Cześć, mam problem z połączeniem frigate do double take. Chodzi o to, że frigate normalnie pokazuje kamerę, łączy się z mqtt, ale na double take’u jest przy nim czerwona kropka i nie wykrywa obiektów (to znaczy wykrywa, ale tylko jedno obiekt, zaraz po restarcie frigate).
Config frigate:
mqtt:
host: 192.168.8.111
user: mqtt-user
password: mqtt
client_id: frigate
cameras:
Camera1:
ffmpeg:
inputs:
- path: rtsp://***:***@192.168.8.108/cam/realmonitor?channel=1&subtype=00&authbasic=YWRtaW46QWRtaW4xMjM0
roles:
- rtmp
- detect
detect:
enabled: True
detectors:
cpu1:
type: cpu
num_threads: 3
objects:
track:
- person
Double take config:
mqtt:
host: 192.168.8.111
username: mqtt-user
password: mqtt
client_id: double_take
frigate:
url: 192.168.8.111
labels:
- person
detectors:
deepstack:
url: http://192.168.8.111
Logi frigate:
2023-07-04 10:24:36.174314392 [INFO] Starting Frigate...
2023-07-04 10:24:37.293974193 [2023-07-04 12:24:37] frigate.app INFO : Starting Frigate (0.12.1-367d724)
2023-07-04 10:24:37.306257520 [2023-07-04 12:24:37] frigate.app INFO : Creating directory: /tmp/cache
2023-07-04 10:24:37.308483195 [2023-07-04 12:24:37] peewee_migrate INFO : Starting migrations
2023-07-04 10:24:37.312440847 [2023-07-04 12:24:37] peewee_migrate INFO : There is nothing to migrate
2023-07-04 10:24:37.328585730 [2023-07-04 12:24:37] frigate.app INFO : Output process started: 300
2023-07-04 10:24:37.331545253 [2023-07-04 12:24:37] detector.cpu1 INFO : Starting detection process: 298
2023-07-04 10:24:37.331732448 [2023-07-04 12:24:37] frigate.detectors WARNING : CPU detectors are not recommended and should only be used for testing or for trial purposes.
2023-07-04 10:24:37.333065060 [2023-07-04 12:24:37] frigate.app INFO : Camera processor started for Camera1: 302
2023-07-04 10:24:37.337075187 [2023-07-04 12:24:37] frigate.app INFO : Capture process started for Camera1: 303
Logi double take:
3-07-04 12:24:41 error: Error: frigate status error: connect EADDRNOTAVAIL ::1:80 - Local (:::0)
at Object.module.exports.checks (/double-take/api/src/util/frigate.util.js:79:11)
at processTicksAndRejections (node:internal/process/task_queues:96:5)
at async module.exports.start (/double-take/api/src/controllers/recognize.controller.js:85:21)
