Mam oczyszcza Air Purifier 3H oraz nawilżacz SCKOA45. Sam oczyszczacz działa tak samo odwrotnie. Wiem, że kod nie umożliwia sterowania wszystkimi funkcjami ale próbuję poznać jak to wszystko działa. Co jest w kodzie nie tak, że po dodaniu drugiego urządzenia pierwsze nie działa?
fan:
- platform: xiaomi_miio_airpurifier
name: Xiaomi Air Humidifier
host: 192.168.x.xxxxxxxxx
token: 5fd84bxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
model: deerma.humidifier.mjjsq
sensors:
airhumidifier_led:
friendly_name: Air Purifier led Index
value_template: '{{ states.fan.xiaomi_air_humidifier.attributes.led }}'
airhumidifier_temperature:
friendly_name: Air Humidifier Temperature
value_template: '{{ states.fan.xiaomi_air_humidifier.attributes.temperature }}'
unit_of_measurement: '°C'
airhumidifier_humidity:
friendly_name: Air Humidifier Humidity
value_template: '{{ states.fan.xiaomi_air_humidifier.attributes.humidity }}'
unit_of_measurement: '%'
airhumidifier_mode:
friendly_name: Air Humidifier mode
value_template: '{{ states.fan.xiaomi_air_humidifier.attributes.mode }}'
airhumidifier_target_humidity:
friendly_name: Air Humidifier Target Humidity
value_template: '{{ states.fan.xiaomi_air_humidifier.attributes.target_humidity }}'
airhumidifier_model:
friendly_name: Air Humidifier model
value_template: '{{ states.fan.xiaomi_air_humidifier.attributes.model }}'
fan:
name: Air Purifier Bedroom
host: 192.168.x.xxx
token: b4f104xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
model: zhimi.airpurifier.mb3
sensors:
air_purifier_bedroom_aqi:
friendly_name: "PM2.5"
unit_of_measurement: 'μg/m³'
value_template: "{{ state_attr('fan.air_purifier_bedroom', 'aqi') }}"
air_purifier_bedroom_temperature:
friendly_name: "Temperature"
value_template: "{{ state_attr('fan.air_purifier_bedroom', 'temperature')|float|round(2) }}"
air_purifier_bedroom_humidity:
friendly_name: "Humidity"
value_template: "{{ state_attr('fan.air_purifier_bedroom', 'humidity') }}"
air_purifier_bedroom_speed:
friendly_name: "Mode"
value_template: "{{ state_attr('fan.air_purifier_bedroom', 'speed') }}"
air_purifier_bedroom_favorite_level:
friendly_name: "Favorite Level"
value_template: "{{ state_attr('fan.air_purifier_bedroom', 'favorite_level') }}"
air_purifier_bedroom_motor_speed:
friendly_name: "Motor Speed"
unit_of_measurement: 'rpm'
szopen
8 Listopad 2021 23:21
2
nie możesz powtarzać sekcji w pliku, przy założeniu, że te wpisy są poprawne powinno to wyglądać mniej więcej tak
fan:
host: 192.168.x.xxx
sensors:
airhumidifier_led:
airhumidifier_mode:
A tak poza konkurencją to w ostatnich miesiącach konfiguracja się radykalnie zmieniła, więc template z atrybutami są zapewne już niepotrzebne.
Gdzie znajdę dla laika jakieś info jak teraz konfigurować poprawnie? Twoja sugestia pomogła !!
szopen
9 Listopad 2021 00:04
4
Podstawowe informacje
Oraz zapewne czytając breaking changes na oficjalnym blogu HA:
Z-Wave JS S2 support, the new official Tuya integration, secure communications with ESPHome devices, and 400 new MDI icons!
Sorry, ale dalej nie chce mi się kopać, a w linkach powyżej masz kilka istotnych informacji. z ostatnich 2 miesięcy.
Prawdopodobnie cały ten kod możesz wywalić z configuration.yaml (lepiej zakomentować), ta integracja teraz jest konfigurowana (w większości wypadków) z poziomu GUI i znając IP urządzeń oraz tokeny, prawdopodobnie da się to zrobić w GUI w sekcji Konfiguracja → Integracje (ale najpierw usuń lub zakomentuj konfigurację YAML i wykonaj restart HA) - możesz też kliknąć w linka poniżej i podać na wygenerowanej stronie adres swojego HA
Oczywiście to jest takie działanie trochę metodą prób i błędów, więc przy wywalaniu czegoś z konfiguracji skopiuj to do jakiegoś pliku na komputerze by łatwo przywrócić te fragmenty (aż tak nie kopałem po dokumentacji by mieć pewność, że oba twoje urządzenia “łykną” konfigurację GUI).
Nie usuń sobie też sekcji sensor: jeśli masz jakiekolwiek inne sensory.
