Hej, mam w domu licznik z nakładką Apator. Używam wmbusmeters w wersji 1.16.1-105-g6874b33 jako kontener dockerowy z donglem USB DVB-T RTL2832U. Gdy korzystam z narzędzia rtl_433, widzę nadchodzące telegramy:
# rtl_433 -R 104 -f 868.95M
rtl_433 version 23.11-153-g38214989 branch master at 202408022150 inputs file rtl_tcp RTL-SDR
New defaults active, use "-Y classic -s 250k" if you need the old defaults
Found Fitipower FC0012 tuner
[SDR] Using device 0: Realtek, RTL2838UHIDIR, SN: 00000001, "Generic RTL2832U OEM"
Exact sample rate is: 1000000.026491 Hz
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
time : 2024-08-14 06:47:48
model : Wireless-MBus Mode : T Manufacturer: APA ID : 4950491
Version : 20 Device Type: 0x07 Device Type String: Water Control : 0x44
Data Length: 29 Data : 1a440106910495041407a09b015685b0a5378a6a897bb49cc24c2b0763a4a9
Integrity : CRC
Control Info: 0xA0 Access number: 0x00 Device Type: 0x00 Configuration Word: 0x0000
Max Volume flow[0]: 4910.601 m3/min Max Volume of month -1: 0.000 m3
time : 2024-08-14 06:47:57
Data Length: 29 Data : 1a440106910495041407a19c014b2b259fb80804dadc741ae14a7913d7e242
Integrity : CRC
Control Info: 0xA1 Access number: 0x00 Device Type: 0x00 Configuration Word: 0x0000
Mogę zdekodować telegram:
/wmbusmeters/wmbusmeters --analyze=apator08 1a440106910495041407a09b015685b0a5378a6a897bb49cc24
c2b0763a4a9
(wmbus) telegram length byte (the first) 0x1a (26) is probably wrong. Expected 0x1e (30) based on the length of the telegram.
Auto driver : not found!
Similar driver : unknown 00/00
Using driver : apator08 00/00
000 : 1a length (26 bytes)
001 : 44 dll-c (from meter SND_NR)
002 : 0106 dll-mfct (APA)
004 : 91049504 dll-id (04950491)
008 : 14 dll-version
009 : 07 dll-type (Water meter)
010 : a0 tpl-ci-field (Mfct specific)
011 C?: 9B015685B0A5378A6A897BB49CC24C2B0763A4A9 mfct specific
025 C!: *** 10|9b015685 total consumption (-685987.020333 m3)
"media":"water",
"meter":"apator08",
"name":"",
"id":"04950491",
"total_m3":-685987.020333,
"timestamp":"2024-08-14T06:52:58Z"
lub
011 C?: D101F8B5718E75FBED2EB1EC2919234B8846A985 mfct specific
025 C!: *** 10|d101f8b5 total consumption (-414012.602333 m3)
"media":"water",
"meter":"apator08",
"name":"",
"id":"04950491",
"total_m3":-414012.602333,
"timestamp":"2024-08-14T06:57:01Z"
lub
011 C?: CB01DD0BE29955BA01688574416EEF3EF0913A96 mfct specific
025 C!: *** 10|cb01dd0b total consumption (66344.430333 m3)
"media":"water",
"meter":"apator08",
"name":"",
"id":"04950491",
"total_m3":66344.430333,
"timestamp":"2024-08-14T06:56:17Z"
Wszystkie powyższe telegramy odebrałem w krótkim oknie czasowym (kilka minut), ale jak widać atrybut total_m3 mocno różni się za każdym razem, w dodatku czasem jest liczbą ujemną. Wiecie dlaczego tak jest?
Drugim problemem jest to, że gdy odpalę wmbusmeters do nasłuchu, to niestety tych telegramów nie widać w ogóle, może tak wisieć kilka godzin:
# docker-compose logs -f wmbusmeters
wmbusmeters | Started config rtlwmbus[00000001] listening on none
wmbusmeters | No meters configured. Printing id:s of all telegrams heard!
Mój wmbusmeters.conf (próbowałem mnóstwa opcji):
lloglevel=normal
device=rtlwmbus
logtelegrams=true
format=json
meterfiles=/wmbusmeters_data/logs/meter_readings
meterfilesaction=overwrite
logfile=/dev/stdout
