLeon/esphome-components@version_3
    refresh: 0d
    components: [ wmbus ]
czyli że wersja 3 bez podawania nr
czy nadal obowiazuje ta konfuguracja ?
  friendly_name: Woda
  min_version: 2024.6.0
  name_add_mac_suffix: false
  project:
    version: dev
  board: esp32dev
    type: arduino
# Enable logging
# Enable Home Assistant API
# Allow Over-The-Air updates
- platform: esphome
# Allow provisioning Wi-Fi via serial
improv_serial:
  ssid: !secret wifi_ssid
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
# To have a "next url" for improv serial
web_server:
    refresh: 0d
time:
  - platform: sntp
wmbus:
  mosi_pin: GPIO13  # blue
  clk_pin:  GPIO14  # purple
  miso_pin: GPIO12  # green
  gdo2_pin: GPIO22  # gray
  gdo0_pin: GPIO21  # yellow
  cs_pin:   GPIO15  # orange
  frequency: 868.950
  - platform: wmbus
    meter_id: 0x07676659
    type: apator162
    lqi:
    rssi:
    total_water_m3:
Jeśli nie zmieniasz wersji generacji komponentu to raczej tak, ale najlepiej by potwierdził autor.
Na ESP32 nie ma powodu by siedzieć na starej wersji - zmień konfigurację i przejdź na 4.x
Brak pamięci jak chce 4.1 .
Nadal brak odświeżania stan woda nieznany już głupieje czy znowu wina zasięgu czy źle utworzone sensory
@oomichalekoo
Jak nie zamieścisz loga i YAMLa to trudno doradzić.
Nadal po tej zmianie na veesion_3 nie czyta wody
INFO Updating https://github.com/SzczepanLeon/esphome-components.git@version_3
WARNING GPIO12 is a strapping PIN and should only be used for I/O with care.
WARNING GPIO15 is a strapping PIN and should only be used for I/O with care.
INFO Starting log output from 192.168.1.166 using esphome API
INFO Successfully connected to woda-szczepan @ 192.168.1.166 in 0.119s
INFO Successful handshake with woda-szczepan @ 192.168.1.166 in 0.026s
[18:56:50][I][app:100]: ESPHome version 2025.2.0 compiled on Feb 23 2025, 18:09:45
[18:56:50][I][app:102]: Project esphome.web version dev
[18:56:50][C][wifi:600]: WiFi:
[18:56:50][C][wifi:428]:   Local MAC: 94:E6:86:3B:EA:FC
[18:56:50][C][wifi:433]:   SSID: [redacted]
[18:56:50][C][wifi:436]:   IP Address: 192.168.1.166
[18:56:50][C][wifi:440]:   BSSID: [redacted]
[18:56:50][C][wifi:441]:   Hostname: 'woda-szczepan'
[18:56:50][C][wifi:443]:   Signal strength: -50 dB ▂▄▆█
[18:56:50][C][wifi:447]:   Channel: 7
[18:56:50][C][wifi:448]:   Subnet: 255.255.255.0
[18:56:50][C][wifi:449]:   Gateway: 192.168.1.1
[18:56:50][C][wifi:450]:   DNS1: 192.168.1.1
[18:56:50][C][wifi:451]:   DNS2: 0.0.0.0
[18:56:50][C][logger:177]: Logger:
[18:56:50][C][logger:178]:   Max Level: DEBUG
[18:56:50][C][logger:179]:   Initial Level: DEBUG
[18:56:50][C][logger:181]:   Log Baud Rate: 115200
[18:56:50][C][logger:182]:   Hardware UART: UART0
[18:56:50][C][captive_portal:089]: Captive Portal:
[18:56:50][C][web_server:153]: Web Server:
[18:56:50][C][web_server:154]:   Address: woda-szczepan.local:80
[18:56:50][C][sntp:042]: SNTP Time:
[18:56:50][C][sntp:045]:   Server 0: '0.pool.ntp.org'
[18:56:50][C][sntp:045]:   Server 1: '1.pool.ntp.org'
[18:56:50][C][sntp:045]:   Server 2: '2.pool.ntp.org'
[18:56:50][C][mdns:116]: mDNS:
[18:56:50][C][mdns:117]:   Hostname: woda-szczepan
[18:56:50][C][esphome.ota:073]: Over-The-Air updates:
[18:56:50][C][esphome.ota:074]:   Address: woda-szczepan.local:3232
[18:56:50][C][esphome.ota:075]:   Version: 2
[18:56:50][C][safe_mode:018]: Safe Mode:
[18:56:50][C][safe_mode:020]:   Boot considered successful after 60 seconds
[18:56:50][C][safe_mode:021]:   Invoke after 10 boot attempts
[18:56:50][C][safe_mode:023]:   Remain in safe mode for 300 seconds
[18:56:50][C][api:140]: API Server:
[18:56:50][C][api:141]:   Address: woda-szczepan.local:6053
[18:56:50][C][api:145]:   Using noise encryption: NO
[18:56:50][C][improv_serial:032]: Improv Serial:
[18:56:50][C][wmbus:372]: wM-Bus v3.3.0:
[18:56:50][C][wmbus:389]:   CC1101 frequency: 868.950 MHz
[18:56:50][C][wmbus:390]:   CC1101 SPI bus:
[18:56:50][C][wmbus:391]:     MOSI Pin: GPIO13
[18:56:50][C][wmbus:392]:     MISO Pin: GPIO12
[18:56:50][C][wmbus:393]:     CLK Pin:  GPIO14
[18:56:50][C][wmbus:394]:     CS Pin:   GPIO15
[18:56:50][C][wmbus:395]:     GDO0 Pin: GPIO21
[18:56:50][C][wmbus:396]:     GDO2 Pin: GPIO22
[18:56:50][C][wmbus:403]:   Available drivers:  amiplus, apator08, apator162, apatoreitn, bmeters, c5isf, compact5, dme07, elf, evo868, fhkvdataiii, flowiq2200, hydrocalm3, hydrus, iperl, itron, izar, kamheat, mkradio3, mkradio4, mkradio4a, multical21, qheat, qwater, rfmtx1, sharky774, topaseskr, ultrimis, unismart, vario451
[18:56:50][C][wmbus:421]:   Meter:
[18:56:50][C][wmbus:422]:     ID: 110454361 [0x06956659]
[18:56:50][C][wmbus:423]:     Type: apator162
[18:56:50][C][wmbus:424]:     Mode: T1
[18:56:50][C][wmbus:425]:     Key: '00000000000000000000000000000000'
[18:56:50][C][wmbus:427]:     Sensor '0x6956659 My_lqi'
[18:56:50][C][wmbus:427]:       Device Class: 'signal_strength'
[18:56:50][C][wmbus:427]:       State Class: 'measurement'
[18:56:50][C][wmbus:427]:       Unit of Measurement: ''
[18:56:50][C][wmbus:427]:       Accuracy Decimals: 0
[18:56:50][C][wmbus:427]:     Sensor '0x6956659 My_RSSI'
[18:56:50][C][wmbus:427]:       Unit of Measurement: 'dBm'
[18:56:50][C][wmbus:427]:     Sensor '0x6956659 Woda'
[18:56:50][C][wmbus:427]:       Device Class: 'water'
[18:56:50][C][wmbus:427]:       State Class: 'total_increasing'
[18:56:50][C][wmbus:427]:       Unit of Measurement: 'm³'
[18:56:50][C][wmbus:427]:       Accuracy Decimals: 3
[18:56:50][C][wmbus:427]:       Icon: 'mdi:water'
Po zmianie z czego?
Może woda nic nie nadaje?
Skoro masz ESP32 i brakuje pamięci to wywal niewykorzystywane drivery.
6 postów zostało scalonych z istniejącym tematem: Komponent wM-Bus do ESPHome (SzczepanLeon) wersja 4.x - wątek ogólny
Cześć, nie potrafię sobie poradzić z odczytamy licznika izar nie znajduje mi nawet id.
Logs wmbus.yaml
INFO ESPHome 2024.12.4
INFO Reading configuration /config/esphome/wmbus.yaml…
INFO Starting log output from wmbus.local using esphome API
WARNING Can’t connect to ESPHome API for wmbus.local: Error resolving IP address: [Errno -5] No address associated with hostname (APIConnectionError)
INFO Trying to connect to wmbus.local in the background
INFO Successfully connected to wmbus @ 192.168.1.123 in 0.006s
INFO Successful handshake with wmbus @ 192.168.1.123 in 3.622s
[10:48:34][I][app:100]: ESPHome version 2024.12.4 compiled on Mar 4 2025, 10:47:45
[10:48:34][C][wifi:600]: WiFi:
[10:48:34][C][wifi:428]: Local MAC: 3C:61:05:D1:5E:8B
[10:48:34][C][wifi:433]: SSID: [redacted]
[10:48:34][C][wifi:436]: IP Address: 192.168.1.123
[10:48:34][C][wifi:439]: BSSID: [redacted]
[10:48:34][C][wifi:441]: Hostname: ‘wmbus’
[10:48:34][C][wifi:443]: Signal strength: 0 dB ▂▄▆█
[10:48:34][V][wifi:445]: Priority: 0.0
[10:48:34][C][wifi:447]: Channel: 11
[10:48:34][C][wifi:448]: Subnet: 255.255.255.0
[10:48:34][C][wifi:449]: Gateway: 192.168.1.2
[10:48:34][C][wifi:450]: DNS1: 192.168.1.2
[10:48:34][C][wifi:451]: DNS2: 0.0.0.0
[10:48:34][C][logger:185]: Logger:
[10:48:34][C][logger:186]: Level: VERY_VERBOSE
[10:48:34][C][logger:188]: Log Baud Rate: 115200
[10:48:34][C][logger:189]: Hardware UART: UART0
[10:48:34][C][captive_portal:089]: Captive Portal:
[10:48:34][C][sntp:042]: SNTP Time:
[10:48:34][C][sntp:045]: Server 0: ‘0.pool.ntp.org
[10:48:34][C][sntp:045]: Server 1: ‘1.pool.ntp.org
[10:48:34][C][sntp:045]: Server 2: ‘2.pool.ntp.org
[10:48:34][C][mdns:116]: mDNS:
[10:48:34][C][mdns:117]: Hostname: wmbus
[10:48:34][V][mdns:118]: Services:
[10:48:34][V][mdns:120]: - _esphomelib, _tcp, 6053
[10:48:34][V][mdns:122]: TXT: friendly_name = wmbus
[10:48:34][V][mdns:122]: TXT: version = 2024.12.4
[10:48:34][V][mdns:122]: TXT: mac = 3c6105d15e8b
[10:48:34][V][mdns:122]: TXT: platform = ESP8266
[10:48:34][V][mdns:122]: TXT: board = nodemcuv2
[10:48:34][V][mdns:122]: TXT: network = wifi
[10:48:34][V][mdns:122]: TXT: api_encryption = Noise_NNpsk0_25519_ChaChaPoly_SHA256
[10:48:34][C][esphome.ota:073]: Over-The-Air updates:
[10:48:34][C][esphome.ota:074]: Address: wmbus.local:8266
[10:48:34][C][esphome.ota:075]: Version: 2
[10:48:34][C][esphome.ota:078]: Password configured
[10:48:34][C][safe_mode:018]: Safe Mode:
[10:48:34][C][safe_mode:019]: Boot considered successful after 60 seconds
[10:48:35][C][safe_mode:021]: Invoke after 10 boot attempts
[10:48:35][C][safe_mode:022]: Remain in safe mode for 300 seconds
[10:48:35][C][api:140]: API Server:
[10:48:35][C][api:141]: Address: wmbus.local:6053
[10:48:35][C][api:143]: Using noise encryption: YES
[10:48:35][C][wmbus:372]: wM-Bus v3.2.3:
[10:48:35][C][wmbus:385]: LED:
[10:48:35][C][wmbus:386]: Pin: GPIO0
[10:48:35][C][wmbus:387]: Duration: 1000 ms
[10:48:35][C][wmbus:389]: CC1101 frequency: 868.950 MHz
[10:48:35][C][wmbus:390]: CC1101 SPI bus:
[10:48:35][C][wmbus:391]: MOSI Pin: GPIO13
[10:48:35][C][wmbus:392]: MISO Pin: GPIO12
[10:48:35][C][wmbus:393]: CLK Pin: GPIO14
[10:48:35][C][wmbus:394]: CS Pin: GPIO2
[10:48:35][C][wmbus:395]: GDO0 Pin: GPIO5
[10:48:35][C][wmbus:396]: GDO2 Pin: GPIO4
[10:48:35][C][wmbus:403]: Available drivers: amiplus, apator08, apator162, apatoreitn, bmeters, c5isf, compact5, dme07, elf, evo868, fhkvdataiii, flowiq2200, hydrocalm3, hydrus, iperl, itron, izar, kamheat, mkradio3, mkradio4, mkradio4a, multical21, qheat, qwater, rfmtx1, sharky774, topaseskr, ultrimis, unismart, vario451
[10:49:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=3973 (now=63973)
[10:49:14][VV][api.service:697]: on_ping_request: PingRequest {}
[10:49:14][VV][api.service:043]: send_ping_response: PingResponse {}
[10:49:21][I][safe_mode:041]: Boot seems successful; resetting boot loop counter
[10:49:34][VV][api.connection:133]: Sending keepalive PING…
[10:49:34][VV][api.service:037]: send_ping_request: PingRequest {}
[10:49:34][VV][api.service:706]: on_ping_response: PingResponse {}
[10:49:54][VV][api.service:697]: on_ping_request: PingRequest {}
[10:49:54][VV][api.service:043]: send_ping_response: PingResponse {}
[10:50:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=63973 (now=123973)
[10:50:34][VV][api.service:697]: on_ping_request: PingRequest {}
[10:50:34][VV][api.service:043]: send_ping_response: PingResponse {}
[10:50:34][VV][api.connection:133]: Sending keepalive PING…
[10:50:34][VV][api.service:037]: send_ping_request: PingRequest {}
[10:50:34][VV][api.service:706]: on_ping_response: PingResponse {}
[10:51:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=123973 (now=183973)
[10:51:14][VV][api.service:697]: on_ping_request: PingRequest {}
[10:51:14][VV][api.service:043]: send_ping_response: PingResponse {}
[10:51:34][VV][api.service:697]: on_ping_request: PingRequest {}
[10:51:34][VV][api.service:043]: send_ping_response: PingResponse {}
[10:51:54][VV][api.service:697]: on_ping_request: PingRequest {}
[10:51:54][VV][api.service:043]: send_ping_response: PingResponse {}
[10:52:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=183973 (now=243973)
[10:52:34][VV][api.service:697]: on_ping_request: PingRequest {}
[10:52:34][VV][api.service:043]: send_ping_response: PingResponse {}
[10:52:34][VV][api.connection:133]: Sending keepalive PING…
[10:52:34][VV][api.service:037]: send_ping_request: PingRequest {}
[10:52:34][VV][api.service:706]: on_ping_response: PingResponse {}
[10:53:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=243973 (now=303973)
[10:53:14][VV][api.service:697]: on_ping_request: PingRequest {}
[10:53:14][VV][api.service:043]: send_ping_response: PingResponse {}
[10:53:34][VV][api.service:697]: on_ping_request: PingRequest {}
[10:53:34][VV][api.service:043]: send_ping_response: PingResponse {}
[10:53:54][VV][api.service:697]: on_ping_request: PingRequest {}
[10:53:54][VV][api.service:043]: send_ping_response: PingResponse {}
[10:54:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=303973 (now=363973)
[10:54:34][VV][api.service:697]: on_ping_request: PingRequest {}
[10:54:34][VV][api.service:043]: send_ping_response: PingResponse {}
[10:54:34][VV][api.connection:133]: Sending keepalive PING…
[10:54:34][VV][api.service:037]: send_ping_request: PingRequest {}
[10:54:34][VV][api.service:706]: on_ping_response: PingResponse {}
[10:55:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=363973 (now=423973)
[10:55:14][VV][api.service:697]: on_ping_request: PingRequest {}
[10:55:14][VV][api.service:043]: send_ping_response: PingResponse {}
[10:55:34][VV][api.service:697]: on_ping_request: PingRequest {}
[10:55:34][VV][api.service:043]: send_ping_response: PingResponse {}
[10:55:54][VV][api.service:697]: on_ping_request: PingRequest {}
[10:55:54][VV][api.service:043]: send_ping_response: PingResponse {}
[10:56:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=423973 (now=483973)
[10:56:34][VV][api.service:697]: on_ping_request: PingRequest {}
[10:56:34][VV][api.service:043]: send_ping_response: PingResponse {}
[10:56:34][VV][api.connection:133]: Sending keepalive PING…
[10:56:34][VV][api.service:037]: send_ping_request: PingRequest {}
[10:56:34][VV][api.service:706]: on_ping_response: PingResponse {}
[10:57:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=483973 (now=543973)
[10:57:14][VV][api.service:697]: on_ping_request: PingRequest {}
[10:57:14][VV][api.service:043]: send_ping_response: PingResponse {}
[10:57:34][VV][api.service:697]: on_ping_request: PingRequest {}
[10:57:34][VV][api.service:043]: send_ping_response: PingResponse {}
[10:57:54][VV][api.service:697]: on_ping_request: PingRequest {}
[10:57:54][VV][api.service:043]: send_ping_response: PingResponse {}
[10:58:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=543973 (now=603973)
[10:58:34][VV][api.service:697]: on_ping_request: PingRequest {}
[10:58:34][VV][api.service:043]: send_ping_response: PingResponse {}
[10:58:34][VV][api.connection:133]: Sending keepalive PING…
[10:58:34][VV][api.service:037]: send_ping_request: PingRequest {}
[10:58:34][VV][api.service:706]: on_ping_response: PingResponse {}
[10:59:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=603973 (now=663973)
[10:59:14][VV][api.service:697]: on_ping_request: PingRequest {}
[10:59:14][VV][api.service:043]: send_ping_response: PingResponse {}
[10:59:34][VV][api.service:697]: on_ping_request: PingRequest {}
[10:59:34][VV][api.service:043]: send_ping_response: PingResponse {}
[10:59:54][VV][api.service:697]: on_ping_request: PingRequest {}
[10:59:54][VV][api.service:043]: send_ping_response: PingResponse {}
[11:00:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=663973 (now=723973)
[11:00:34][VV][api.service:697]: on_ping_request: PingRequest {}
[11:00:34][VV][api.service:043]: send_ping_response: PingResponse {}
[11:00:34][VV][api.connection:133]: Sending keepalive PING…
[11:00:34][VV][api.service:037]: send_ping_request: PingRequest {}
[11:00:34][VV][api.service:706]: on_ping_response: PingResponse {}
[11:00:35][VV][scheduler:225]: Running interval ‘update’ with interval=900000 last_execution=4294812130 (now=744834)
[11:01:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=723973 (now=783973)
[11:01:14][VV][api.service:697]: on_ping_request: PingRequest {}
[11:01:14][VV][api.service:043]: send_ping_response: PingResponse {}
[11:01:34][VV][api.service:697]: on_ping_request: PingRequest {}
[11:01:34][VV][api.service:043]: send_ping_response: PingResponse {}
[11:01:54][VV][api.service:697]: on_ping_request: PingRequest {}
[11:01:54][VV][api.service:043]: send_ping_response: PingResponse {}
[11:02:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=783973 (now=843973)
[11:02:34][VV][api.service:697]: on_ping_request: PingRequest {}
[11:02:34][VV][api.service:043]: send_ping_response: PingResponse {}
[11:02:34][VV][api.connection:133]: Sending keepalive PING…
[11:02:34][VV][api.service:037]: send_ping_request: PingRequest {}
[11:02:34][VV][api.service:706]: on_ping_response: PingResponse {}
[11:03:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=843973 (now=903973)
[11:03:14][VV][api.service:697]: on_ping_request: PingRequest {}
[11:03:14][VV][api.service:043]: send_ping_response: PingResponse {}
[11:03:34][VV][api.service:697]: on_ping_request: PingRequest {}
[11:03:34][VV][api.service:043]: send_ping_response: PingResponse {}
[11:03:54][VV][api.service:697]: on_ping_request: PingRequest {}
[11:03:54][VV][api.service:043]: send_ping_response: PingResponse {}
[11:04:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=903973 (now=963974)
[11:04:34][VV][api.service:697]: on_ping_request: PingRequest {}
[11:04:34][VV][api.service:043]: send_ping_response: PingResponse {}
[11:04:34][VV][api.connection:133]: Sending keepalive PING…
[11:04:34][VV][api.service:037]: send_ping_request: PingRequest {}
[11:04:34][VV][api.service:706]: on_ping_response: PingResponse {}
[11:05:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=963973 (now=1023973)
[11:05:14][VV][api.service:697]: on_ping_request: PingRequest {}
[11:05:14][VV][api.service:043]: send_ping_response: PingResponse {}
[11:05:34][VV][api.service:697]: on_ping_request: PingRequest {}
[11:05:34][VV][api.service:043]: send_ping_response: PingResponse {}
[11:05:54][VV][api.service:697]: on_ping_request: PingRequest {}
[11:05:54][VV][api.service:043]: send_ping_response: PingResponse {}
[11:06:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=1023973 (now=1083973)
[11:06:34][VV][api.service:697]: on_ping_request: PingRequest {}
[11:06:34][VV][api.service:043]: send_ping_response: PingResponse {}
[11:06:34][VV][api.connection:133]: Sending keepalive PING…
[11:06:34][VV][api.service:037]: send_ping_request: PingRequest {}
[11:06:34][VV][api.service:706]: on_ping_response: PingResponse {}
[11:07:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=1083973 (now=1143973)
[11:07:14][VV][api.service:697]: on_ping_request: PingRequest {}
[11:07:14][VV][api.service:043]: send_ping_response: PingResponse {}
[11:07:34][VV][api.service:697]: on_ping_request: PingRequest {}
[11:07:34][VV][api.service:043]: send_ping_response: PingResponse {}
[11:07:54][VV][api.service:697]: on_ping_request: PingRequest {}
[11:07:54][VV][api.service:043]: send_ping_response: PingResponse {}
[11:08:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=1143973 (now=1203973)
[11:08:34][VV][api.service:697]: on_ping_request: PingRequest {}
[11:08:34][VV][api.service:043]: send_ping_response: PingResponse {}
[11:08:34][VV][api.connection:133]: Sending keepalive PING…
[11:08:34][VV][api.service:037]: send_ping_request: PingRequest {}
[11:08:34][VV][api.service:706]: on_ping_response: PingResponse {}
[11:09:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=1203973 (now=1263973)
[11:09:14][VV][api.service:697]: on_ping_request: PingRequest {}
[11:09:14][VV][api.service:043]: send_ping_response: PingResponse {}
[11:09:34][VV][api.service:697]: on_ping_request: PingRequest {}
[11:09:34][VV][api.service:043]: send_ping_response: PingResponse {}
[11:09:54][VV][api.service:697]: on_ping_request: PingRequest {}
[11:09:54][VV][api.service:043]: send_ping_response: PingResponse {}
[11:10:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=1263973 (now=1323973)
[11:10:34][VV][api.service:697]: on_ping_request: PingRequest {}
[11:10:34][VV][api.service:043]: send_ping_response: PingResponse {}
[11:10:34][VV][api.connection:133]: Sending keepalive PING…
[11:10:34][VV][api.service:037]: send_ping_request: PingRequest {}
[11:10:34][VV][api.service:706]: on_ping_response: PingResponse {}
[11:11:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=1323973 (now=1383973)
[11:11:14][VV][api.service:697]: on_ping_request: PingRequest {}
[11:11:14][VV][api.service:043]: send_ping_response: PingResponse {}
[11:11:34][VV][api.service:697]: on_ping_request: PingRequest {}
[11:11:34][VV][api.service:043]: send_ping_response: PingResponse {}
[11:11:54][VV][api.service:697]: on_ping_request: PingRequest {}
[11:11:54][VV][api.service:043]: send_ping_response: PingResponse {}
[11:12:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=1383973 (now=1443973)
[11:12:34][VV][api.service:697]: on_ping_request: PingRequest {}
[11:12:34][VV][api.service:043]: send_ping_response: PingResponse {}
[11:12:34][VV][api.connection:133]: Sending keepalive PING…
[11:12:34][VV][api.service:037]: send_ping_request: PingRequest {}
[11:12:34][VV][api.service:706]: on_ping_response: PingResponse {}
[11:13:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=1443973 (now=1503973)
[11:13:14][VV][api.service:697]: on_ping_request: PingRequest {}
[11:13:14][VV][api.service:043]: send_ping_response: PingResponse {}
[11:13:34][VV][api.service:697]: on_ping_request: PingRequest {}
[11:13:34][VV][api.service:043]: send_ping_response: PingResponse {}
[11:13:54][VV][api.service:697]: on_ping_request: PingRequest {}
[11:13:54][VV][api.service:043]: send_ping_response: PingResponse {}
[11:14:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=1503973 (now=1563973)
[11:14:34][VV][api.service:697]: on_ping_request: PingRequest {}
[11:14:34][VV][api.service:043]: send_ping_response: PingResponse {}
[11:14:34][VV][api.connection:133]: Sending keepalive PING…
[11:14:34][VV][api.service:037]: send_ping_request: PingRequest {}
[11:14:34][VV][api.service:706]: on_ping_response: PingResponse {}
[11:14:45][V][rxLoop:167]: Have 45 bytes from CC1101 Rx, RSSI: -88 dBm LQI: 168
[11:14:45][V][rxLoop:172]: Synchronus mode enabled.
[11:14:45][D][mbus:034]: Processing T1 A frame
[11:14:45][V][mbus:045]: Frame: 36571CED6777F292FAAD0996F34DCDE4D3DB98E7BF7ADDF61633BC89BC1B2D73BDD9EB3BD39B5BAD67B4BF796D (45) [RAW]
[11:14:45][V][3of6:083]: Decode 3 out of 6 failed…
[11:15:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=1563973 (now=1623974)
[11:15:14][VV][api.service:697]: on_ping_request: PingRequest {}
[11:15:14][VV][api.service:043]: send_ping_response: PingResponse {}
[11:15:34][VV][api.service:697]: on_ping_request: PingRequest {}
[11:15:34][VV][api.service:043]: send_ping_response: PingResponse {}
[11:15:35][VV][scheduler:225]: Running interval ‘update’ with interval=900000 last_execution=744834 (now=1644834)
[11:15:54][VV][api.service:697]: on_ping_request: PingRequest {}
[11:15:54][VV][api.service:043]: send_ping_response: PingResponse {}
[11:16:14][VV][scheduler:225]: Running interval ‘’ with interval=60000 last_execution=1623973 (now=1683973)
[11:16:30][V][rxLoop:167]: Have 45 bytes from CC1101 Rx, RSSI: -88 dBm LQI: 198
[11:16:30][V][rxLoop:172]: Synchronus mode enabled.
[11:16:30][D][mbus:034]: Processing T1 A frame
[11:16:30][V][mbus:045]: Frame: 36571C2D673CF2B2FBADCFD7DB45ABF4DA4F19E71D7AF5B7BCF2F4F5BEF274FB8C6B37479ACCE766D69EFB7BD6 (45) [RAW]
[11:16:30][V][3of6:083]: Decode 3 out of 6 failed…
Logi very_verbose
Przeglądałem całe wypowiedzi i nie mogę znaleźć rozwiązania mojego problemu.
Yaml:
  friendly_name: wmbus
esp8266:
    board: nodemcuv2
# Enable logging
  level: VERY_VERBOSE
    key: "w7kayYStRMKXg4+nCwldN4YchdsH6JficSBPJwmS0Aw="
  - platform: esphome
    password: "9f9bd4b8e95eab7b87987ef38a8f39d2"
    ssid: "Wmbus Fallback Hotspot"
    password: "vyE0NgNv1STu"
time:
  - platform: sntp
    timezone: warsaw
  - source: github://SzczepanLeon/esphome-components@3.2.3
wmbus:
  mosi_pin: GPIO13
  miso_pin: GPIO12
  clk_pin:  GPIO14
  cs_pin:   GPIO2
  gdo0_pin: GPIO5
  gdo2_pin: GPIO4
  led_pin: GPIO0
  led_blink_time: "1s"
  frequency: 868.950
  sync_mode: True
captive_portal:
wmbus.yaml (1014 bajtów)
