MySpeed 🏎️ | Pomiar prędkości połączenia
MySpeed ​​to oprogramowanie do analizy testów prędkości, które przechowuje prędkość Twojego Internetu przez maksymalnie 30 dni.
Strona Projektu: https://myspeed.dev/
Github: https://github.com/gnmyt/myspeed?tab=readme-ov-file
Tutorial instalacji na innych platformach: https://myspeed.dev/tutorials
Kod Dla: Dockge
version: "3" # This specifies the version of the Docker Compose file format being used
# This section defines the services to be run
services:
  # The 'myspeed' service
  myspeed:
    # This sets the Docker image to be used for the 'myspeed' service
    image: germannewsmaker/myspeed
    # Port mapping from host to container: Host's 5216 is mapped to container's 5216
    ports:
      - "5216:5216"
    # This volume mount docker volume 'myspeed_data'
    # to the container's directory '/myspeed/data'.
    # This allows for data persistence and sharing between the host and container.
    volumes:
      - myspeed_data:/myspeed/data
    # The 'restart' policy is set to 'unless-stopped', meaning the service will automatically restart
    # unless it has been explicitly stopped by the user.
    restart: unless-stopped
# Here we define Docker volumes for use by our services
volumes:
  myspeed_data: # Define the named volume 'myspeed_data'
    driver: local # Optional: Specifies that the local volume driver should be used
Możliwość zmiany wielu parametrów.
