Tworzę dwie właściwości w msg i sprawdzam je w switch.
[{"id":"d3bfa069e0a93936","type":"server-state-changed","z":"f8a99b5726f9247a","name":"","server":"6a2af6d8.98c388","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_number.test","entityidfiltertype":"exact","outputinitially":false,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"tempzadana","propertyType":"msg","value":"","valueType":"entityState"}],"x":180,"y":760,"wires":[["e2c0f7bbec04a510","bf6f2bc47a0b4edb"]]},{"id":"e2c0f7bbec04a510","type":"debug","z":"f8a99b5726f9247a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":650,"y":640,"wires":[]},{"id":"bf6f2bc47a0b4edb","type":"api-current-state","z":"f8a99b5726f9247a","name":"","server":"6a2af6d8.98c388","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.sypialniaczujniktemperatury_temperature","state_type":"num","blockInputOverrides":false,"outputProperties":[{"property":"tempaktualna","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":650,"y":760,"wires":[["9d30f97d9b31db5b"]]},{"id":"38418d28745578f3","type":"debug","z":"f8a99b5726f9247a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1130,"y":700,"wires":[]},{"id":"b9d49c1b066cc130","type":"debug","z":"f8a99b5726f9247a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1130,"y":820,"wires":[]},{"id":"9d30f97d9b31db5b","type":"switch","z":"f8a99b5726f9247a","name":"","property":"tempzadana","propertyType":"msg","rules":[{"t":"gte","v":"tempaktualna","vt":"msg"},{"t":"lt","v":"tempaktualna","vt":"msg"}],"checkall":"true","repair":false,"outputs":2,"x":970,"y":760,"wires":[["38418d28745578f3"],["b9d49c1b066cc130"]]},{"id":"6a2af6d8.98c388","type":"server","name":"Home Assistant 1","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30}]
