Problem z błędami urządzeń na zigbee2mqtt
Hej. Jak w temacie, od razu czasu w logach zigbee2mqtt występuje mnóstwo błędów. Posiadam 4 czujniki obecności czy to możliwe że zapychaja sieć i stąd te błędy? Czasem zdarzy się że nie zapali się światło lub się nie zgasi.
Przykłady błędów:
error 2024-09-15 18:54:07z2m: Publish 'set' 'state' to 'Przełącznik 2 Kuchnia' failed: 'Error: ZCL command 0xa4c138871669e0f5/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (no response received (110) waiting for response TIMEOUT)'
error 2024-09-15 18:54:08z2m: Publish 'set' 'state' to 'Przełącznik 2 Kuchnia' failed: 'Error: ZCL command 0xa4c138871669e0f5/2 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (no response received (113) waiting for response TIMEOUT)'
error 2024-09-15 18:54:22z2m: Publish 'set' 'state' to 'Przełącznik 2 Kuchnia' failed: 'Error: ZCL command 0xa4c138871669e0f5/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (no response received (118) waiting for response TIMEOUT)'
What kind of presence sensor (czujniki obecnośc) and what kind of light bulb (światło)?
Very unlikely would be the cause of this kind of issue. I would either assume, that your light bulb is either too far from the network, or have something which interferes with it to receive commands, like a low quality USB3 device/cable, or a 2.4GHz wifi router/device next to it, or something similar. If you use some clever Wifi equipment that might change its Wifi channel to overlap with your Zigbee network and that causes interference.
But just guessing randomly, is that light bulb an IKEA one?
