service nut-server status
● nut-server.service - Network UPS Tools - power devices information server
Loaded: loaded (/lib/systemd/system/nut-server.service; enabled; vendor preset: enabled)
Active: active (running) since Mon 2021-02-22 14:56:38 CET; 1min 32s ago
Process: 14614 ExecStart=/sbin/upsd (code=exited, status=0/SUCCESS)
Main PID: 14622 (upsd)
Tasks: 1 (limit: 4915)
Memory: 716.0K
CGroup: /system.slice/nut-server.service
└─14622 /lib/nut/upsd
Feb 22 14:56:38 pve upsd[14614]: addchar: discarding invalid character (0xe2)!
Feb 22 14:56:38 pve upsd[14614]: addchar: discarding invalid character (0x80)!
Feb 22 14:56:38 pve upsd[14614]: addchar: discarding invalid character (0x9c)!
Feb 22 14:56:38 pve upsd[14614]: addchar: discarding invalid character (0x9d)!
Feb 22 14:56:38 pve upsd[14614]: Connected to UPS [ups]: usbhid-ups-ups
Feb 22 14:56:38 pve upsd[14622]: Startup successful
Feb 22 14:56:38 pve systemd[1]: Started Network UPS Tools - power devices information server.
Klient natomiast wyświetla coś takiego:
service nut-client status
● nut-monitor.service - Network UPS Tools - power device monitor and shutdown controller
Loaded: loaded (/lib/systemd/system/nut-monitor.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2021-02-22 15:01:28 CET; 5s ago
Process: 15466 ExecStart=/sbin/upsmon (code=exited, status=1/FAILURE)
Feb 22 15:01:28 pve upsmon[15466]: addchar: discarding invalid character (0x80)!
Feb 22 15:01:28 pve upsmon[15466]: addchar: discarding invalid character (0x9d)!
Feb 22 15:01:28 pve upsmon[15466]: Network UPS Tools upsmon 2.7.4
Feb 22 15:01:28 pve upsmon[15466]: Fatal error: insufficient power configured!
Feb 22 15:01:28 pve upsmon[15466]: Sum of power values…: 0
Feb 22 15:01:28 pve upsmon[15466]: Minimum value (MINSUPPLIES): 1
Feb 22 15:01:28 pve upsmon[15466]: Edit your upsmon.conf and change the values.
Feb 22 15:01:28 pve systemd[1]: nut-monitor.service: Control process exited, code=exited, status=1/FAILURE
Feb 22 15:01:28 pve systemd[1]: nut-monitor.service: Failed with result ‘exit-code’.
Feb 22 15:01:28 pve systemd[1]: Failed to start Network UPS Tools - power device monitor and shutdown controller.
Witam, po ostatnich wydarzeniach przyszedł czas na dołożenia UPSa do swojej instalacji. Postępowałem zgodnie z opisem do momentu uruchomienia usług. Przy próbie wykonania poleceń:
nut-server start
nut-client start
dostaję komunikat
-bash: nut-server: command not found
-bash: nut-client: command not found
wykonałem restart proxmoxa i usługa nut-server uruchomiła się
Witam wszystkich forumowiczów. Może ktoś podpowie co mam zrobić? Zainstalowałem NUT na proxmox. wszystko ładnie , pięknie chodzi, ale po rstarcie HA muszę ręcznie na Proxmox komendą service nut-server start wystartować server ponieważ w logach mam komunikat że nie moze sie połaczyć z blazer_usb driver. Czy to jest normalne ze trzeba startować ręcznie? Czy może coś jest nie tak?
Nie trzeba - komenda service powoduje wystartowanie danej usługi w danym momencie. jeśli chcesz odpalić permamentne startowanie usługi podczas startu systemu wystarczy że użyjesz komendy
Myślałem że jest ok ale po restarcie Proxmoxa mam w logach to co niżej i integracja nut w HAnie startuje
Mar 17 18:41:30 proxmox blazer_usb[1018]: Got disconnected by another driver: Device or resource busy
Mar 17 18:41:30 proxmox upsd[1020]: Can’t connect to UPS [ups] (blazer_usb-ups): No such file or directory
Mar 17 18:41:30 proxmox kernel: hid-generic 0003:0665:5161.0003: hiddev0,hidraw0: USB HID v1.10 Device [HID UPS HID UPS] on usb-0000:00:12.0-1/input0
Mar 17 18:41:30 proxmox kernel: usb 5-1: usbfs: process 1018 (blazer_usb) did not claim interface 0 before use
Mar 17 18:41:30 proxmox systemd[1]: nut-driver.service: Main process exited, code=exited, status=1/FAILURE
Mar 17 18:41:30 proxmox systemd[1]: nut-driver.service: Failed with result ‘exit-code’.
Mar 17 18:41:32 proxmox upsmon[1023]: Poll UPS [ups@localhost] failed - Driver not connected
Mar 17 18:41:32 proxmox upsmon[1023]: Communications with UPS ups@localhost lost
Mar 17 18:41:37 proxmox upsmon[1023]: Poll UPS [ups@localhost] failed - Driver not connected
Mar 17 18:41:42 proxmox upsmon[1023]: Poll UPS [ups@localhost] failed - Driver not connecte
Nie jestem specem w liinuxie alle po tym co widzę to demon ma problem z sterownikiem do ups. Na pewno wpisałeś w config dobry sterownik? Co to za model UPS?
To jak z ręki startujesz sterownik a potem usługi serwera i klienta i wstają bez błędów to nie mam pomysłu. Chyba że usuń NUT, konfiguracje i zainstaluj ponownie
Witam, mam problem z NUT. Zainstalowany na Fujitsu q920 (Proxmox i HomeAssistant)
UPS : Ever Eco Pro AVR 1200 w wersji RACK. USB podpięty pod różne porty ale na wszystkich tak samo, nut-scanner nie widzi nic
Wydaje sie ze wszystko dobrze skonfigurowałem, bo sprawdzałem na innym UPSie Ever Duo Pro II - i wszystko ładnie śmiga. Natomiast ten rackowy nie chce się podpiąć.
Teoretycznie jest widoczny:
Brakuje już mi pomysłów, proszę o pomoc bo nie wiem już gdzie szukać rozwiązania, ewentualnie jaki rackowy UPS bez problemu ruszy a do tego nie kosztuje majątku.
Odkopuję temat
Zakupiłem niedawno UPS APC BR900G-GR 900 VA. Korzystając ze świątecznego przedpołudnia postanowiłem powalczyć z podłączeniem go do HA. Konfigurację przeprowadzałem zgodnie z tą instrukcją: Konfiguracja NUT pod Proxmox
Użyłem drivera APCSMART. Niestety serwer się nie uruchamia. Moja wiedza co do linuxa ogranicza się do tego co przepisuję z instrukcji próbując użytkować od niecałych dwóch miesięcy HA na Proxmoxie, tak że nawet nie bardzo wiem gdzie szukać błędów. Próbowałem restartów, przepinania portów USB, jednak serwer NUT nie wstaje.
Zadziałało Dzięki
Sugerowałem się cytowaną stroną ze sterownikami gdzie wybrałem Back UPS-PRO.
Ale teraz działa.
Aktualizacja
Niestety moja radość była przedwczesna. Po podmianie sterownika sprawdziłem tylko czy mam podgląd parametrów i że wszystko wyglądało ok. to się ucieszyłem.
Później próbowałem zainstalować integrację w HA i nie mogą uzyskać połączenia. Niestety sprawdzając status serwera i clienta wychodzą jakieś błędy.
Server:
Integracji nie jestem w stanie uruchomić – mimo różnych prób nie udało mi się wyjść poza okno łączenia z serwerem NUT. Dlatego też zacząłem przyglądać się instalacji w proxmoxie i zauważyłem te błędy. W tych linijkach upomina się o jakiś plik – może tu jest problem?
