Od kilku dni nie mogę poprawnie wyświetlić interfejsu w ww wtyczce. Nie wiem co się stało, bo kilka dni temu to działało. Nie wiem czy dobrze kojarzę, ale być może miała na to wpływ konfiguracja duckdns.
Wyświetla się to:
Podaj wersję używanego addona i logi od momentu uruchomienia addona do momentu próby wejścia do interfejsu użytkownika.
PS. Zakładam, że już próbowałeś zatrzymać a później ponownie uruchomić addon.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] permissions: applying...
[fix-attrs.d] permissions: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: SSH & Web Terminal
SSH & Web Terminal access to your Home Assistant instance
Add-on version: 9.0.1
System: Home Assistant OS 6.6 (amd64 / qemux86-64)
Home Assistant Core: 2021.11.2
Home Assistant Supervisor: 2021.10.8
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] docker.sh: executing...
[10:48:05] INFO: Docker support has been enabled.
[cont-init.d] docker.sh: exited 0.
[cont-init.d] mosquitto.sh: executing...
[cont-init.d] mosquitto.sh: exited 0.
[cont-init.d] mysql.sh: executing...
[cont-init.d] mysql.sh: exited 0.
[cont-init.d] ssh.sh: executing...
[10:48:07] INFO: No network port is defined in the configuration so access
[10:48:07] INFO: will only be available via the web interface.
[cont-init.d] ssh.sh: exited 0.
[cont-init.d] user.sh: executing...
[10:48:08] NOTICE: Session sharing has been disabled!
[cont-init.d] user.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[10:48:08] INFO: Starting the Home Assistant STDIN service...
[10:48:08] INFO: Starting the ttyd daemon...
