Mam dwa czujnik drzwi podpięte przez zigbbe i tuya, wkurza mnie że w HA mam “otwarto” chcicałbym mieć “otwarte” pomoże ktoś?
https://www.google.com/search?q=+state+rename+home+assistant
i otwórz sobie Przegląd od AI - jest kilka metod, które zadziałają (a przynajmniej na 1 rzut oka wyglądają wiarygodnie…)
cytat odpowiedzi AI (Uwaga w ogóle nie powinienem tak odpowiadać, ale ten temat był wałkowany setki razy - po prostu nawet nie szukałeś po forum)
To rename a state in Home Assistant, you’ll need to use a template, either a template sensor or by modifying the display within a specific card. For example, you can use a template sensor with a
value_templateandfriendly_nameto rename the state of an entity. Alternatively, some cards likecustom:button-cardallow for templating of state names, enabling dynamic renaming.Here’s a more detailed explanation:
- Using Template Sensors:
- Create a template sensor (e.g.,
template.my_sensor).- Define a
value_templatethat evaluates the original state and returns the desired renamed state (e.g., “Aberta” or “Fechada” for “open” or “closed”).- Set the
friendly_nameto the desired display name for the sensor.Kod
sensors:
my_sensor:
value_template: >
{% if is_state("sensor.original_sensor", "open") %}
Aberta
{% else %}
Fechada
{% endif %}
friendly_name: "Custom Sensor Name"
- Modifying State Display in Cards:
- Some cards, like
custom:button-card, allow you to use Jinja2 templating within their attributes, including thenameorstatedisplay.- You can use a template to dynamically change the displayed state based on the entity’s current state.
Kod
- type: custom:button-card
entity: binary_sensor.my_binary_sensor
{% if is_state('binary_sensor.my_binary_sensor', 'on') %}
Activated
{% else %}
Deactivated
{% endif %}
- Other Considerations:
device_class:Setting
device_classin a sensor’s configuration can change the icon and text representation of the state, but it doesn’t change the underlying state value (on/off for a binary sensor).
- Binary Sensors:
Binary sensors have fixed states (“on” or “off”). If you need more custom state names, consider using a template sensor instead.
- Translations:
tu celowo uciąłem, bo nie chodzi o modyfikowanie tłumaczeń, no AI nie jest idealne
no i oczywiście lepiej poczytać dokumentację na dany temat
niż wypociny AI
oprócz tych tam opisanych jest jeszcze niezalecana metoda customize
i pewnie można to teraz wytaptać pomocnikami z GUI
Z urządzeniami to nie ma nic wspólnego, więc przeniosłem wątek w lepsze miejsce, to co widzisz to de facto tłumaczenie z angielskiego (ale nie polecam go modyfikować).
kod rozumiem ale gdzie z nim w HA jestem zielony
Tego się obawiałem, w configuration.yaml, zanim sobie popsujesz HA, zrób backup.
Ten drugi fragment do edytora karty (ale wymaga karty niestandardowej, więc musisz ją najpierw doinstalować - jeśli masz już z 2 miesiące doświadczenia to HACS wita).
dzięki a backup to podstawa
HACS mam od początku, dobrze rozumiem że HA to dodawanie skryptów a nie tylko edycja?
HA mam od 2 tygodni
Musisz zmienić znacznie stosunek ilości tego co czytasz do tego o co pytasz.
A na takie fundamentalne pytania filozoficzne to nawet nie czuję się na siłach próbować odpowiadać…
Nie wiem może zajrzyj tam
poczytaj oficjalnego bloga autorów
oraz w ogóle jakieś zbliżone zasoby
fundamentalne jak dla kogo, jak 20 lat temu się bawiłem to oprogramowanie się głównie edytowanie i było oporne na nowe skrypty
Widocznie nigdy się nie interesowałeś oprogramowaniem open-source, które sobie istnieje i rozwija się od lat 90 zeszłego wieku (wcześniej też istniało, ale nie jako coś sformalizowanego, w tak powszechnej i publicznej formie i istotnie głównie było ograniczone do środowiska naukowego i wyższych uczelni).
HA to jeden z setek tysięcy projektów FOSS, a że akurat jest tak popularny to czysty przypadek.
no ciut czyms innym sie interesowałem niestety i uczyłem sie na zasadzie skasuj/ dodaj, co się stanie
