Dziś dotarł do mnie CC2652P : https://allegro.pl/oferta/cc2652p-zigbee2mqtt-home-assistant-domoticz-ebook-10826521476
W Windowsie zainstalowałem VirtualBox na którym mam Home Assistanta.
Udostępiony CC2652p VirtualBox
Sprzęt widoczny w Home Assistant
Użytkownik core-msquitto utworzony na potrzeby integracji dodatków
Mosquito broker
LOG po uruchomieniu:
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] mosquitto.sh: executing…
[23:29:04] INFO: Setting up user user
[23:29:04] INFO: SSL is not enabled
[cont-init.d] mosquitto.sh: exited 0.
[cont-init.d] nginx.sh: executing…
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[23:29:04] INFO: Starting NGINX for authentication handling…
[23:29:04] INFO: Starting mosquitto MQTT broker…
1636583344: mosquitto version 1.6.12 starting
1636583344: |-- *** auth-plug: startup
[23:29:04] INFO: Successfully send discovery information to Home Assistant.
[23:29:04] INFO: Successfully send service information to the Supervisor.
1636583344: Config loaded from /etc/mosquitto/mosquitto.conf.
1636583344: Loading plugin: /usr/share/mosquitto/auth-plug.so
1636583344: ├── Username/password checking enabled.
1636583344: ├── TLS-PSK checking enabled.
1636583344: └── Extended authentication not enabled.
1636583344: Opening ipv4 listen socket on port 1883.
1636583344: Opening ipv6 listen socket on port 1883.
1636583344: Opening websockets listen socket on port 1884.
1636583344: Warning: Mosquitto should not be run as root/administrator.
1636583344: mosquitto version 1.6.12 running
1636583344: New connection from 127.0.0.1 on port 1883.
1636583344: Socket error on client , disconnecting.
1636583347: New connection from 172.30.32.1 on port 1883.
1636583347: New client connected from 172.30.32.1 as auto-7A9CCAC0-2FCC-82CC-8525-2C974E1601EE (p2, c1, k60, u’addons’).
1636583362: New connection from 172.30.32.1 on port 1883.
Klient nie nawiązuje połączenia
Natomiast tutaj już tak
Następnie zainstalowałem Zigbee2MQTT
Ustawienia
log:
[fix-attrs.d] done.
[cont-init.d] socat.sh: executing…
[01:03:11] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing…
[01:03:11] INFO: MQTT available, fetching server detail …
[01:03:11] INFO: MQTT server settings not configured, trying to auto-discovering …
[01:03:11] INFO: Configuring ‘mqtt://core-mosquitto:1883’ mqtt server
[01:03:11] INFO: Previous config file found, checking backup
[01:03:11] INFO: Creating backup config in ‘/config/zigbee2mqtt/.configuration.yaml.bk’
[01:03:11] INFO: Adjusting Zigbee2mqtt core yaml config with add-on quirks …
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] done.
[01:03:11] INFO: Handing over control to Zigbee2mqtt Core …
zigbee2mqtt@1.22.0 start
node index.js
Zigbee2MQTT:warn 2021-11-11 01:03:14: Using experimental new availability feature
Nie widzę w spisie urządzeń koncentratora czyli CC2652P
Co robię nie tak?
, a wynik taki sam dodatek zigbee2mqtt nie uruchamia się - jedyne co robi, to kręci kółkiem jakby probówał odświeżyć ekran.
