Witam!
Mam problem z dwoma przekaźnikami, których nie widać w GUI, a widać w konfigu.
Oprócz tego są 3 włączniki 2 czujki ruchu i czujnik otwarcia drzwi, które działają bez problemu.
Oto skrypt:
// Enable debug prints to serial monitor
#define MY_DEBUG
// Enable and select radio type attached
#define MY_RADIO_RF24
//#define MY_RADIO_NRF5_ESB
//#define MY_RADIO_RFM69
//#define MY_RADIO_RFM95
// Enable repeater functionality for this node
#define MY_REPEATER_FEATURE
#define MY_NODE_ID 10
#include <MySensors.h>
#include <Bounce2.h>
#define RELAY_PIN 4 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
#define NUMBER_OF_RELAYS 2 // Total number of attached relays
#define RELAY_ON 0 // GPIO value to write to turn on attached relay
#define RELAY_OFF 1 // GPIO value to write to turn off attached relay
#define PRIMARY_CHILD_ID 11
#define PRIMARY_BUTTON_PIN A0
#define SECONDARY_CHILD_ID 22
#define SECONDARY_BUTTON_PIN A1
#define TERTIARY_CHILD_ID 33
#define TERTIARY_BUTTON_PIN A2
#define QUATERNARY_CHILD_ID 44
#define QUATERNARY_BUTTON_PIN A3
#define QUINARY_CHILD_ID 55
#define QUINARY_BUTTON_PIN A4
#define SENARY_CHILD_ID 66
#define SENARY_BUTTON_PIN A5
Bounce debouncer = Bounce();
int oldValue = -1;
// Change to V_LIGHT if you use S_LIGHT in presentation below
MyMessage msg(PRIMARY_CHILD_ID, V_TRIPPED);
MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
MyMessage msg3(TERTIARY_CHILD_ID, V_TRIPPED);
MyMessage msg4(QUATERNARY_CHILD_ID, V_LIGHT);
MyMessage msg5(QUINARY_CHILD_ID, V_LIGHT);
MyMessage msg6(SENARY_CHILD_ID, V_LIGHT);
void before()
for (int sensor = 1, pin = RELAY_PIN; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
// Then set relay pins in output mode
pinMode(pin, OUTPUT);
// Set relay to last known state (using eeprom storage)
digitalWrite(pin, loadState(sensor) ? RELAY_ON : RELAY_OFF);
void setup()
// Setup the button
pinMode(PRIMARY_BUTTON_PIN, INPUT);
pinMode(SECONDARY_BUTTON_PIN, INPUT);
pinMode(TERTIARY_BUTTON_PIN, INPUT);
pinMode(QUATERNARY_BUTTON_PIN, INPUT);
pinMode(QUINARY_BUTTON_PIN, INPUT);
pinMode(SENARY_BUTTON_PIN, INPUT);
// Activate internal pull-up
digitalWrite(PRIMARY_BUTTON_PIN, HIGH);
digitalWrite(SECONDARY_BUTTON_PIN, HIGH);
digitalWrite(TERTIARY_BUTTON_PIN, HIGH);
digitalWrite(QUATERNARY_BUTTON_PIN, HIGH);
digitalWrite(QUINARY_BUTTON_PIN, HIGH);
digitalWrite(SENARY_BUTTON_PIN, HIGH);
debouncer.attach(PRIMARY_BUTTON_PIN);
debouncer.attach(SECONDARY_BUTTON_PIN);
debouncer.attach(TERTIARY_BUTTON_PIN);
debouncer.attach(QUATERNARY_BUTTON_PIN);
debouncer.attach(QUINARY_BUTTON_PIN);
debouncer.attach(SENARY_BUTTON_PIN);
debouncer.interval(10);
void presentation()
// Send the sketch version information to the gateway and Controller
sendSketchInfo("Relay", "1.0");
// Register all sensors to gw (they will be created as child devices)
present(sensor, S_BINARY);
wait( 50 );
present(PRIMARY_CHILD_ID, S_MOTION);
present(SECONDARY_CHILD_ID, S_MOTION);
present(TERTIARY_CHILD_ID, S_DOOR);
present(QUATERNARY_CHILD_ID, S_LIGHT);
present(QUINARY_CHILD_ID, S_LIGHT);
present(SENARY_CHILD_ID, S_LIGHT);
void loop()
uint8_t value;
static uint8_t sentValue = 2;
static uint8_t sentValue2 = 2;
static uint8_t sentValue3 = 2;
static uint8_t sentValue4 = 2;
static uint8_t sentValue5 = 2;
static uint8_t sentValue6 = 2;
// Short delay to allow buttons to properly settle
value = digitalRead(PRIMARY_BUTTON_PIN);
if (value != sentValue) {
// Value has changed from last transmission, send the updated value
send(msg.set(value == HIGH ? 1 : 0));
sentValue = value;
value = digitalRead(SECONDARY_BUTTON_PIN);
if (value != sentValue2) {
send(msg2.set(value == HIGH ? 1 : 0));
sentValue2 = value;
value = digitalRead(TERTIARY_BUTTON_PIN);
if (value != sentValue3) {
send(msg3.set(value == HIGH ? 1 : 0));
sentValue3 = value;
value = digitalRead(QUATERNARY_BUTTON_PIN);
if (value != sentValue4) {
send(msg4.set(value == LOW ? 1 : 0));
sentValue4 = value;
value = digitalRead(QUINARY_BUTTON_PIN);
if (value != sentValue5) {
send(msg5.set(value == LOW ? 1 : 0));
sentValue5 = value;
value = digitalRead(SENARY_BUTTON_PIN);
if (value != sentValue6) {
send(msg6.set(value == LOW ? 1 : 0));
sentValue6 = value;
void receive(const MyMessage &message)
// We only expect one type of message from controller. But we better check anyway.
if (message.getType() == V_STATUS) {
// Change relay state
digitalWrite(message.getSensor() - 1 + RELAY_PIN, message.getBool() ? RELAY_ON : RELAY_OFF);
// Store state in eeprom
saveState(message.getSensor(), message.getBool());
// Write some debug info
Serial.print("Incoming change for sensor:");
Serial.print(message.getSensor());
Serial.print(", New status: ");
Serial.println(message.getBool());
I config mysensors:
"0": {
"sensor_id": 0,
"children": {},
"type": 18,
"sketch_name": null,
"sketch_version": null,
"battery_level": 0,
"protocol_version": "2.3.2",
"heartbeat": 0
"10": {
"sensor_id": 10,
"children": {
"1": {
"id": 1,
"type": 3,
"description": "",
"values": {}
"2": {
"id": 2,
"type": 3,
"description": "",
"values": {}
"11": {
"id": 11,
"type": 1,
"description": "",
"values": {
"16": "0"
"22": {
"id": 22,
"type": 1,
"description": "",
"values": {
"16": "0"
"33": {
"id": 33,
"type": 0,
"description": "",
"values": {
"16": "0"
"44": {
"id": 44,
"type": 3,
"description": "",
"values": {
"16": "0",
"2": "0"
"55": {
"id": 55,
"type": 3,
"description": "",
"values": {
"16": "0",
"2": "0"
"66": {
"id": 66,
"type": 3,
"description": "",
"values": {
"16": "0",
"2": "0"
"type": 18,
"sketch_name": "Relay",
"sketch_version": "1.0",
"battery_level": 0,
"heartbeat": 0
Obstawiam że ID 1 oraz 2 to te nieszczęsne przekaźniki.
Czy ktoś wie gdzie popełniłem błąd?
