Witam serdecznie tworze sobie proces odejmowania od siebie 2 temperatur aby wysyłać do głowicy termostatycznej parametr “temperature calibration” pomoże ktoś jak to zrobić aby na wyjściu mieć obliczoną wartość.
"id": "421bfd2ce983e247",
"type": "tab",
"label": "Flow 1",
"disabled": false,
"info": ""
"id": "24277514ca16a1b2",
"type": "server-state-changed",
"z": "421bfd2ce983e247",
"name": "TermostatK",
"server": "bd4ec4c0.659038",
"version": 3,
"exposeToHomeAssistant": false,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "climate.termostat_kinga",
"entityidfiltertype": "exact",
"outputinitially": true,
"state_type": "str",
"haltifstate": "",
"halt_if_type": "str",
"halt_if_compare": "is",
"outputs": 1,
"output_only_on_state_change": true,
"for": 0,
"forType": "num",
"forUnits": "minutes",
"ignorePrevStateNull": false,
"ignorePrevStateUnknown": false,
"ignorePrevStateUnavailable": false,
"ignoreCurrentStateUnknown": false,
"ignoreCurrentStateUnavailable": false,
"outputProperties": [
"property": "data",
"propertyType": "msg",
"value": "",
"valueType": "eventData"
"property": "topic",
"value": "",
"valueType": "triggerId"
"x": 110,
"y": 300,
"wires": [
"c8a4b33f74c110aa"
"id": "c8a4b33f74c110aa",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "data.new_state.attributes.current_temperature",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 270,
"y": 300,
"wires": [
"0c59e3ea0edb6c4a"
"id": "0bf3ef2cb08e50c0",
"name": "TermometrK",
"version": 3,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityidfilter": "sensor.temperatura_kinga_temperature",
"haltifstate": "",
"outputs": 1,
"for": 0,
"forType": "num",
"property": "data",
"value": "",
"value": "",
"x": 130,
"y": 360,
"wires": [
"b2e54431a155426b"
"id": "b2e54431a155426b",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "data.new_state.attributes.temperature",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 290,
"y": 360,
"wires": [
"0c59e3ea0edb6c4a"
"id": "0c59e3ea0edb6c4a",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 490,
"y": 320,
"wires": []
"id": "bd4ec4c0.659038",
"type": "server",
"name": "Home Assistant",
"version": 2,
"addon": true,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true,
"heartbeat": false,
"heartbeatInterval": 30
