Problem z Appdaemon i NSpanel
Cześć
Mam problem z Appdaemon.
Próbuje uruchomnić Nspanel z wgraną tasmotą.Zainstalowałem dodatek Appdaemon oraz NSPanel Lovelace UI w Hacs.Przy próbuie uruchomienia Appdaemon błędy jak poniżej.
Katalog AppDaemon znajduje sie w katalogu \xxx.xxx.xxx.xxx\addon_configs\a0d7b954_appdaemon\
[14:35:33] INFO: Starting AppDaemon...
2024-01-22 14:35:39.524790 INFO AppDaemon: AppDaemon Version 4.4.2 starting
2024-01-22 14:35:39.525188 INFO AppDaemon: Python version is 3.11.6
2024-01-22 14:35:39.525488 INFO AppDaemon: Configuration read from: /config/appdaemon.yaml
2024-01-22 14:35:39.525750 INFO AppDaemon: Added log: AppDaemon
2024-01-22 14:35:39.526055 INFO AppDaemon: Added log: Error
2024-01-22 14:35:39.526356 INFO AppDaemon: Added log: Access
2024-01-22 14:35:39.526620 INFO AppDaemon: Added log: Diag
2024-01-22 14:35:39.930060 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2024-01-22 14:35:40.336664 INFO HASS: HASS Plugin Initializing
2024-01-22 14:35:40.336956 WARNING HASS: ha_url not found in HASS configuration - module not initialized
2024-01-22 14:35:40.337239 INFO HASS: HASS Plugin initialization complete
2024-01-22 14:35:40.338017 INFO AppDaemon: Initializing HTTP
2024-01-22 14:35:40.338700 INFO AppDaemon: Using 'ws' for event stream
2024-01-22 14:35:40.346176 INFO AppDaemon: Starting API
2024-01-22 14:35:40.350572 INFO AppDaemon: Starting Admin Interface
2024-01-22 14:35:40.351206 INFO AppDaemon: Starting Dashboards
2024-01-22 14:35:40.382772 INFO HASS: Connected to Home Assistant 2024.1.5
2024-01-22 14:35:40.410040 INFO AppDaemon: App 'hello_world' added
2024-01-22 14:35:40.411699 INFO AppDaemon: Found 1 active apps
2024-01-22 14:35:40.412211 INFO AppDaemon: Found 0 inactive apps
2024-01-22 14:35:40.412658 INFO AppDaemon: Found 0 global libraries
2024-01-22 14:35:40.413180 INFO AppDaemon: Starting Apps with 1 workers and 1 pins
2024-01-22 14:35:40.414678 INFO AppDaemon: Running on port 5050
2024-01-22 14:35:40.462160 INFO HASS: Evaluating startup conditions
2024-01-22 14:35:40.486190 INFO HASS: Startup condition met: hass state=RUNNING
2024-01-22 14:35:40.486728 INFO HASS: All startup conditions met
2024-01-22 14:35:40.542041 INFO AppDaemon: Got initial state from namespace default
2024-01-22 14:35:42.425255 INFO AppDaemon: Scheduler running in realtime
2024-01-22 14:35:42.437329 INFO AppDaemon: Adding /config/apps to module import path
2024-01-22 14:35:42.439052 INFO AppDaemon: Adding /config/apps/luibackend to module import path
2024-01-22 14:35:42.440372 INFO AppDaemon: Adding /config/apps/luibackend/translations to module import path
2024-01-22 14:35:42.441701 INFO AppDaemon: Adding /config/apps/luibackend/translations/backend to module import path
2024-01-22 14:35:42.443019 INFO AppDaemon: Adding /config/apps/luibackend/translations/frontend to module import path
2024-01-22 14:35:42.444137 INFO AppDaemon: Adding /config/apps/nspanel-lovelace-ui to module import path
2024-01-22 14:35:42.445253 INFO AppDaemon: Adding /config/apps/nspanel-lovelace-ui/luibackend to module import path
2024-01-22 14:35:42.446402 INFO AppDaemon: Adding /config/apps/nspanel-lovelace-ui/luibackend/translations to module import path
2024-01-22 14:35:42.447641 INFO AppDaemon: Adding /config/apps/nspanel-lovelace-ui/luibackend/translations/backend to module import path
2024-01-22 14:35:42.448954 INFO AppDaemon: Adding /config/apps/nspanel-lovelace-ui/luibackend/translations/frontend to module import path
2024-01-22 14:35:42.553569 WARNING AppDaemon: No app description found for: /config/apps/nspanel-lovelace-ui.py - ignoring
2024-01-22 14:35:42.558506 WARNING AppDaemon: No app description found for: /config/apps/luibackend/localization.py - ignoring
2024-01-22 14:35:42.563348 WARNING AppDaemon: No app description found for: /config/apps/luibackend/config.py - ignoring
2024-01-22 14:35:42.567987 WARNING AppDaemon: No app description found for: /config/apps/luibackend/icon_mapping.py - ignoring
2024-01-22 14:35:42.572765 WARNING AppDaemon: No app description found for: /config/apps/luibackend/theme.py - ignoring
2024-01-22 14:35:42.577780 WARNING AppDaemon: No app description found for: /config/apps/luibackend/controller.py - ignoring
2024-01-22 14:35:42.582636 WARNING AppDaemon: No app description found for: /config/apps/luibackend/updater.py - ignoring
2024-01-22 14:35:42.587880 WARNING AppDaemon: No app description found for: /config/apps/luibackend/pages.py - ignoring
2024-01-22 14:35:42.590873 WARNING AppDaemon: No app description found for: /config/apps/luibackend/mqtt.py - ignoring
2024-01-22 14:35:42.595780 WARNING AppDaemon: No app description found for: /config/apps/luibackend/apis.py - ignoring
2024-01-22 14:35:42.600038 WARNING AppDaemon: No app description found for: /config/apps/luibackend/icons.py - ignoring
2024-01-22 14:35:42.605356 WARNING AppDaemon: No app description found for: /config/apps/luibackend/helper.py - ignoring
2024-01-22 14:35:42.609986 WARNING AppDaemon: No app description found for: /config/apps/nspanel-lovelace-ui/nspanel-lovelace-ui.py - ignoring
2024-01-22 14:35:42.614750 WARNING AppDaemon: No app description found for: /config/apps/nspanel-lovelace-ui/luibackend/localization.py - ignoring
2024-01-22 14:35:42.619101 WARNING AppDaemon: No app description found for: /config/apps/nspanel-lovelace-ui/luibackend/config.py - ignoring
2024-01-22 14:35:42.623759 WARNING AppDaemon: No app description found for: /config/apps/nspanel-lovelace-ui/luibackend/icon_mapping.py - ignoring
2024-01-22 14:35:42.628762 WARNING AppDaemon: No app description found for: /config/apps/nspanel-lovelace-ui/luibackend/theme.py - ignoring
2024-01-22 14:35:42.635270 WARNING AppDaemon: No app description found for: /config/apps/nspanel-lovelace-ui/luibackend/controller.py - ignoring
2024-01-22 14:35:42.640239 WARNING AppDaemon: No app description found for: /config/apps/nspanel-lovelace-ui/luibackend/updater.py - ignoring
2024-01-22 14:35:42.644647 WARNING AppDaemon: No app description found for: /config/apps/nspanel-lovelace-ui/luibackend/pages.py - ignoring
2024-01-22 14:35:42.649235 WARNING AppDaemon: No app description found for: /config/apps/nspanel-lovelace-ui/luibackend/mqtt.py - ignoring
2024-01-22 14:35:42.653690 WARNING AppDaemon: No app description found for: /config/apps/nspanel-lovelace-ui/luibackend/apis.py - ignoring
2024-01-22 14:35:42.657568 WARNING AppDaemon: No app description found for: /config/apps/nspanel-lovelace-ui/luibackend/icons.py - ignoring
2024-01-22 14:35:42.662074 WARNING AppDaemon: No app description found for: /config/apps/nspanel-lovelace-ui/luibackend/helper.py - ignoring
2024-01-22 14:35:42.666441 INFO AppDaemon: App initialization complete
Konfiguracja raczej nie znajduję się w wyświetlonym powyżej pliku.
Witaj, własnie zainstalowalem to samo i pomimo tych błędów panel działa bez problemow.
Witam,
Czy coś w temacie sie wyjaśniło ?
Może ktoś mnie pomoże mam takie błędy w logu
2024-04-08 20:25:12.976944 WARNING AppDaemon: No app description found for: /homeassistant/appdaemon/apps/hello.py - ignoring
2024-04-08 20:25:12.977302 INFO AppDaemon: Loading App Module: /homeassistant/appdaemon/apps/nspanel-lovelace-ui/nspanel-lovelace-ui.py
2024-04-08 20:25:13.048535 WARNING AppDaemon: No app description found for: /homeassistant/appdaemon/apps/nspanel-lovelace-ui/luibackend/pages.py - ignoring
2024-04-08 20:25:13.048857 WARNING AppDaemon: No app description found for: /homeassistant/appdaemon/apps/nspanel-lovelace-ui/luibackend/icon_mapping.py - ignoring
2024-04-08 20:25:13.049087 WARNING AppDaemon: No app description found for: /homeassistant/appdaemon/apps/nspanel-lovelace-ui/luibackend/localization.py - ignoring
2024-04-08 20:25:13.049328 WARNING AppDaemon: No app description found for: /homeassistant/appdaemon/apps/nspanel-lovelace-ui/luibackend/theme.py - ignoring
2024-04-08 20:25:13.049539 WARNING AppDaemon: No app description found for: /homeassistant/appdaemon/apps/nspanel-lovelace-ui/luibackend/helper.py - ignoring
2024-04-08 20:25:13.049752 WARNING AppDaemon: No app description found for: /homeassistant/appdaemon/apps/nspanel-lovelace-ui/luibackend/icons.py - ignoring
2024-04-08 20:25:13.049960 WARNING AppDaemon: No app description found for: /homeassistant/appdaemon/apps/nspanel-lovelace-ui/luibackend/apis.py - ignoring
2024-04-08 20:25:13.050153 WARNING AppDaemon: No app description found for: /homeassistant/appdaemon/apps/nspanel-lovelace-ui/luibackend/config.py - ignoring
2024-04-08 20:25:13.050368 WARNING AppDaemon: No app description found for: /homeassistant/appdaemon/apps/nspanel-lovelace-ui/luibackend/updater.py - ignoring
2024-04-08 20:25:13.050562 WARNING AppDaemon: No app description found for: /homeassistant/appdaemon/apps/nspanel-lovelace-ui/luibackend/mqtt.py - ignoring
2024-04-08 20:25:13.050765 WARNING AppDaemon: No app description found for: /homeassistant/appdaemon/apps/nspanel-lovelace-ui/luibackend/controller.py - ignoring
2024-04-08 20:25:13.050934 INFO AppDaemon: Loading app NSPanel-Tasmota using class NsPanelLovelaceUIManager from module nspanel-lovelace-ui
Wklejam cały Log:
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service init-appdaemon: starting
Looking in indexes: https://pypi.org/simple, https://wheels.home-assistant.io/musllinux-index/
Collecting babel
  Downloading Babel-2.14.0-py3-none-any.whl.metadata (1.6 kB)
Downloading Babel-2.14.0-py3-none-any.whl (11.0 MB)
   ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 11.0/11.0 MB 4.1 MB/s eta 0:00:00
Installing collected packages: babel
Successfully installed babel-2.14.0
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
s6-rc: info: service init-appdaemon successfully started
s6-rc: info: service appdaemon: starting
s6-rc: info: service appdaemon successfully started
[20:25:09] INFO: Starting AppDaemon...
2024-04-08 20:25:10.776745 INFO AppDaemon: AppDaemon Version 4.4.2 starting
2024-04-08 20:25:10.776877 INFO AppDaemon: Python version is 3.11.6
2024-04-08 20:25:10.776951 INFO AppDaemon: Configuration read from: /config/appdaemon.yaml
2024-04-08 20:25:10.777018 INFO AppDaemon: Added log: AppDaemon
2024-04-08 20:25:10.777391 INFO AppDaemon: Added log: Error
2024-04-08 20:25:10.777452 INFO AppDaemon: Added log: Access
2024-04-08 20:25:10.777513 INFO AppDaemon: Added log: Diag
2024-04-08 20:25:10.864939 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2024-04-08 20:25:10.956776 INFO HASS: HASS Plugin Initializing
2024-04-08 20:25:10.956857 INFO HASS: HASS Plugin initialization complete
2024-04-08 20:25:10.956988 INFO AppDaemon: Initializing HTTP
2024-04-08 20:25:10.957093 INFO AppDaemon: Using 'ws' for event stream
2024-04-08 20:25:10.958344 INFO AppDaemon: Starting API
2024-04-08 20:25:10.959126 INFO AppDaemon: Starting Admin Interface
2024-04-08 20:25:10.959247 INFO AppDaemon: Starting Dashboards
2024-04-08 20:25:10.962659 INFO HASS: Connected to Home Assistant 2024.4.2
2024-04-08 20:25:10.967516 INFO AppDaemon: App 'NSPanel-Tasmota' added
2024-04-08 20:25:10.967914 INFO AppDaemon: Found 1 active apps
2024-04-08 20:25:10.967993 INFO AppDaemon: Found 0 inactive apps
2024-04-08 20:25:10.968055 INFO AppDaemon: Found 0 global libraries
2024-04-08 20:25:10.968118 INFO AppDaemon: Starting Apps with 1 workers and 1 pins
2024-04-08 20:25:10.968407 INFO AppDaemon: Running on port 5050
2024-04-08 20:25:10.977584 INFO HASS: Evaluating startup conditions
2024-04-08 20:25:10.979548 INFO HASS: Startup condition met: hass state=RUNNING
2024-04-08 20:25:10.979652 INFO HASS: All startup conditions met
2024-04-08 20:25:10.986519 INFO AppDaemon: Got initial state from namespace default
2024-04-08 20:25:12.971713 INFO AppDaemon: Scheduler running in realtime
2024-04-08 20:25:12.973620 INFO AppDaemon: Adding /homeassistant/appdaemon/apps/ to module import path
2024-04-08 20:25:12.973732 INFO AppDaemon: Adding /homeassistant/appdaemon/apps/nspanel-lovelace-ui to module import path
2024-04-08 20:25:12.973836 INFO AppDaemon: Adding /homeassistant/appdaemon/apps/nspanel-lovelace-ui/luibackend to module import path
2024-04-08 20:25:12.973935 INFO AppDaemon: Adding /homeassistant/appdaemon/apps/nspanel-lovelace-ui/luibackend/translations to module import path
2024-04-08 20:25:12.974051 INFO AppDaemon: Adding /homeassistant/appdaemon/apps/nspanel-lovelace-ui/luibackend/translations/frontend to module import path
2024-04-08 20:25:12.974177 INFO AppDaemon: Adding /homeassistant/appdaemon/apps/nspanel-lovelace-ui/luibackend/translations/backend to module import path
2024-04-08 20:25:13.051455 INFO AppDaemon: Calling initialize() for NSPanel-Tasmota
2024-04-08 20:25:13.070210 INFO NSPanel-Tasmota: Starting
2024-04-08 20:25:13.075681 WARNING AppDaemon: Unknown Plugin Configuration in get_plugin_api()
2024-04-08 20:25:13.076362 INFO NSPanel-Tasmota: Input config: {'panelRecvTopic': 'tele/NSPanel/RESULT', 'panelSendTopic': 'cmnd/NSPanel/CustomSend', 'model': 'eu', 'locale': 'pl_PL', 'updateMode': 'auto-notify', 'sleepTimeout': 20, 'screensaver': {'entity': 'weather.dom'}}
2024-04-08 20:25:13.076968 INFO NSPanel-Tasmota: Loaded config: {'panelRecvTopic': 'tele/NSPanel/RESULT', 'panelSendTopic': 'cmnd/NSPanel/CustomSend', 'updateMode': 'auto-notify', 'model': 'eu', 'sleepTimeout': 20, 'sleepBrightness': 20, 'screenBrightness': 100, 'defaultBackgroundColor': 'ha-dark', 'featureExperimentalSliders': False, 'sleepTracking': None, 'sleepTrackingZones': ['not_home', 'off'], 'sleepOverride': None, 'locale': 'pl_PL', 'quiet': True, 'timeFormat': '%H:%M', 'dateFormatBabel': 'full', 'dateAdditionalTemplate': '', 'timeAdditionalTemplate': '', 'dateFormat': '%A, %d. %B %Y', 'cards': [{'type': 'cardEntities', 'entities': [{'entity': 'iText.', 'name': 'MQTT Config successful', 'icon': 'mdi:check', 'color:': [0, 255, 0]}, {'entity': 'iText.', 'name': 'Continue adding', 'icon': 'mdi:arrow-right-bold'}, {'entity': 'iText.', 'name': 'cards to your', 'icon': 'mdi:card'}, {'entity': 'iText.', 'name': 'apps.yaml', 'icon': 'mdi:cog'}], 'title': 'Setup successful'}], 'screensaver': {'type': 'screensaver', 'entity': 'weather.dom', 'weatherUnit': 'celsius', 'forecastSkip': 0, 'weatherOverrideForecast1': None, 'weatherOverrideForecast2': None, 'weatherOverrideForecast3': None, 'weatherOverrideForecast4': None, 'doubleTapToUnlock': False, 'alternativeLayout': False, 'defaultCard': None, 'key': 'screensaver'}, 'hiddenCards': []}
2024-04-08 20:25:13.077407 WARNING NSPanel-Tasmota: ------------------------------------------------------------
2024-04-08 20:25:13.077484 WARNING NSPanel-Tasmota: Unexpected error running initialize() for NSPanel-Tasmota
2024-04-08 20:25:13.077540 WARNING NSPanel-Tasmota: ------------------------------------------------------------
2024-04-08 20:25:13.078878 WARNING NSPanel-Tasmota: Traceback (most recent call last):
  File "/usr/lib/python3.11/site-packages/appdaemon/app_management.py", line 162, in initialize_app
    await utils.run_in_executor(self, init)
  File "/usr/lib/python3.11/site-packages/appdaemon/utils.py", line 304, in run_in_executor
    response = future.result()
  File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
    result = self.fn(*self.args, **self.kwargs)
  File "/homeassistant/appdaemon/apps/nspanel-lovelace-ui/nspanel-lovelace-ui.py", line 33, in initialize
    self._controller = LuiController(cfg, mqttsender.send_mqtt_msg)
  File "/homeassistant/appdaemon/apps/nspanel-lovelace-ui/luibackend/controller.py", line 22, in __init__
    self._pages_gen.page_type("pageStartup")
  File "/homeassistant/appdaemon/apps/nspanel-lovelace-ui/luibackend/pages.py", line 140, in page_type
    self._send_mqtt_msg(f"pageType~{target_page}")
  File "/homeassistant/appdaemon/apps/nspanel-lovelace-ui/luibackend/mqtt.py", line 102, in send_mqtt_msg
    apis.mqtt_api.mqtt_publish(topic, msg)
AttributeError: 'NoneType' object has no attribute 'mqtt_publish'
2024-04-08 20:25:13.078963 WARNING NSPanel-Tasmota: ------------------------------------------------------------
2024-04-08 20:25:13.079199 INFO AppDaemon: App initialization complete
Podaj jaki masz HA (VM, supervised ),Wersję HA, appdaemon. Chodzi o nie działającą pogodę ?
Chodzi o "Waiting for content … " na ekranie NSPanelu.
Core
2024.4.2
Supervisor
2024.04.0
Operating System
12.1
Interfejs użytkownika
20240404.1
AppDaemon Current version: 0.16.4
Masz na to receptę ? Działa tylko prognoza dnia , nie działają dni następne.
@Paweł_Gruszczyński przenieś cały konfig do addon_configs , używając np Samby , potem restart AppDaemon i powinno ruszyć.
Nie działa
Próbowałem na zmianę katalogi konfigurację itp. Zdalnie z HA panel sterować mozna jest komunikacja tylko brak UI na Panelu jest kółko oczekiwania i tyle.
Homeassistant/appdaemon
To nie jest już obsługiwana ścieżka konfiguracji.
Screenshot - 08.04.2024 , 21_48_46
Pliki powinny znajdować się w addon_configs
Screenshot - 08.04.2024 , 21_50_51
Zobacz dokładnie jakie są scieżki po prawej i po lewej
Masz złą lokalizację
appdaemon.yaml
secrets: /homeassistant/secrets.yaml
appdaemon:
  latitude: *******
  longitude: *******
  elevation: 2
  time_zone: Europe/Berlin
  plugins:
    HASS:
      type: hass
    MQTT:
      type: mqtt
      namespace: mqtt
      client_id: "appdaemon"
      client_host: 192.168.1.220
      client_port: 1883
      client_user: "****"
      client_password: "******"
      client_topics: NONE
http:
  url: http://127.0.0.1:5050
admin:
hadashboard:
Dokładnie tak plus ha_url i token.
Jeżeli nic się nie ładuje to brak jest komunikacji.
Problemów szukaj w Panelu i jego konfiguracji MQTT jak i nazwy w Topic
Komunikacja jest ponieważ po MQTT jest załączane wyjscia poprzez HA, oraz stany wyjść panelu.
appdaemon.yaml:
Sprawdź to.
I tutaj czy są te same tematy:
Screenshot - 08.04.2024 , 22_03_15
Twoje błędy zaczynają się tutaj:
O ile dobrze pamiętam to nazwy tematów MQTT piszemy z małych liter .
w logach masz cmnd/NSPanel/CustomSend' a w tasmota nspanel masz inny temat.
