Po ostatniej aktualizacji Esphome w momencie uruchomienia Logow mialem takie błędy:
INFO ESPHome 2025.12.4
INFO Reading configuration /config/esphome/esp32c3.yaml...
ERROR Unable to import component logger:
File "/esphome/esphome/loader.py", line 199, in _lookup_module
module = importlib.import_module(f"esphome.components.{domain}")
File "/usr/local/lib/python3.12/importlib/__init__.py", line 90, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 999, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "/esphome/esphome/components/logger/__init__.py", line 6, in <module>
from esphome.components.esp32 import (
ImportError: cannot import name 'VARIANT_ESP32C61' from 'esphome.components.esp32' (/data/external_components/5c086c68/components/esp32/__init__.py)
Failed config
logger: [source /config/esphome/esp32c3.yaml:26]
Component not found: logger.
level: DEBUG
Nie było też możliwości kompilacji
Dodam ze moduł cały czas działał i odczytywał dane z liczników
Teraz mam taki config
friendly_name: Lora
platformio_options:
upload_speed: 921600
external_components:
components: [wmbus_common, wmbus_radio, wmbus_meter]
refresh: 0d
board: heltec_wifi_lora_32_V2
flash_size: 8MB
type: esp-idf
# Enable logging
level: INFO
logs:
wmbus: ERROR
wmbusmeters: ERROR
# Enable Home Assistant API
key: "HQgeLhbuFOvN73DM0CYaT3qVabF0Euciq2C1aqJ0hLU="
platform: esphome
ssid: !secret wifi_ssid
ssid: "Lora Fallback Hotspot"
password: "EyK1CEVSi4yt"
web_server:
version: 3
time:
- platform: sntp
spi:
clk_pin:
number: GPIO5
mosi_pin: GPIO27
miso_pin: GPIO19
#socket_transmitter:
# id: my_socket
# ip_address: 192.168.1.1
# port: 3333
# protocol: TCP
#mqtt:
# broker: test.mosquitto.org
# port: 1883
# client_id: some_client_id
wmbus_radio:
radio_type: SX1276
cs_pin: GPIO18
reset_pin: GPIO14
irq_pin: GPIO35
# frequency: 868.950
# all_drivers: True
# sync_mode: True
# log_all: True
on_frame:
- then:
- logger.log:
args: [ frame->rssi(), frame->as_hex().c_str(), frame->data().size() ]
#- then:
#- repeat:
#count: 3
#then:
# - output.turn_on: status_led
#- delay: 100ms
#- delay: 100ms
# - mark_as_handled: True
# then:
# - mqtt.publish:
# topic: wmbus-test/telegram_rtl
# payload: !lambda return frame->as_rtlwmbus();
# then:
# - socket_transmitter.send:
# data: !lambda return frame->as_hex();
wmbus_meter:
- id: water_meter
meter_id: 0x0000000000
type: apator162
- id: electricity_meter
type: amiplus
key: "000000000000000000000000000000"
mode:
- T1
- C1
- platform: wmbus_meter
parent_id: water_meter
field: total_m3
device_class: water
accuracy_decimals: 3
state_class: total_increasing
unit_of_measurement: "m³"
icon: "mdi:water"
parent_id: electricity_meter
field: total_energy_consumption_kwh
name: Suma konsumpcji
device_class: energy
icon: "mdi:transmission-tower-export"
field: current_power_consumption_kw
icon: "mdi:transmission-tower"
field: total_energy_production_kwh
name: Suma produkcji
icon: "mdi:transmission-tower-import"
field: current_power_production_kw
name: Aktualna produkcja
icon: "mdi:solar-power-variant"
field: voltage_at_phase_1_v
icon: "mdi:lightning-bolt"
field: voltage_at_phase_2_v
field: voltage_at_phase_3_v
field: rssi_dbm
icon: "mdi:wifi"
Teraz kompilacja przechodzi ale moduł zachowuje się dziwnie.
Robi restart. Raz działa 20 minut i resrtart a innym razem potrafi działać godzinę
Pojawiają się takie logi:
13:51:23
[W]
[component:543]
safe_mode took a long time for an operation (69 ms)
13:51:23
[W]
[component:546]
Components should block for at most 30 ms
13:51:26
[W]
[component:543]
interval took a long time for an operation (466 ms)
13:51:26
[W]
[component:546]
13:51:26
[W]
[component:543]
api took a long time for an operation (473 ms)
13:51:26
[W]
[component:546]
13:54:16
[W]
[component:543]
display took a long time for an operation (258 ms)
13:54:16
[W]
[component:546]
Da się coś z tym zrobić?
