Jasne. Gotowiec do użycia w Node Red:
[{"id":"fb0ad81822d5efdb","type":"comment","z":"187eed28.58531b","name":"Zmień serwer VPN na rekomendowany","info":"","x":210,"y":1400,"wires":[]},{"id":"10dc89e58cc0d486","type":"inject","z":"187eed28.58531b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":140,"y":1480,"wires":[["4fd733b9f58893e0"]]},{"id":"4fd733b9f58893e0","type":"http request","z":"187eed28.58531b","name":"","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://nordvpn.com/wp-admin/admin-ajax.php?action=servers_recommendations","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":310,"y":1480,"wires":[["62c5d37964866a84"]]},{"id":"62c5d37964866a84","type":"change","z":"187eed28.58531b","name":"","rules":[{"t":"set","p":"adresik","pt":"msg","to":"payload[0].hostname","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":1480,"wires":[["9f86a87fc08685b5"]]},{"id":"9f86a87fc08685b5","type":"switch","z":"187eed28.58531b","name":"","property":"statusCode","propertyType":"msg","rules":[{"t":"eq","v":"200","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":670,"y":1480,"wires":[["fd4478d5832c4624"],["d8d3367592f2ae83"]]},{"id":"fd4478d5832c4624","type":"function","z":"187eed28.58531b","name":"function 3","func":"var adres=msg.adresik\nmsg.payload = {\n \"command\": [\n \"/ip/ipsec/peer/set\",\n \"=.id=0\",\n \"=address=\"+adres\n ]\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":820,"y":1420,"wires":[["de592b0c895a4eb4"]]},{"id":"de592b0c895a4eb4","type":"mikrotik","z":"187eed28.58531b","device":"de203752aa6d1341","name":"","action":"9","command":"","command-type":"str","x":980,"y":1420,"wires":[["dc648b55df5fea1f"]]},{"id":"de203752aa6d1341","type":"mikrotik-device","host":"192.168.10.1","port":"8728","username":null,"password":null,"ssl":"api"}]
