Mam głowicę termostatyczną Fibaro. Co robię nie tak, że nie mogę przez NR zmienić zadanej temperatury. Próbowałem już w nodzie inject wysyłać jak msg.payload i msg.temperature i cały czas mam ten sam błąd.
Trzeba uzupełnić pole data z msg. payload poszukaj składni na forum (Termostat) było publikowane.
Dziękuję za podpowiedź.
Sterowanie trybem
Przykładowy Kod do importu NR
[{"id":"ff818902.0ff108","type":"server-state-changed","z":"e6798371.41886","name":"coolTargetTemp","server":"","version":3,"entityidfilter":"input_number.target_temp_cool","entityidfiltertype":"substring","state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":620,"y":1900,"wires":[["6b0934e8.90e5bc","be4be28e.ff3ac"]]},{"id":"f2190030.3d76c","type":"server-state-changed","z":"e6798371.41886","name":"Input Temp","server":"c13cf592d5df7fba","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_number.target_temp_heat","entityidfiltertype":"substring","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":false,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":600,"y":1860,"wires":[["6b0934e8.90e5bc","2f69eaa9.e4b416"]]},{"id":"c5a83afa.d18ce8","type":"api-call-service","z":"e6798371.41886","name":"coolSetThermostat","server":"","version":3,"service_domain":"climate","service":"set_temperature","entityId":"","data":"{ }","mergecontext":"","outputProperties":[{"value":"","valueType":"data"}],"queue":"none","x":990,"y":1900,"wires":[[]]},{"id":"be4be28e.ff3ac","type":"function","z":"e6798371.41886","name":"Fn","func":"msg.payload = { data: { 'entity_id': 'climate.hallway_nest','temperature':msg.payload}};\n\nreturn msg;","outputs":1,"noerr":0,"x":830,"y":1900,"wires":[["c5a83afa.d18ce8"]]},{"id":"2f69eaa9.e4b416","type":"function","z":"e6798371.41886","name":"Fn","func":"msg.payload = { data: { 'entity_id': 'climate.hallway_nest','temperature':msg.payload}};\n\nreturn msg;","outputs":1,"noerr":0,"x":830,"y":1860,"wires":[["e6c79eef.e4f5"]]},{"id":"e6c79eef.e4f5","type":"api-call-service","z":"e6798371.41886","name":"heatSetThermostat","server":"","version":3,"service_domain":"climate","service":"set_temperature","entityId":"","data":"{ }","mergecontext":"","outputProperties":[{"value":"","valueType":"data"}],"queue":"none","x":990,"y":1860,"wires":[[]]},{"id":"c13cf592d5df7fba","type":"server","name":"Home Assistant Artur","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
Trochę inaczej wykombinowałem:
ale działa tak jak chciałem.
Teraz szukam jakiejś karty “harmonogram” albo coś będę kleił z encji i pomocników. A może po prostu napiszę automatyzację.
Jeżeli dla HA to jest harmonogram w HACS
Dzięki, zaraz poszukam.
Masz na myśli scheduler-component / scheduler-card czy coś innego?
scheduler-component współpracuje z scheduler-card
