Witajcie, mam problem z aktualizacją HACS wyświetla się coś takiego:
Zapewne wpływa to na to że nie mogę pobrać żadnego dodatku z HACS.
Nie ma czegoś takiego jak HACKS co najwyżej jest HACS
| version | core-2024.3.0 |
| installation_type | Home Assistant OS |
| dev | false |
| hassio | true |
| docker | true |
| user | root |
| virtualenv | false |
| python_version | 3.12.2 |
| os_name | Linux |
| os_version | 6.6.20-haos |
| arch | x86_64 |
| timezone | Europe/Warsaw |
| config_dir | /config |
| GitHub API | ok |
| Github API Calls Remaining | 4902 |
| Installed Version | 1.22.0 |
| Stage | running |
| Available Repositories | 1402 |
| Downloaded Repositories | 18 |
| logged_in | true |
| subscription_expiration | 1 stycznia 2018 01:00 |
| relayer_connected | false |
| relayer_region | null |
| remote_enabled | false |
| remote_connected | false |
| alexa_enabled | false |
| google_enabled | true |
| remote_server | null |
| certificate_status | null |
| instance_id | 10dd238d8c724b3f997b534f6c5694ab |
| can_reach_cert_server | ok |
| can_reach_cloud_auth | ok |
| can_reach_cloud | ok |
| host_os | Home Assistant OS 12.1 |
| update_channel | stable |
| supervisor_version | supervisor-2024.03.1 |
| agent_version | 1.6.0 |
| docker_version | 24.0.7 |
| disk_total | 30.8 GB |
| disk_used | 10.0 GB |
| healthy | true |
| supported | true |
| board | ova |
| supervisor_api | ok |
| version_api | ok |
| installed_addons | Node-RED (17.0.11), Check Home Assistant configuration (3.11.0), File editor (5.8.0), Terminal & SSH (9.10.0), InfluxDB (5.0.0), Samba share (12.3.1), Studio Code Server (5.15.0), Git pull (7.14.0), Mosquitto broker (6.4.0), Zigbee2MQTT (1.36.0-1) |
| dashboards | 1 |
| resources | 9 |
| views | 4 |
| mode | storage |
| oldest_recorder_run | 22 marca 2024 18:30 |
| current_recorder_run | 30 marca 2024 21:17 |
| estimated_db_size | 68.43 MiB |
| database_engine | sqlite |
| database_version | 3.44.2 |
Poprawione, dziękuję za zwrócenie uwagi ![]()
Nie mam dzisiaj już czasu na szukanie dokładnego opisu
spróbuj takiego obejścia
Jeśli to nie wystarczy, to będzie pewnie trzeba się pozbyć HACS, ale warto sprawdzić inne opcje - może masz jakieś archaiczne zaszłości w konfiguracji (np. konfiguracja HACS w YAML?).
Uściślijmy jeszcze jedno - w HACS nigdy nie było żadnych Dodatków (ani nie ma i nie będzie), są tam co najwyżej komponenty niestandardowe
Jeśli potrzebujesz jakiegoś Dodatku to nie szukaj go w HACS, tylko w standardowym Sklepie.
Dodatki są zbudowane całkowicie inaczej od komponentów, a do zwykłego Sklepu można też dodawać niestandardowe repozytoria (ale tylko takie z dodatkami, nie z komponentami!).
PS Nie dodałeś czasem do HACS jakiegoś repozytorium z Dodatkami (które powinieneś dodać w Sklepie, a nie w HACS?), jeśli tak, to je usuń.
Nie pamiętam IP VM i nie wiem jak się zalogować. Na routerze mam jedno IP na które nie mogę wejść ;/ ( Serwer 192.168.3.100 odrzucił połączenie.)
A myślisz, że ja pamiętam? (skoro nawet nie podałeś takich informacji)
IP VM musi być tożsamy z IP HA, bo przecież jakoś się logowałeś do HA.
Musisz dostarczać jakiekolwiek dane, aby ktokolwiek mógł pomóc, tyle ile napisałeś wystarcza jedynie do odpowiedzi w stylu
łączę się w bólu, ale forum nie jest do wylewania żali…
A więc zrób coś, dosłownie cokolwiek - screenshoty z routera, screenshoty z proxmoxa itd.
Masz tam sambę - jesteś w stanie wejść na jakieś udziały?
Jeśli nie ogarniasz podstaw to moim zdaniem ta instalacja jest do zaorania.
PS w innym wątku miedzy wierszami wyczytałem, że zrobiłeś jakąś radykalną aktualizację wszystkiego, a tą kluczową informację tu skutecznie przemilczałeś…
Masz proxmoxa to przywróć migawkę systemu (tej VM w której masz HAOS-ova) sprzed swoich dziwnych ruchów (tj przeskoku kilkunastu dużych wersji HA) - prawdoodobnie to jedyna sensowna droga ratunku, robota na parę dni bo nie wiadomo z czego wystartowałeś, ale skoro rok nie robiłeś aktualizacji niczego… to będziesz miał sporo do czytania.
PPS Integracja HACS 1.22.0 wyszła na początku lutego 2022, a 1.23.0 wyszła pod koniec lutego 2022… więc raczej jeden rok Ci umknął, bo od tego czasu minęły ponad 2 lata…
(jeśli nie aktualizowałeś niczego w tym czasie, a teraz właśnie zacząłem to domniemywać, bo nie sądzę abyś aktualizował wszystko inne, choć troszkę systematycznie, a tylko HACS zostawił na jakiejś zabytkowej wersji)
