Witam nie jestem specem od Linux. Wyskoczył mi komunikat żeby z aktualizować system do wersji 2024. Poniżej załączam logi proszę o wsparcie.
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:238
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 8 lutego 2024 20:15:37 (3 occurrences)
Last logged: 20:00:17
[140092580865088] Error updating Home Assistant Core ‘HomeAssistantCore.update’ blocked from execution, system is not healthy - privileged
[140092580296512] Error updating Home Assistant Core ‘HomeAssistantCore.update’ blocked from execution, system is not healthy - privileged
File “/usr/src/homeassistant/homeassistant/components/hassio/update.py”, line 303, in async_install
await async_update_core(self.hass, version=version, backup=backup)
File “/usr/src/homeassistant/homeassistant/components/hassio/handler.py”, line 53, in _wrapper
raise HassioAPIError(data[“message”])
homeassistant.components.hassio.handler.HassioAPIError: ‘HomeAssistantCore.update’ blocked from execution, system is not healthy - privileged
The above exception was the direct cause of the following exception:
File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 238, in handle_call_service
response = await hass.services.async_call(
File “/usr/src/homeassistant/homeassistant/core.py”, line 2149, in async_call
response_data = await coro
File “/usr/src/homeassistant/homeassistant/core.py”, line 2186, in _execute_service
return await target(service_call)
File “/usr/src/homeassistant/homeassistant/helpers/entity_component.py”, line 272, in handle_service
return await service.entity_service_call(
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 882, in entity_service_call
single_response = await _handle_entity_call(
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 952, in _handle_entity_call
result = await task
File “/usr/src/homeassistant/homeassistant/components/update/init.py”, line 161, in async_install
await entity.async_install_with_progress(version, backup)
File “/usr/src/homeassistant/homeassistant/components/update/init.py”, line 465, in async_install_with_progress
await self.async_install(version, backup)
File “/usr/src/homeassistant/homeassistant/components/hassio/update.py”, line 305, in async_install
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Core ‘HomeAssistantCore.update’ blocked from execution, system is not healthy - privileged
