Po zmianie czasu lato -zima nie uruchamia się NR
Moje logi
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 10.0.1
System: Home Assistant OS 6.5 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2021.10.6
Home Assistant Supervisor: 2021.10.6
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] customizations.sh: executing...
[cont-init.d] customizations.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] node-red.sh: executing...
patching file nodes/ui_base.html
Hunk #1 succeeded at 1162 (offset 631 lines).
npm ERR! code ENOTEMPTY
npm ERR! syscall rename
npm ERR! path /config/node-red/node_modules/bl
npm ERR! dest /config/node-red/node_modules/.bl-I9fz5dFv
npm ERR! errno -39
npm ERR! ENOTEMPTY: directory not empty, rename '/config/node-red/node_modules/bl' -> '/config/node-red/node_modules/.bl-I9fz5dFv'
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2021-10-31T08_01_09_669Z-debug.log
[09:01:09] FATAL: Failed un-installing conflicting packages
[cont-init.d] node-red.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
nie wiadomo co się popsuło bo każdy miał inne problemy. Przywrócenie powinno naprawić błędy
odinstalowanie automatycznie usuwa wszystko, więc trzeba by dla przywrócenia exportować wszystkie node i później wrzucić ponownie.
