Jakbyś wyeksportował i zamieścił flow zamiast screena byłoby prościej.
Nie ten node. Wstaw Trigger
z opcją
Overide w delay pozwala na podanie w msg. indywidualnej wartosci.
ja mam to w ten sposób zrobione
[{"id":"b7cbb6df996af097","type":"mqtt in","z":"4d1d611d.bd4da","name":"Czujnik kuchnia","topic":"zigbee2mqtt/Czujka_kuchnia","qos":"2","datatype":"json","broker":"7f257382.e85b1c","nl":false,"rap":true,"rh":0,"inputs":0,"x":120,"y":1460,"wires":[["fc19928139cc3d26"]]},{"id":"fc19928139cc3d26","type":"switch","z":"4d1d611d.bd4da","name":"Czy ruch","property":"payload.occupancy","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"false","repair":false,"outputs":2,"x":300,"y":1460,"wires":[["974c78aa9bde8cfd","13b9f93feed27be3"],["706b1d5d82d9932f"]]},{"id":"13b9f93feed27be3","type":"change","z":"4d1d611d.bd4da","name":"Resetuj","rules":[{"t":"set","p":"reset","pt":"msg","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":1520,"wires":[["706b1d5d82d9932f"]]},{"id":"706b1d5d82d9932f","type":"delay","z":"4d1d611d.bd4da","name":"2 minuty","pauseType":"delay","timeout":"2","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":500,"y":1520,"wires":[["48b138ea924a47f9"]]},{"id":"974c78aa9bde8cfd","type":"switch","z":"4d1d611d.bd4da","name":"Jasność","property":"payload.illuminance_lux","propertyType":"msg","rules":[{"t":"lte","v":"75","vt":"num"},{"t":"gt","v":"75","vt":"num"}],"checkall":"false","repair":false,"outputs":2,"x":500,"y":1460,"wires":[["bfdd3516deef0d18"],[]]},{"id":"48b138ea924a47f9","type":"switch","z":"4d1d611d.bd4da","name":"Czy przyciskiem","property":"pod_szafkami","propertyType":"flow","rules":[{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"1","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":740,"y":1520,"wires":[["faaa17038ec6cfa9"],[]]},{"id":"faaa17038ec6cfa9","type":"change","z":"4d1d611d.bd4da","name":"Wyłącz pod szafkami","rules":[{"t":"set","p":"payload","pt":"msg","to":"off","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"shellies/shelly_pod_szafkami/relay/0/command","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1000,"y":1520,"wires":[["28f9415e.21f1ae"]]},{"id":"bfdd3516deef0d18","type":"change","z":"4d1d611d.bd4da","name":"Włącz pod szafkami","rules":[{"t":"set","p":"payload","pt":"msg","to":"on","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"shellies/shelly_pod_szafkami/relay/0/command","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1000,"y":1460,"wires":[["28f9415e.21f1ae"]]},{"id":"7f257382.e85b1c","type":"mqtt-broker","name":"HA MQTT","broker":"localhost","port":"1883","clientid":"","autoConnect":true,"usetls":false,"compatmode":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
jeśli wykryje ruch z czujki włączam światło (o ile nie jest jasno) i włączam odliczanie jeśli czujka wykryje ruch restuje delay znowu na 2 minuty i tak w kółko jeśli nie będzie ruchu przez 2 minuty sprawdza czy nie włączyłem przełącznikiem (stan w zmiennej flow) i wyłącza.
Dokładnie o to chodziło. Walczyłem nie z tym modem. Dziękuję.
Czy mógłbyś wrzucić plik json z projektem?
Hej,
W filmie Arutra wszystko jest prawie zrozumiale. Jednak nie potrafie zrobic tego pod swoje potrzeby. U mnie wyglada to tak że, mam shelly1 gdzie jest proste włacz wyłacz, jednym przyciskiem. Kombinuje i cos mi nie idzie, a wydaje sie ze ta część powinna być prostrasz Ta zaznaczona czesc nie dziala, a w niej pewnie ta na żółto nie działa.
Czujka jak wykryje ruch to po sek światło gasnie.
flows (5).json (7.3 KB)
Pomoze ktos ? ![]()
Walcze dalej,
poprawilem troche ( chociaz ciagle nie dziala
Pokaze punkty w ktorych gdzies jest babol.
Stan swiatla
Stan przelacznika
wlacz /wylacz
Swiatlo w lazience
Stan
I tym razem nie reguje w ogole na wlacz/wylacz
Ma ktos pomysl ?
[{"id":"91fade93.7dae5","type":"group","z":"4d1d611d.bd4da","style":{"stroke":"#999999","stroke-opacity":"1","fill":"none","fill-opacity":"1","label":true,"label-position":"nw","color":"#a4a4a4"},"nodes":["67b6ed2e.1b31f4","284f107ce2305d90","ed312836.8c40f8","df3e4bfe.009b88","95e9fc25.5a002","6edd7a56c4a06ade","f00e785fd564cdd3","40e47b1be78e9167"],"x":14,"y":-1,"w":1072,"h":142},{"id":"67b6ed2e.1b31f4","type":"mqtt in","z":"4d1d611d.bd4da","g":"91fade93.7dae5","name":"Przełącznik pod szafkami","topic":"shellies/shelly_pod_szafkami/input_event/0","qos":"2","datatype":"json","broker":"7f257382.e85b1c","nl":false,"rap":false,"inputs":0,"x":150,"y":40,"wires":[["284f107ce2305d90"]]},{"id":"284f107ce2305d90","type":"switch","z":"4d1d611d.bd4da","g":"91fade93.7dae5","name":"Czy krótkie","property":"payload.event","propertyType":"msg","rules":[{"t":"eq","v":"S","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":390,"y":40,"wires":[["6edd7a56c4a06ade"]]},{"id":"ed312836.8c40f8","type":"function","z":"4d1d611d.bd4da","g":"91fade93.7dae5","name":"Ustaw wyłączony","func":"flow.set(\"pod_szafkami\",0)\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":970,"y":80,"wires":[[]]},{"id":"df3e4bfe.009b88","type":"function","z":"4d1d611d.bd4da","g":"91fade93.7dae5","name":"Ustaw włączony","func":"flow.set(\"pod_szafkami\",1)\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":960,"y":40,"wires":[[]]},{"id":"95e9fc25.5a002","type":"api-current-state","z":"4d1d611d.bd4da","g":"91fade93.7dae5","name":"Czy świeci","server":"c00e7dc3.fec7d","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"light.pod_szafkami","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":750,"y":40,"wires":[["df3e4bfe.009b88"],["ed312836.8c40f8"]]},{"id":"6edd7a56c4a06ade","type":"delay","z":"4d1d611d.bd4da","g":"91fade93.7dae5","name":"1 sek","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":570,"y":40,"wires":[["95e9fc25.5a002"]]},{"id":"f00e785fd564cdd3","type":"server-state-changed","z":"4d1d611d.bd4da","g":"91fade93.7dae5","name":"Czy zmiana w HA","server":"c00e7dc3.fec7d","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"light.pod_szafkami","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"off","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[],"x":120,"y":100,"wires":[["40e47b1be78e9167"],[]]},{"id":"40e47b1be78e9167","type":"switch","z":"4d1d611d.bd4da","g":"91fade93.7dae5","name":"Czy przełącznikiem","property":"pod_szafkami","propertyType":"flow","rules":[{"t":"eq","v":"1","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":730,"y":100,"wires":[["ed312836.8c40f8"]]},{"id":"7f257382.e85b1c","type":"mqtt-broker","name":"HA MQTT","broker":"localhost","port":"1883","clientid":"","autoConnect":true,"usetls":false,"compatmode":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""},{"id":"c00e7dc3.fec7d","type":"server","name":"Home Assistant iZYD","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30"}]
Nie było mnie kilka dni w domu więc dopiero wrzucam (o ile to pomoże)
tutaj masz cały json ze moim sterowaniem oświetleniem
flows.json (79,9 KB)
Dzieki Rafał,
Twoje flow to kosmos jeszcze dla mnie.
Poki co odpuszczam swoj przykład bo ciagle nie wychodzi…;|
Kurde a kopiouje prawie identycznie jak ma Rafał na yt.
Chyba że ktos pomoże za pare groszy i mi to wyjaśni co robię źle to chetnie zapłace.
Ok napisz co chcesz uzyskać tzn. kiedy ma zapalać światło kiedy gasić, oraz jakie warunki i jaki sprzęt ma to wywoływać) coś w wolnej chwili postaram się pomyśleć i podeślę jakieś moje przemyślenia ![]()
@rizydorczyk na poczatku dzieki ![]()
Teraz mowie o co chodzi.
Zdarza sie sytuacja w ktorej wieczorem żona idzie do łazienki , zapala światło…w tym czasie małe dziecko zaczyna wołać tata tata
Tata idzie , załacza sie czujka i wyzwala zapalenie swiatła i mam ustawione ze po 2 min sie wyłacza. Siedze z dzieciakiem ponad 2 min a w tym czasie żonie gasnie swiatło ![]()
Wiem ze na kanale yt Artur robił własnie taki flow ale mi to w ogole nie wychodzi.
W gniazdku mam shelly 1 , swiatło ma jeden włacznik gora doł (włacz wyłacz).
Mam tez czujke aqura.
Flow wyglada tak…
Gorna częsć działa jak nalezy, ale żeby działało tak jak na filmiku , że jak Żona zapali swiatło to jak by zatrzymywało proces odliczania i zeby nie gasiło jej tego swiatła ![]()
Na 100% skopana jest czesc zaznaczona, probowalem jak Artur w filmiku …po swojemu…i gdzies robie ( chyba prosty) bład.
Podrzucam tez flow
flows (9).json (9.3 KB)
Dziekuje
Ja mam oświetlenie w korytarzu rozwiązane w ten sposób jak na poniższym flow i działa prawidłowo już od dłuższego czasu. Mam dodatkowo uwarunkowane od nasłonecznienia na czujniku i od pozycji słońca.
@MarcO podzielisz sie flow ?
Nie ma problemu
Oswietlenie korytarza w nocy.json (21,3 KB)
Moja automatyzacja wygląda tak jak na obrazku i mam jeden problem, światło zapala się po około 30s od momentu wykrycia ruchu.
PIR to czujnik Aqara, a za włączanie oświetlenia odpowiada Sonoff Mini.
Z innymi procesami nie mam takiego problemu.
Czy ktoś spotkał się z podobnym problemem?
Dość długo, wrzuć tu swój flow
flows(1).json (4.3 KB)
Proszę.
Wiem, że brakuje tam kilku nodów, do sensownego działania, ale na ten moment co innego jest moim problemem
Zauważ ze twoja czujka załączy twoje światło dopiero gdy czujka zmieni stan z on na off
bo tak to ustawiłeś, czyli załącza ci światło po czasie gdy czujka przechodzi ci w stan wyłączony.
Faktycznie moje niedopatrzenie, zmiana połączeń pomogła
Rewelacyjny materiał , Przepływ dostosowałem do swoich potrzeb i działa zawodowo. Mam tylko pytanie , W tym poradniku nie wspominasz o możliwości załączenia światła z interfejsu HA i jak zachowa się przepływ. Jak rozumiem nie da się tak zmodyfikować przepływu , żeby po włączeniu oświetlenia uzyskać to samo co po użyciu przycisku fizycznego ? Po włączeniu lampy z interfejsu , naruszenie czujnika aktywuje odliczanie czasu do wyłączenia lampy i tylko użycie przycisku fizycznego pozwala na zablokować część przepływu .
@ Pawel123 Udało się zrobić ten algortym?
Mam ten sam problem: czujnik ruchu steruje przełącznikiem wifi a ten zapala zwykłą żarówkę. Sposób, który pokazuje Artur tu raczej nie zadziała gdyż stan przełącznika zawsze zmienia się wg tego co podaje czujnik ruchu.
Macie jakiś pomysł jak to zrobić by normalnie światło zapalało się i gasło jak teraz, wg czujnika ruchu, a jak włączę ręcznie to chciałbym by świeciło dopóki ręcznie go nie wyłączę?
